For Help with NCSExpert Errors
06-30-2013, 11:19 AM | #133 | |
295
Rep 2,203
need some help with these errors.
Trying to test for Air bags in INPA I get a version maybe mismatched error. Hers A copy of the log in NCS errors that I saw just trying read out FA. Quote:
07-03-2013, 09:01 AM | #134 | |
Kind of a big deal
301
Rep 1,674
Drives: an 1M not often enough
Recent US cars with professional audio S663A have 2uRad module (u represents US version of the 2Rad). If brought to Europe, local dealers will have coding problems when the combination of options does not require the MOST bus. This is because some EU dealer software insists to connect to the MOST bus (even if it is not present). So my guess is in an attempt to get advance with the dealer diagnostic software they/the software 'retrofits' the RAD module in trail and error mode. Successful or not, the dealer has no means (NCSEXPERT) to remove such addition from the VO/FA later on. |
07-16-2013, 08:00 AM | #135 |
Rep 10
I found your post while trobleshooting a problem I am having trying to code the aux on a 2006 X3 e83, it is throwing an error when I try to write the .man file back to the car.
What is the version of NCS-Expert I should be using? I have CoapiV3.5.1B. Daten files are from 10/18/2010. Thanks for your help. |
07-16-2013, 08:22 AM | #136 | |
Rep 252
You need to install Standard Tools 2.12 and upadte with at least sp-daten 49. Give me your email, I will send you all you need. |
07-18-2013, 01:04 PM | #137 | |
335i Owner
58
Rep 839
Drives: BMW 335i 4 Door
Anyone? It was working at 2AM last night
E90 - 2007 BMW 335i Sedan
45K miles 7" VRSF FMIC | BMS DCI | AR Catless DPs | KW v2 Coilovers | M3 Front Control Arms |
07-20-2013, 01:14 PM | #138 |
Rep 10
I know I don't have an E90 but using NCS Expert I am getting an error when trying to turn on the aux on the radio.
updated ncs to v4.0.1 (2012), daten files to 46.3 (11/2012) here is the error when I try to write the code back to the car (all is good before that) 2060 PABD/CABD A_RA_NG.IPS Cod_SG_CODIEREN 58 Codierung fehlerhaft (allgemein) C_RADIO, C_C_AUFTRAG: ERROR_VERIFY 2060 Error COAPI2.CPP coapiRunCabd 6 Codierung fehlerhaft (allgemein) SG_CODIEREN |
09-30-2013, 02:00 AM | #139 |
Rep 3
hey guys, I updated my SP-Daten from v49 to v50.2 because at e91 chassis (2010) I didnt get an access to the ECUs like NFRM. (At e60 it works very fine)
So I updated it like this: Folder: Daten: execute laden.bat Folder: Copied the files of ECU: in C:/EDIABAS/ECU and overwrited it Folder: Copied the files of SGDAT: in C:/NCSEXPER/SGDAT and overwrited it When I choose e89 and try to get a connection to the car via CAS this error will pop up: "ERROR! Modul: LFCDHDIA.CPP (A_E65CAS.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000 COAPI-2000: Fehler in EDIABAS oder in SG-Beschreibungsdatei SYS-0005: SG-Beschreibungsdatei nicht gefunden" NCS expert version: 3.1.0 hope that someone can help me Last edited by drivebmw; 09-30-2013 at 03:40 AM.. |
10-29-2013, 09:11 PM | #140 |
Rep 675
2URAD Error Reading ECU
Can't read 2URAD module. All other modules coded correctly. SP Daten 50.2, NCSExper 4.0.1, Standard Tools 2.12. While coding job is active it gives me this info: RAD2.C03, A_E65MMI.IPO, RAD2.PRG. The car is X1 e84 September 2013, Professional Radio. I suspect it is something to do with the MOST communication and Pin 7/8.
