Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Can the oil thermostat cover gasket be purchased?
      11-23-2021, 01:50 PM   #45
mweisdorfer
mweisdorfer's Avatar
Drives: 2007 Black/Black 335i e90
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
You can get them from BMS
https://burgertuning.com/collections...thermastat-lid
      11-23-2021, 01:55 PM   #46
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
2659
Drives: 11' 335is DCT
Originally Posted by mweisdorfer View Post
That one is just the lid. Doesn't come with a gasket.
      11-23-2021, 02:32 PM   #47
Wolf 335
Wolf 335's Avatar
2341
Drives: 2007 E92 335i
Originally Posted by ab987 View Post
Well I ordered these and they are way too big
https://www.theoringstore.com/store/...ducts_id=27461
Do you have a link to the ones you ordered, or any leftover? I thought 6mm CS 37ID would do it, but no way in hell. They are absolutely massive.
Thanks
There's a link from Grainger few posts above that Biginboca posted.
You need:
Internal diameter of 37mm
Outside diameter 43mm
43-37 = 6
6/2 = 3mm Cross Section (thickness of the ring)
feuer4275.50
      11-23-2021, 02:52 PM   #48
TheMidnightNarwhal
2659
Thanks
I think your issue is you got the 6mm thick one instead of 3mm.
      11-23-2021, 04:52 PM   #49
ab987
192
Drives: X3M, M3, 335i
2008 BMW 335i  [9.00]
2020 BMW X3 M  [9.25]
2010 BMW M3  [9.00]
2016 Mini Cooper  [0.00]
Yeah I figured, but all of the graphics I could find by googling it showed axial cross section as diameter rather than radius. I couldn't even find a 3.0x37. I'll check that link though
      11-23-2021, 08:23 PM   #50
ab987
192
2010 BMW M3  [9.00]
Originally Posted by Biginboca View Post
Well you can get 5 Viton O rings that work from Granger for $10 so why on earth would anyone pay $50 for 1?
https://www.grainger.com/product/GRA...-Inside-713H04
These are 43mm ID / 49mm OD btw, so too big. Are these what I'm looking for?
https://www.grainger.com/product/GRA...-Inside-713G96
Biginboca3763.50
      11-23-2021, 08:37 PM   #51
Biginboca
Biginboca's Avatar
3764
Drives: 2009 E92 328i 6MT
Oops! You are right I posted the wrong one.
This one should be right, 37mm ID x 43mm OD and 3mm cross section viton gaskets:
I edited that post also with the correct ones. Thanks for bringing that to my attention!
Appreciate 3
Wolf 3352340.50
ab987192.00
feuer4275.50
      11-24-2021, 06:00 PM   #52
soulcrusher
10
Drives: BMW 335i
Oh my goodness, I'm in this same situation with an oil leak at this thermostat!
What are the results of your purchases? I need to replace this gasket but I want a proven quality seller....
      11-24-2021, 06:01 PM   #53
soulcrusher
10
Drives: BMW 335i
Originally Posted by Wolf 335 View Post
I sourced a few and still have some left over. Get in touch with me through PM.
I got the same ones as spidertri
Viton 43mm OD, 37mm ID, 3mm thick o-ring
Do you have any left? How's the gasket holding for you?
      11-25-2021, 07:15 AM   #54
Wolf 335
Wolf 335's Avatar
2341
McMaster-Carr, Grainger, Fastenal - all reputable suppliers.
Unfortunately I don't have any left.
Key things to consider are material (Viton) and Dimensions.
Super easy to replace. I've had mine now through a wide range of temperatures and so far they are holding up amazing. No sweating or leaks.
      01-22-2022, 03:10 PM   #55
Shanemac
Drives: E34 E83
Found similar gasket
Originally Posted by feuer View Post
To my knowledge no.
Search on Google or eBay for...Thermostat Housing Seal - 2012-2018 Chevrolet Sonic - AC Delco
https://www.ebay.com/itm/For-2012-20...-127632-2357-0
Appreciate 3
feuer4275.50
      01-22-2022, 04:01 PM   #56
Shanemac
Drives: E34 E83
Also found this
Going to try this one and see if it works
Appreciate 3
feuer4275.50
      01-22-2022, 05:06 PM   #57
feuer
feuer's Avatar
Drives: wife crazy!
My post is from 2018. Now is 2022. Things change. I’m glad that now we have options. Good find.
      01-22-2022, 06:03 PM   #58
Shanemac
Drives: E34 E83
I'm new to these forums and to posting always jus read..will post results. Unfortunately right now is too cold to attempt and I don't have a garage.
      02-06-2022, 08:55 AM   #59
david in germany
Drives: 118i, 335i and 328i
And? How are the measurements?
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
      02-09-2022, 01:48 PM   #60
Shanemac
Drives: E34 E83
Jus tried it out and unfortunately it's too big and too thick by about 3mm. I had a spare round gasket like the picture above that I was able to make it work.
      02-10-2022, 08:25 AM   #61
Liquidsk8s
Drives: BMW 135i N55
I just came to post the same result lol, rolled the dice. $9 on Amazon prime figured why not hah.
I’m ordering the other o ring others have been using. Crazy BMW don’t have this part.
      02-14-2022, 05:18 PM   #62
Shanemac
Drives: E34 E83
Haha Yea I don't understand why they wouldn't sell that gasket
      02-15-2022, 07:45 AM   #63
Wolf 335
Wolf 335's Avatar
2341
Guys just a quick update.
I have had the viton o-ring for a year now. The car is a daily driver and has seen a vast amount of weather and temperature variations.
The o-ring is doing its job great. I see no sweating or leaks around the cover plate.
Appreciate 3
      02-15-2022, 04:26 PM   #64
E90lmao
27
Drives: 2001 e46 325i, 2008 e90 335i
That's awesome news! I recently bought a used oil thermostat housing so I can add an oil cooler. I figured I change this gasket now and save myself the headache later, just have to try and find one within Canada preferably. With shipping and duties, anywhere outside of Canada is pretty rough.
      02-16-2022, 12:20 PM   #65
jadams161
jadams161's Avatar
Drives: 2009 E93 335i. 2011 E90 328xi
Malo industries sells them too Fast shipping from Canada. The crank seal plate is amazing too.
Appreciate 3
feuer4275.50
Wolf 3352340.50
E90lmao27.00
      02-16-2022, 09:44 PM   #66
feuer
feuer's Avatar
Drives: wife crazy!
Very nice! https://www.maloindustries.com/
Wolf 3352340.50
