08-07-2019, 02:56 PM | #1 |
Rep 5
B48 Turbo Upgrades
I've started noticing that some upgrated tubos are coming out. Is there any owner of a car with installed one? How it is going? what dyno results are you having? What futher modifications are done to the car?
Most modified turbos says that it can give around 400hp so what about transmission? In my car I have ZF8HP55 which as I know can handle 550 nm of torq. So after installing such turbo transmission should be changed to smth. Do my considierations are correct? |
12-02-2019, 11:54 AM | #3 |
24350
Rep 191,156
Sub'd
12-14-2019, 02:20 AM | #4 |
73
Rep 95
I have one, I got it in Taiwan shop import to CN, they will not tell me much about the spec, cost me about 1700 USD with installation. They tell it should support 400 WHP.
Here is log, running JB4 & e98 METH, with e30 gas, on top of BM3 S2 e30 OTS flash. https://datazap.me/u/rmtm/log-1576310981?log=1&data=1-4 Car is a blast, here is a 100-200 run at 10.68s, not too bad, JB4 log below is that same run, ignore first 4 seconds, spun tires in 1st /2nd had to pull off, 22 PSI on that run up top, still did 13.1s in quarter on that one, with 2.33s 60ft, take 0.4s off that with a more reasonable 1.9s 60ft, FYI 180.8 kph = 112.3 mph. https://datazap.me/u/rmtm/log-1576310981?log=0&data=1-4 I included also 100-200 in same place but on stock turbo for compare, as 12.6 seconds, that was at same or higher boost, and also about 20 deg higher ambient temps, so that is part of it One weird thing with JB4 it keeps lower FF (WGDC learning) even when boost is under target, you can see it in my log, the FF is lowering during the run, and boost is like 2 psi under target, by end of run it is 3 psi under, frustrating |
12-14-2019, 04:38 AM | #5 |
Rep 500
Drives: BMW 330e F30 M-sport
Pretty sure you have the 8HP50.
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
b48, turbo |