Error.log [16:22:42.012] [2013-10-29] [SERIE] 2020 Error LFCDHDIA.CPP (A_E65MMI.IPS/IPO) CDHapiResultText 1 [16:22:42.012] [2013-10-29] [SERIE] SG antwortet nicht IFH-0009: SG nicht angeschlossen oder meldet sich nicht RAD2 [16:22:42.122] [2013-10-29] [SERIE] 2020 Error COAPI2.CPP coapiRunCabd 6 [16:22:42.122] [2013-10-29] [SERIE] SG antwortet nicht CODIERDATEN_LESEN |
11-28-2013, 09:48 AM | #142 |
9
Rep 26
PROFILES NCSexpert v.4.0.1
Can anybody send me some profiles for my newly installed NCSExpert v401... which i believe its the latest one. After I installed I only got one profile, and NO EXPERTMODE/REVTOR
VMR - BC Coilovers - aFe - M Performance - CODED
12-08-2013, 08:52 AM | #143 |
9
Rep 25
HI trying to write nfrm, kombi, dsc and a couple other ecus Im getting coapi 2000 error
ive updated sp daten files to V51 by using laden.bat and tried using bmw coding tool program to do it for me ncs dummy will not read the trc files correctly on in bmw coding tool I can read then try and write get the coapi error do I need older spdaten files to read the other modules thanks ERROR! Modul: LFCDHDIA.CPP (A_DMOT.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000 COAPI-2000: Fehler in EDIABAS oder in SG-Beschreibungsdatei BIP-0009: Faulty BEST version of description file >> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2000 CODIERINDEX_LESEN >> ERROR! Modul: COAPI.CPP, Proc: coapiReadCodierIndexFromSg, LineNr: 05, ErrorNr: 2000 CODIERINDEX_LESEN: A_DMOT >> ERROR! Modul: LFCDHDIA.CPP (A_DMOT.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000 BIP-0009: Faulty BEST version of description file >> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2000 CODIERDATEN_LESEN ERROR! Modul: LFCDHDIA.CPP (A_DMOT.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000 COAPI-2000: Fehler in EDIABAS oder in SG-Beschreibungsdatei BIP-0009: Faulty BEST version of description file >> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2000 CODIERINDEX_LESEN >> ERROR! Modul: COAPI.CPP, Proc: coapiReadCodierIndexFromSg, LineNr: 05, ErrorNr: 2000 CODIERINDEX_LESEN: A_DMOT >> ERROR! Modul: LFCDHDIA.CPP (A_DMOT.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000 BIP-0009: Faulty BEST version of description file >> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2000 CODIERDATEN_LESEN ERROR! Modul: LFCDHDIA.CPP (A_PL2KMB.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000 COAPI-2000: Fehler in EDIABAS oder in SG-Beschreibungsdatei BIP-0009: Faulty BEST version of description file >> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2000 CODIERINDEX_LESEN |
12-09-2013, 05:23 PM | #144 |
Rep 25
Ok guys Im at the point of doing the digital speedometer and when I open up my FSW PSW file to find "BC_Digital_V" its not there....
