      12-11-2012, 02:05 AM   #23
DrGadget
DrGadget's Avatar
Australia
46
Drives: M140i F20 LCI-2
2018 BMW M140i  [0.00]
Front and rear Turn Signal LEDs
@Qube: Thank you for the guide. I'd like to offer what I think is a correction to Front and Rear Turn Signal Bulbs. You show them as 1157 Base: BAU15D.
Having replaced mine with LEDs I can confirm that (for my model at least), these are 1156 Base: BAU15S. Yes, the pins are 150 degrees and not 180 degrees, i.e., not opposite each other.
I can confirm that the brake lights have bayonets (pins) that are opposite each other.
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016.
Sold: Alpine White 123d e82, 2010, 150kW/204hp.
      12-11-2012, 02:10 AM   #24
DrGadget
DrGadget's Avatar
Australia
46
Originally Posted by Papa13 View Post
Why has no one whited out their blinkers if it's just a normal bulb?
Or if someone has Post pics please!!
One moving picture coming up for stealth LED turn signal bulbs coming up.
      07-11-2017, 08:04 PM   #25
Tallicia
Tallicia's Avatar
Drives: X6 and 1 series
2013 X6  [0.00]
2011 BMW 135i M Spo ...  [0.00]
Has anyone found a LED map light replacement that works, preferablyh 6000k? Every bulb I try will shut off after 5 - 10 seconds, and then might work again when it resets after a few minutes.
      11-05-2018, 09:54 AM   #26
teaberry
Drives: 2012 135i M Sport Convert 6spd
Sorry I'm still not clear on what the top "eyebrow" lights are on the 135i called, what type of bulb or how to change them. Thank you.
      12-20-2020, 05:32 PM   #27
BMWCCA1
BMW Owner Since 1971
2258
Drives: 1964 700 Sport Cabriolet
2013 BMW 128i  [10.00]
My Check Control warning for "R. Brake Light" bulb came on this morning. When I looked inside with the brakes on, it looked as if there were three bulbs not working compared to the Left side. I pulled the board with four bulbs out just to see inside and then found the socket outside that cluster in the hole in the body with a burned-out "1156" bulb. I never was able to locate access to the two other bulbs that were not lit.
I checked my spares and found several "7506" bulbs which had the same base and installed one which worked. Then I Googled "1156 vs 7506" and found sources saying they are different but can substitute for one another as long as they have the chrome base.
Oddly, after replacing the one bulb, all three were working again and the warning-triangle gave up warning me. I'll get the correct 1156 bulb at work tomorrow but at least I no longer have to have my info screen blocked by the dreaded yellow triangle!
Is there some series circuit which causes the seemingly inaccessible bulbs to go out with the 1156?
      03-06-2021, 09:28 PM   #28
MAMSport
MAMSport's Avatar
93
Drives: '13 128i M-Sport coupe
Has anyone substituted W16W LED bulbs for the standard W16W bulbs? I'm not sure what is in my '13 128i with halogen headlights, but I wouldn't mind extra lighting on dark driveways when trying to back up.
Will using the LED versions cause issues with the 'bulb out warning' system?
Thank you!
E9x M3 front & rear suspension arms; BMW Performance brakes upgraded to drilled rotors in rear; BMW performance shifter; BMW Performance Exhaust; Wave Trac LSD with modified 'nannies'; BMW Euro Intake box; BMW Aluminum Strut Tower bar; ECS front and rear sway bars; 3 stage intake with BPC software; BMW style 78, 17 x 8" wheels with Bridgestone RE 980AS 225/45-17 tires; Koni Special Active struts/shocks, E9x M3 RTABs.
      12-24-2021, 05:46 PM   #29
MajorBob
18
Drives: 2012 e88 135i, 2008 e60 M5
The high beams on my 2012 135i (with Xenon) are H8. This is also what RealOEM confirms they should be. For the 3 year old question from teaberry, that is an H3 bulb and to access it you remove a small rectangulare cover on the top.
      01-20-2022, 02:49 PM   #30
Fishee
Fishee's Avatar
1003
Drives: 135i MSport
Anyone ever change their D1S HID bulbs?
Looking to refresh my headlights, including the xenon bulbs.
Did you go with Sylvania? Osram? Something different?
Thx!
      10-15-2022, 02:52 PM   #31
blizzbone
Drives: BMW 128i
Did you happen to figure this out? 1 of mine are acting up and would like to replace the bulb.
Thanks
