07-07-2011, 04:41 PM | #155 | |
Mr. Nice Says Hello
637
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
07-07-2011, 04:44 PM | #156 |
Rep 7,389
07-07-2011, 05:34 PM | #157 | |
Rep 15,818
I currently have 245 40 18 285 35 18 and I like it, but I want more in the front (happy with the rear, but wouldn't mind bigger) When I said "265 35" for the Front I had meant to write "275 35" in the front with 295 35 (or 295 30?) in the rear. My current set up (Continental ExtremeContact DWs) have about 4500 miles and 2 track days. They're fine. By the end of August, there will be 5 (maybe 6?) more track days on them, and another 3k miles. My desire is for them to last until the end of August, but realistically thinking early August. Thus I need to find a replacement set of tires and was thinking of going wider which would require new rims. I'm using OEM 18s right now. Thank you for your assistance
07-08-2011, 11:22 AM | #158 | |
445
Rep 1,658
You could do 275/35/18 DW's on 18x10" fronts and 295/35/18 DW's on 18x10.5" rears. That will fit. That size combo has been done |
07-08-2011, 11:30 AM | #159 |
Mr. Nice Says Hello
637
Rep 16,662
07-11-2011, 02:46 PM | #160 |
445
Rep 1,658
I can't seem to find the other car with 295/35/18 NT-05's on the rear, but there is this one
http://www.m3post.com/forums/showpos...&postcount=120 |
07-11-2011, 03:10 PM | #161 | |
Rep 15,818
OMG Why do these look sexier than ANY other Apex wheel picture I've seen??
07-11-2011, 03:12 PM | #162 |
Rep 1,672
07-11-2011, 03:23 PM | #163 |
Rep 15,818
Yes they are but these look sexier than the one on the SSII (not that that's not sexy, but these just look sexier)
07-12-2011, 10:33 AM | #166 |
Rep 1,672
07-12-2011, 02:07 PM | #167 |
445
Rep 1,658
07-13-2011, 10:35 AM | #168 | |
Formerly K335i
19
Rep 215
So running the 15mm spacer up front on the 18x10 ET25 with 275/35R18 tires worked? No rubbing? Didn't the wheel stick out quite a bit?
I have nearly the same suspension setup (GC conversion kit), running -2.5 up front with no more than a half inch of lowering. I've got the 18x10 with 275/35 NT01s up front and notice that the tire runs really close to the strut. Good to know you have the flexibility of running a spacer if needed. Quote:
2009 E92 M3 :: Jet Black :: Fox Red Extended :: Carbon Leather :: 6MT :: JRZ RS Suspension :: RD Sport Sways :: StopTech Trophy Brakes :: Cantrell Brake Cooling |
07-13-2011, 10:42 AM | #169 |
Rep 7,389
Sorry, none right now, but I'll try to remember to snap a couple this weekend. Here you can see there's lots of room in front (it's close to the strut):
IMG_0267_DxO7D by dcstep, on Flickr
07-14-2011, 10:48 AM | #170 | |
Captain Obvious
90
Rep 977
Just a girl and her 863 ponies...
2013 Santorini M3, 2016 328i Alpine White Wagon (Lab hauler), 199x wrapped E36 M3 (because racecar) ///M-Flight |
07-14-2011, 03:13 PM | #171 |
Formerly K335i
19
Rep 215
Thanks, much appreciated! Alignment with the fender is the main thing. I guess my main concern is what happens under full compression, but if you haven't seen any rubbing, there must be enough room under the fender.
07-14-2011, 09:35 PM | #172 | |
Captain Obvious
90
Rep 977
The front with a 15mm spacer sticks out a smidge. I've never had it rub with this setup though: Here's a side shot to give you an idea of my ride height - I lowered it 1/2" from stock (no ZCP, obviously): The rear is flush with 12mm spacers. Again, no rubbing: Hope that helps! C
07-14-2011, 10:42 PM | #173 |
Formerly K335i
19
Rep 215
Absolutely does, thanks for posting!
One last question (I promise)... given that these wheels are supposed to be direct fitment, any particular reason you chose to run spacers?
07-14-2011, 11:35 PM | #174 |
Rep 9,034
He may have had the early 9.5" like I have. You need a spacer if you have aftermarket coil over or for looks if you're on stock suspenstion. The new 9.5" will fit without spacers.
Edit: looks like he's running 10" square. It's optional for the spacers.
08-09-2011, 03:04 PM | #175 |
445
Rep 1,658
The spacers just make it flush, which is not a requirement for a track fitment. Flush puts you at risk of fender damage with wider tires, and car with lower ride heights.
08-09-2011, 05:39 PM | #176 | |
#thatsanicemovebro
202
Rep 3,920
Drives: E92 M3 LSB/Black 6MT
18x10, 18x10.5, apex, arc-8, wheel |