This is what is in my FSW PSW file. BAUREIHE e90 BAUART limousine MOTOR_ART benzin_normal TYP_LENKUNG linkslenker ZYLINDER_ZAHL 6_zylinder GETRIEBE_GAENGE 6_gaenge KLASSE_BATTERIE 90ah STROM_RUHE wert_01 STROM_KS_MIN wert_01 STROM_KS_MAX wert_01 STARTABBRUCH_BREMSE aktiv KOMFORTSTART aktiv KOMFORT_EIN aktiv ERROR_EJECT nicht_aktiv ZEIT_BREMSE wert_02 BREMSE_DRUCK wert_01 KOMFORT_AUS_IN_50MS wert_03 KLR_AUS_TIMEOUT wert_03 KL30G_TIMEOUT wert_01 SICHERHEITSFAHRZEUG nicht_aktiv HECKSCHEI_ENTR_OHNE_NR nicht_aktiv HECKSCHEIBE_ENTR_SENDER_1 nicht_aktiv HECKSCHEIBE_ENTR_SENDER_2 nicht_aktiv HECKSCHEIBE_ENTR_SENDER_3 nicht_aktiv HECKSCHEIBE_ENTR_SENDER_4 nicht_aktiv TOEHK_EO_HS_OHNE_NR nicht_aktiv TOEHK_EO_HS_SCHL_NR01 nicht_aktiv TOEHK_EO_HS_SCHL_NR02 nicht_aktiv TOEHK_EO_HS_SCHL_NR03 nicht_aktiv TOEHK_EO_HS_SCHL_NR04 nicht_aktiv HKAT_EO_HS_OHNE_NR nicht_aktiv HKAT_EO_HS_SCHL_NR01 nicht_aktiv HKAT_EO_HS_SCHL_NR02 nicht_aktiv HKAT_EO_HS_SCHL_NR03 nicht_aktiv HKAT_EO_HS_SCHL_NR04 nicht_aktiv FH_KINDERSICHERUNG aktiv ZV_DISFERTMODE nicht_aktiv ZV_DISTRANSMODE aktiv ZV_DISWERKSTMODE nicht_aktiv CLT_TASTE aktiv SPERRE_CRASH_ER aktiv VR_KLR nicht_aktiv VR_KLR_EINMALIG nicht_aktiv VR_GESCHW_EINMALIG aktiv SPERRE_HECKKLAPPE_KLR nicht_aktiv ER_TANKKLAPPE_SER aktiv ER_TANKKLAPPE_VR aktiv ER_KEYOUT_AUTOVR nicht_aktiv ENABLE_CLT_NACH_CRASH nicht_aktiv ZV_AUTHENTISIERUNG nicht_aktiv CCM_SEND_INVALID nicht_aktiv CRASH_SCHWERE wert_02 CRASH_BESCHLEUNIGUNG wert_01 VERRIEGELUNGSSCHWELLE wert_04 GESCHW_SPERRE_TOEHK wert_01 ZEIT_AUTO_ZV_VR wert_01 VER_AUT_X_MIN_OHNE_NR nicht_aktiv VER_AUT_X_MIN_SENDER_1 aktiv VER_AUT_X_MIN_SENDER_2 aktiv VER_AUT_X_MIN_SENDER_3 nicht_aktiv VER_AUT_X_MIN_SENDER_4 nicht_aktiv VERRIEGEL_XKM/H_OHNE_NR nicht_aktiv VERRIEGELN_XKM/H_SENDER_1 nicht_aktiv VERRIEGELN_XKM/H_SENDER_2 nicht_aktiv VERRIEGELN_XKM/H_SENDER_3 nicht_aktiv VERRIEGELN_XKM/H_SENDER_4 nicht_aktiv FH_ECEFIN nicht_aktiv FH_ABSCHALTKRITERIUM aktiv FH_USACANADA nicht_aktiv FH_DISAKL15 nicht_aktiv FH_DISAKLR nicht_aktiv KOMFORTOEFFNUNG_FB aktiv KOMFORTOEFFNUNG aktiv KOMFORTSCHLIESSUNG aktiv FH_RESETTIMEOUTKL50 aktiv FH_TUERBED_EINSTG nicht_aktiv FH_SCHLIESSEN_EINSTG nicht_aktiv FH_DISTGDEFECT aktiv FH_KMFRTFBDTIM aktiv FH_DISCLSYDEFECT aktiv FH_DISFBDDEFCT aktiv FH_DISFERTMODE aktiv FH_DISTRANSMODE aktiv FH_DISWERKSTMODE aktiv KMFRT_OEFF_HINTEN wert_01 KMFRT_OEFF_SHD wert_01 KMFRT_SCHL_VORNE wert_01 KOMFORT_SCHL_SHD wert_01 ANSTEUERZEIT wert_01 KMFRT_OEFFNEN wert_01 KMFRT_SCHLIESSEN wert_01 MIND_KMFRT_NACH_UNTERB wert_01 MAX_KMFRT_UNTERB wert_01 MAX_KMFRT_UNTERB_FBD wert_01 SLEEPTIMER_FH_KLRAUS wert_01 PERSONALISIERUNG_AUS nicht_aktiv