BMW M3 Forum (E90 E92)
      07-23-2009, 10:39 PM   #67
bigsky
Drives: M3
How do you reset the oil change computer if you are at the scheduled oil change?
      07-23-2009, 11:08 PM   #68
GregW / Oregon
Commander-In-Chief
2122
Drives: 2023 M2 Coupe, 2020 GLE 450
I takes special equipment. Not sure if there are owner-usable devices out yet. Presumably you are getting your oil changed at a dealer for the first 4/50 since it's free.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      07-24-2009, 11:27 AM   #69
JCtx
Drives: No BMW yet
More like special knowledge. There's a thread somewhere how to reset every maintenance item. It wasn't an M3, but it's reportedly the same procedure. It's with the OBC buttons, by the way, and that was confirmed by an M3 owner watching a tech reset his computer on the dash. We just need to learn how . Good day.
      07-25-2009, 01:05 AM   #70
KrazyM3
Drives: 2008 AW M3
Here you guys go!
PROCEDURE TO VIEW OR RESET SERVICE ITEMS IN THE INSTRUMENT CLUSTER E90, E91, E92, E60, E61, E63 AND E64 Includes M Cars
Turn ignition to Terminal 15.
Press and hold the Instrument Cluster Set/Reset button for 10 seconds.
The upper display in the Instrument Cluster will be illuminated with a Service Item (example: An oil can is the designation for Oil Service). The lower display in the Instrument Cluster will indicate the remaining time or mileage left for that Service Item (example: 14000). Pressing the button repeatedly will allow the display to scroll through all of the Condition Based Service Items.
Press and hold the Instrument Cluster Set/Reset button again and the lower display screen will indicate "OK" or "DUE".
Pressing the Instrument Cluster Set/Reset button again will allow the "RESET" to appear in the lower window for that service. Releasing and reapplying the button one more time will reset the service displayed in the upper window only. Repeat the procedure for any additional service reset needs.
Note: The CBS service items for both State Vehicle Safety Inspection and State Emissions Inspection cannot be viewed in the Instrument Cluster. These State Inspections can be viewed on the CBS Menu in the Control Display or by DISplus / GT1.
      07-25-2009, 01:59 PM   #71
JCtx
Drives: No BMW yet
Is this button the trip-meter one or the stalk's OBC (on-board computer) one?
Could you clarify? Does 'control display' means iDrive? Many states don't have emissions testing, plus you can get it done wherever you want, so it'd seem stupid not being able to reset it yourself, iDrive or not. Thx.
      07-25-2009, 08:13 PM   #72
KrazyM3
Drives: 2008 AW M3
Correct it is the trip reset button.
Everything is done in front of you, you will not need iDrive to to this.
      07-26-2009, 12:54 AM   #73
bigsky
Drives: M3
Thanks!
      07-26-2009, 03:56 AM   #74
McLuVan
McLuVan's Avatar
Vietnam
304
Drives: ///M3
which is m6 and which is m8
      07-28-2009, 10:34 AM   #75
JonM
Drives: E90 M3 Sedan
You will have to measure the threads. On my car, both plugs are the same size.
Jon Maddux
coupenut.blogspot.com
x5nut.blogspot.com
16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe
      08-01-2009, 02:59 PM   #76
FrenchBoy
FrenchBoy's Avatar
France
234
Drives: '16 F80 M3
Changed my oil yesterday. Process is pretty straight forward. Here are a couple of comments:
1. Both drain plugs required a 6mm Allen wrench. It initially confused me because the DIY mentions 2 different plugs (6mm and 8mm). I did not take thread measurements but both plugs look pretty similar to me.
2. In addition to the large filter housing o-ring, remember to replace the copper crush washers with new ones; they are provided with the filter.
3. I emptied the oil left in the oil filter reservoir (with a syringe). I added about 8.3L of oil and the reading is now right in the middle. I will monitor in the next few days to see if that changes
4. Greg, you mention that you used the front center jack point after the rear is up on ramps. I tried that but there was no way my jack (which is somewhat low profile) would fit under the car once the rear is up on ramps. Do you have a special jack or technique? I ended up using a jack on each side to lift the front. Worked well.
Thanks for this DIY.
