The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > add e85 to fix timing corrections MHD
      05-06-2019, 12:32 PM   #1
tony55343
104
Drives: 08 335i coupe 6mt
Quick question, I believe I got some bad 93 oct in my car. My prior logs have all been great , very little to no timing corrections. However after filling up this last time I have some corrections across all 6 cylinders which I believe could be due to poor quality 93 . Could I safely add like 2-3 gallons of E85 to my tank to try and up the octane and see if it will help with the timing corrections?
Currently have MHD stage 2+ , all maintenance up to date. Dci's , intercooler, downpipes. Running v8 93oct stage 2+ map on MHD .
Thanks in advance!!
      05-06-2019, 12:33 PM   #2
Silent9n54
574
Drives: 2007 E92 335i
yes, i ran E maps with ZERO mods, you are still on gas tune so a little E85 will only bump your octane levels
      05-06-2019, 12:39 PM   #3
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
2659
Drives: 11' 335is DCT
You can always dial back to lower octane tunes to if E85 don't do anything (altho it should if octane is the problem).
      05-06-2019, 12:40 PM   #4
tony55343
104
Cool thanks, yea I don't want to run E maps until I have the stage 2 lpfp etc. Just looking to minimize/eliminate corrections on this tank until I can refill with fuel thats up to par .
You think like 2-3 gallons with the rest 93 would be good enough, and safe?
      05-06-2019, 12:41 PM   #5
type-dRew
type-dRew's Avatar
641
Drives: 2009 335i xDrive
Yeah, no issue adding some ethanol to a tank of gas. The car will compensate fueling needs and you'll get back the octane you lost.
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50
11.61 @ 117.5
New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets
      04-13-2024, 03:32 PM   #6
tbeam335
tbeam335's Avatar
Drives: 2007 BMW 335i
How much should I add for -3 corrections across all 6? I’m also losing 3 degrees timing