SONDERTASTE_INNENLICHT nicht_aktiv FBD_AKTIV_KL15AUS nicht_aktiv FBD_AKTIV_KEYIN aktiv FBD_TESTKEY_AKTIV nicht_aktiv FBD_HECKKLAPPE_TOTZEIT wert_02 FBD_PANIK_TOTZEIT wert_01 FBD_MOTORLAUF wert_01 FBD_MOTORSTART wert_01 FBD_PANIKDAUER wert_01 FBDIN_9_6_KBAUD aktiv MFS_KEY_PLGD nicht_aktiv FBD_DISFERTMODE nicht_aktiv FBD_DISTRANSMODE nicht_aktiv FBD_DISWERKSTMODE nicht_aktiv PA_CONFIG_FBDREFCHECK nicht_aktiv PA_TVRERFATH wert_01 PA_TSPERRVR wert_01 PA_TBEREITPE wert_01 PA_ID_GEBER wert_01 PA_FBD_REF wert_01 PA_TBEREIT_PG wert_01 CHIPCARD aktiv BOS_DATEN_ANFRAGEN aktiv FS_DATEN_ANFRAGEN aktiv SQCNT_UPDATE nicht_aktiv BEDINGUNG_CC_10KM aktiv EE_ZEIT_NLF wert_01 EE_ZEIT_ABFR wert_01 GESCHW_REQ_CC wert_01 EWS_NACHLAUF_KLR_AUS nicht_aktiv EWS_FEHLER_MOTORLAUF aktiv EWS_SCHRITTWEITE_2 nicht_aktiv MOTOR_HUBRAUM n51b30 n52b30 n52kb30 n53b30 n54b30 m54b30 m57d30 n57d30 n62b30 LAENDERVARIANTE_BNDB us GETRIEBE_TYP schrittschaltung ANLASSSPERRE_BLS aktiv ES_EINMALIG_CLT aktiv SCHAERFEN/ENTSCHAERFEN schloss_und_fernbedienung CAN_MEHRFACH_SICHERN aktiv MOTORHAUBENKONTAKT nicht_aktiv ZV_SELEKTIV aktiv SEL_ZV_SENDER_1 nicht_aktiv SEL_ZV_SENDER_2 nicht_aktiv SEL_ZV_SENDER_3 aktiv SEL_ZV_SENDER_4 aktiv FH_SICHERHEITSFAHRZEUG nicht_aktiv FH_CABRIO_VERDECK_MODUL nicht_aktiv FH_HINTEN aktiv SCHIEBEHEBEDACH aktiv FH_DISASHD_KL15 nicht_aktiv KOMFORTSCHLIESSUNG_FB nicht_aktiv KOMFORTSCHLIESSUNG_PA nicht_aktiv EINSTIEGSHILFE_OHNE_NR nicht_aktiv EINSTIEGSHILFE_SENDER_1 nicht_aktiv EINSTIEGSHILFE_SENDER_2 nicht_aktiv EINSTIEGSHILFE_SENDER_3 nicht_aktiv EINSTIEGSHILFE_SENDER_4 nicht_aktiv SONDERTASTE_PANIKALARM nicht_aktiv MOTORFERNSTART_GENERELL nicht_aktiv MOTORFERNSTART_CAN nicht_aktiv FBD_HSF_0 wert_09 FBD_HSF_1 wert_09 PASSIVE_ACCESS nicht_aktiv AUSWERTUNG_B_DRUCK nicht_aktiv AUSWERTUNG_P_CAN aktiv KLSTRG_DISFERTMODE nicht_aktiv KLSTRG_DISTRANSMODE nicht_aktiv KLSTRG_DISWERKSTMODE nicht_aktiv MFS_MIT_TON nicht_aktiv STARTDELAY_K_START nicht_aktiv EE_TRSP_CCM_0CD aktiv EE_TRSP_PERM aktiv FBD_SERVICEFKT_AKTIV aktiv DELAY_KL50L wert_03 HK_ENABLE_OPEN aktiv ANLASSERSPERRE_KPS nicht_aktiv EE_TRSP_DEBUG nicht_aktiv KLSTRG_TESTER nicht_aktiv KOMFORT_EJECT nicht_aktiv PA_CHIPCARD_ACTIVE aktiv PA_DISABLE_HK_REV nicht_aktiv PA_HK_BACK_IR_SEARCH nicht_aktiv PA_HK_INTERIOR_SEARCH nicht_aktiv PA_HK_PGS_SEARCH nicht_aktiv PA_HK_REOPEN_CTL_DEP aktiv PA_HK_REOPEN_CTR_LOCK nicht_aktiv PA_HK_RSCR_ACTIVE nicht_aktiv PA_SILENTTIMEOUT wert_01 ANLASSERSPERRE_P aktiv AUSWERTUNG_P_HW aktiv CLASS_PWR klasse_1 DELAY_KLR_AUS wert_02 STARTABBRUCH_P aktiv KLR_EIN_GESCHW aktiv ANLASSERSCHUTZ_3SEK aktiv SPERRE_KLRAUS_SST nicht_aktiv EINSTIEGSHILFE_DEFAULT nicht_aktiv EINSTIEGSHILFE_PORT nicht_aktiv PA_HK_REOPEN_INDICATE