05-03-2021, 11:54 AM | #2289 |
65
Rep 59
Finally got around to snapping some pics of mine. These are tough to get the right lighting on them haha. Replaced at 99k. Glad I didn't listen to the people saying it was just fear mongering.
05-03-2021, 06:08 PM | #2290 |
Rep 1,038
Drives: BMW M3 e92 08 & 330d e90 10
Yikes! Some really bad there, copper with purple/blue overheating streaks!
Weird how some of the other uppers are nowhere near as bad Bet you're glad you've got shot of those old ones , what did you replace them with?
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. |
05-03-2021, 08:47 PM | #2291 | |
65
Rep 59
I was also a little curious as to why the 1,3,4 and 8 tops were so bad with the others being more reasonably worn. Guess it was just the luck of the draw on clearances? |
05-04-2021, 05:01 AM | #2293 | |
Rep 1,038
Yikes, yea 3 shells were indeed shot!
Good that they're gone! Quote:
Those shells showing copper had no life left, the lead isn't supposed to wear away. Re copper colouring, fair enough, I found it hard to get the colour right with photos too, I had the opposite problem, at least 2 shells were showing blue/purple streaks but it didn't show under the workshop lights, I had to photo them outside to make it visible.
05-04-2021, 08:31 AM | #2294 | ||
2631
Rep 2,142
Drives: 2011 E92 M3
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
05-07-2021, 08:44 PM | #2295 |
116
Rep 161
2013 E93 M3, replaced with the VACMotorsports kit at 48k. These are the aluminum/zinc bearings that were used starting in 2011. |
Assimilator1594.00 |
05-08-2021, 04:46 AM | #2296 |
Rep 1,038
Yea, not too bad at all, but more wear than it should be at just 48k miles, typical LCI bearings.
Alu/tin from mid-ish 2010 btw Any idea what bearings VAC use btw?
05-08-2021, 04:52 AM | #2297 |
Rep 860
VAC should currently be using a calico CT1 coated clevite tri-metal bearing, but as you should know they have been known to sell other bearings from time to time when the supply is thin and not disclose what they were actually shipping, or would coat cover the bearings so you had no idea what you actually were sent. I believe they even sent someone coated OEM bearings at some point, but it’s been some time since I read that story.
05-08-2021, 05:24 AM | #2298 |
Rep 1,038
I've no idea what bearings they've sold in the past .
Thanks for the reply, sounds like a bit of a lottery, I wouldn't want OEM bearings!
05-15-2021, 07:49 AM | #2299 |
Rep 22
Here are the rod bearings removed from the replacement engine that ran 50000km
1-4 top and bottom 5-8 top and bottom 1-4 top more closeup 1-4 bottom closeup 5-8 top closeup 5-8 bottom close-up . |
05-15-2021, 11:33 AM | #2300 |
Rep 1,038
Good shots, thanks .
What bearings did you have fitted?
05-16-2021, 12:14 AM | #2301 |
Rep 22
05-16-2021, 10:08 AM | #2302 | |
Rep 1,485
Drives: 2011 Frozen Grey E90 M3
Enjoy
05-17-2021, 01:24 PM | #2303 |
Rep 1,038
Yea the rest don't look so good, good that they were changed.
And what year is the car again?
05-17-2021, 07:13 PM | #2304 |
Rep 1,485
2011
05-18-2021, 02:15 PM | #2305 |
Rep 1,038
Thanks, I'm guessing a build date of early 2010 as they look like the lead/copper bearings.
05-19-2021, 11:24 PM | #2307 |
Rep 1,485
Nope. Shade tree mechanic.
05-20-2021, 09:38 AM | #2308 |
Rep 2
Drives: 2011 BMW E92 M3
Bearing Service
Can anyone recommend a shop that has an excellent reputation of S65 Rod bearing replacements in the Houston, TX area? I have a 2011, E92 M3 with 32,000 miles, with the last 8-9,000 miles as a track car with an ESS 625 supercharger. I know of a few locations in Houston, but don't now their reputation on this type of service.
Thanks |
05-20-2021, 01:49 PM | #2309 |
Rep 1,038
Isn't deansbimmer/Mporium in that area?
[edit] NW Texas, no idea how near that is to you or not Not used them myself (other than to buy parts), but I believe they have a good rep from what I remember reading.
deansbimmer3767.50 |
05-21-2021, 09:28 AM | #2310 | |
3768
Rep 2,911
Drives: 2011 E93 M3