Current: 2016 F80 M3 6-Speed | SO | AB XT1 | ZCP | M Performance Suspension | GC Camber Plates
Previous: 2009 E90 M3
      08-01-2009, 05:25 PM   #77
GregW / Oregon
Commander-In-Chief
2122
If you slide the jack in at an angle from behind the front wheel, rather than the front of the car, there is plenty of height.
      08-01-2009, 05:53 PM   #78
FrenchBoy
FrenchBoy's Avatar
France
234
Drives: '16 F80 M3
Thanks for the reply Greg. I tried that and my jack hit the bottom of the car half way to the jack point. And that's with the stock suspension. I guess my jack is too big ;-(
The 2-jacks method worked fine though. Especially since Dawgdog was there manning one of them while I was on the other.
Thanks!
      08-01-2009, 10:48 PM   #79
dawgdog
148
Drives: 2015 M3, 2016 GT3
Thanks!
Was an interesting process. I would do much better working at my job and paying to have it done, but there is a real sense of satisfaction in doing it oneself.
2015 f80 M3, 2016 GT3
      08-02-2009, 04:14 PM   #80
Silvertige
Silvertige's Avatar
Drives: 2011.75 e92 M3
1988 BMW 535i  [10.00]
Thanks for all the info. I'll be doing this soon...
      08-03-2009, 12:57 PM   #81
JonM
I think some cars were made with M6 and some were made with M8.
Jon Maddux
x5nut.blogspot.com
      08-04-2009, 11:59 AM   #82
FrenchBoy
FrenchBoy's Avatar
France
234
Drives: '16 F80 M3
Update. After getting the initial ready in the middle of the range on my first drive after the oil change, it took a few more drives (my commute is short) before I got another reading. Which was last night. And it said "+1qt". I added a bit of oil (a couple of times) and eventually got the marker in the middle. Total oil added was about 8.8L.
The "+1qt" reading is pretty misleading. If I had added an actual quart, I think I would have overfilled the engine with oil.
As others have said, the process is quite annoying. A dip stick is clearly an easier approach. However, since there are 2 reservoirs, it may not be a viable option. Unless you have 2 dip sticks of course...
      08-04-2009, 12:05 PM   #83
GregW / Oregon
Commander-In-Chief
2122
Did you do a "reset" on the oil level by holding in the stalk for a few seconds after you first changed it?
      08-04-2009, 03:26 PM   #84
FrenchBoy
FrenchBoy's Avatar
France
234
Drives: '16 F80 M3
No. I guess that explains why it was still showing up in the middle right after the oil change. Must have missed that part of the DIY.
Thanks Greg!
EDIT: Now that I think about it, why do I have to "reset" the oil level?
Isn't that what the car does when it spends 10 mins trying to figure out the level? which it did after I changed the oil, and then gave me a reading
      09-12-2009, 04:40 PM   #85
4u3
20
Drives: 09 E92
I have to do it myself the next time, I track my car 2-3 weekends a month. Had my oil changed at 6000 miles was charged one hour time at 100 per hour plus cost of oil and filter. Do not have the receipt in front of me but I bet it was close to $200.00. Never again. Oh well keeps the economy going. Thanks for the pics.
      09-12-2009, 05:16 PM   #86
GregW / Oregon
Commander-In-Chief
2122
Thanks Greg!
It will eventually correct itself. I am told this just speeds up the process. Don't get me going on the "no dipstick" rant again.
      09-13-2009, 01:19 PM   #87
JCtx
Drives: No BMW yet
You need to 'reset' it at the right time to get a correct reading. Yes, ECU 'resets' level every time you turn the engine ON, but you don't know when it's going to take the reading (usually 5 to 10 miles into your trip), which most likely won't be on a flat surface while idling, which is the correct way to do it. Once engine oil is at full operating temperature, a 'reset' has the same effect as turning engine off and back on again, so it saves battery juice, starter wear and time . When you get home, use the same spot in your garage and do a 'reset' before turning engine off to check level accurately. And yes, always use the same spot and the same technique (idle with engine fully hot) for consistent readings. Hope this helps.
      10-24-2009, 03:32 PM   #88
///M Protocol
Guest
n/a
Drives:
Thanx for the DIY. I used this DIY to fix the dealer overfill. The dealer overfilled my engine by .5 liter. As soon as I drained the front oil sump, my reading is perfect.
The last technician that worked on my car didn't even drain the front slump hence the overfill. I know this because when I unscrew the M6 plug, I heard the loctite snapping. THis is a sign that the drain plug was never removed.
m3post