aktiv PA_HK_REV_ZYKL aktiv PA_MONITOR_ACTIVE nicht_aktiv RSSI_THRESHOLD wert_02 SEL_ZV_SENDER_DEFAULT aktiv SEL_ZV_SENDER_PORT aktiv STARTWUNSCH_KL50 aktiv VER_AUT_X_MIN_DEFAULT nicht_aktiv VER_AUT_X_MIN_PORT nicht_aktiv VERRIEGELN_XKM/H_DEFAULT nicht_aktiv VERRIEGELN_XKM/H_PORT nicht_aktiv TEST_DUTY_CYCLE aktiv FBD_HKL_NUR_ER nicht_aktiv PA_HA_SEARCH_ACTIVE nicht_aktiv KL15HW01_ALLWAYS aktiv PA_TRUNK_HIGH aktiv SENDMHKCCMLIMIT wert_01 HS_ENABLE_OPEN nicht_aktiv HKL_LIFT_BEI_CA nicht_aktiv FHM_CA_OHNE_EKS nicht_aktiv FHM_CA_OHNE_EKS_DELAY wert_01 HK_GESPERRT_IN_GESICHERT nicht_aktiv AUT_OFFNEN_HK_IN_ENTLPOS nicht_aktiv EWS_EGS nicht_aktiv CBS_VERSION wert_03 KL30G_NACHLAUF_NACH_SZ1 wert_01 SCHLUESSELVARIANTE wert_03 FH_KOMFORTF_MIT_SUBST nicht_aktiv ZEIT_KL50_ANSTRG wert_03 ABZUGSPERRE_PLOCK_C6 aktiv FBD_LOAD_POS_HK_HK nicht_aktiv FBD_LOAD_POS_LF_PING nicht_aktiv FBD_NO_LOAD_POS aktiv FH_RELEASE_CA_BASIC nicht_aktiv KL30G_EIN_HKT_AUSSEN_07 nicht_aktiv KL30G_EIN_HKT_FBD_07 nicht_aktiv KLR_AUS_TK aktiv KLSTRG_GRB_ID wert_01 SPERRE_HKL_KEY_VALID_07 aktiv SS_GETRIEBE_7 nicht_aktiv STARTABBRUCH_KLR nicht_aktiv STARTDELAY_K_START_R5X nicht_aktiv TC_KL15_AUTO_OFF aktiv TC_KL15_AUTO_OFF_LIGHT aktiv TC_MSA_NO_KL15_AUTO_OFF nicht_aktiv TC_TIME_KL15_AUTO_OFF wert_00 FBD_COMFORT_OPEN_LF_PING nicht_aktiv PA_TBEREIT_HK wert_01 CCM_0X42_IM_NACHLAUF nicht_aktiv NLF_AUS_ALLE_TUEREN nicht_aktiv NEUES_FSE_KONZEPT nicht_aktiv PA_SUPERRANGE_R56 nicht_aktiv PA_TAGE_REAR_RL_MIRROW nicht_aktiv PA_LF_PING_TAGE nicht_aktiv PA_MAUT_CLOSE_SILENT nicht_aktiv PA_SEARCH_HK_VORRASTE nicht_aktiv PA_SILENT_TO_4TAGE nicht_aktiv ELV_AUT_FCT aktiv ELV_RESET_FCT aktiv FH_RELEASE_TOP_ZWSTLG nicht_aktiv PA_HK_2SEARCH aktiv ELV_CCM_NEU aktiv PA_LF_PING_PGS nicht_aktiv HINTERE_TUEREN_MINI nicht_aktiv OSFG_MSA_NO_KL15_AUTO_OFF aktiv TC_KL15_AUTO_OFF_OSFG nicht_aktiv TC_NOT_P_NO_KL15_AUTO_OFF aktiv TIME_KL15_AUT_OFF_DR_OPEN wert_01 HK_V_VER_MODUS modus_00 TC_MSA_IGNORE_ENG_RUN nicht_aktiv |
12-26-2013, 11:10 AM | #145 |
Rep 801
ok I've been at this post for hours without trying to post for help,
I have a 2011 335is, Running 32 bit Windows XP I have a K+DCAN INPA Compatible cable (opened it up and it has 8 pins) I have downloaded all the original links from the OP (running INPA version 5.0.1, EDIABAS 6.4.7, and NCSEXPER 3.1.0) when i run INPA both circles are black, but when i try to communicate with the airbag i get an error...heard you could still code so i went ahead and followed the diy and got to the vin part and got this error: VIN is faulty COAPI-2000: EDIABAS or SGBD error IFH-0003: DATATRANSMISSION TO INTERFACE DISTRUBED I changed the latency to 1 and still nothing someone please help I've been at this for hours |
02-03-2014, 01:34 PM | #148 |
23
Rep 321
02-06-2014, 08:58 PM | #149 |
23
Rep 321
So Im trying to recode an adaptive headlight module to my car to replace a shorted one. I cannot for the life of me get the coding to take. Every time I get the following errors:
I can read the VIN, ECU's, everything fine. I click execute job and it goes to coding active, then just errors out with coding is faulty. Ive tried two different cables. Two different laptops. Same results on other modules as well. Tried various profiles. If anyone can please help me get this module coded I would be GREATLY appreciative [20:29:57.468] [2014-02-06] [SERIE] 2020 PABD/CABD A_SMCKWR.IPS CodIndex2Lesen 495 [20:29:57.468] [2014-02-06] [SERIE] ECU does not answer FRM_87, ID_SMC_LESEN: ERROR_ECU_BUSY_REPEAT_REQUEST [20:29:57.562] [2014-02-06] [SERIE] 2020 Error COAPI2.CPP coapiRunCabd 6 [20:29:57.562] [2014-02-06] [SERIE] ECU does not answer CODIERINDEX_LESEN ================================================== ==============================(2) [20:30:29.812] [2014-02-06] [SERIE] 2020 PABD/CABD A_SMCKWR.IPS CodIndex2Lesen 495 [20:30:29.812] [2014-02-06] [SERIE] ECU does not answer FRM_87, ID_SMC_LESEN: ERROR_ECU_BUSY_REPEAT_REQUEST [20:30:29.921] [2014-02-06] [SERIE] 2020 Error COAPI2.CPP coapiRunCabd 6 [20:30:29.921] [2014-02-06] [SERIE] ECU does not answer CODIERDATEN_LESEN |
02-16-2014, 10:35 AM | #153 |
dee*****13
Rep 13
current Revtor profile and latest daten for 2011 e90
ive been looking all weekend for these files. i have tools 2.1 with everything installed and working on win 7 32bit. want to try to code a few things before road trip tomorrow... anybody want to share the latest Revtor profile and daten file???? PLEASE!!! im runnung out of time.....
04-04-2014, 07:50 AM | #154 |
Rep 3,996
Hoping someone can help.
I was able to successfully code my 08 M3, M3DSC, KOMBI, CAS, FRM, etc. This was with NCS 3.0.1 with updated EDIABAS (forgot version). 50.2 Daten Files Tried to code a friend's 09 335i and got this error: I was able to read CAS, KOMBI, etc, but couldn't write/code it after making changes. I got the error (see screenshot COAPI-2063 error) Did some research, thought I needed to fully upgrade to BMW tools 2.12 and NCS 4.0.1, so I did that, loaded new profiles, make sure daten files were updated to 50.2. Same error... Any ideas? I didn't view the error log at the time thinking it would be saved, but tried to view it now and now its gone. Can anyone help without the error log? or is it needed? I'd have to get my friend to come over again and try it once more. 32-bit Windows XP Laptop, clean install, nothing else on it. BMW Coding Tool used to update daten files.
