BMW M3 Forum (E90 E92)
  TireRack
      09-19-2009, 12:00 AM   #89
signes
signes's Avatar
Drives: 991 GT3 RS
Originally Posted by Mean_M3 View Post
Hi Ben - Does all around 245/45/18 works well on the OEM 18" gun metal rims even if they are wider or do I need to get new rims if I am running that setup? Just planning to get the tires and not another set of rims that I have to store once winter is over. thanks!
Do you mean 245/40? If so, that is what I run all around on my OEM 18s. Pretty stretched in the back but I like the square setup for being able o rotate for wear. The other option would be to get another set of OEM 18 fronts and mount those on the rear with spacers.
      09-20-2009, 09:11 AM   #90
Mean_M3
Drives: 2009 E92 coupe
Hey, sorry, my mistake..245/40 yes....ok that is good. I am not willing to spend more money on a winter set up than what I have to....so thanks for that info, I will go ahead and get the tires......appreciate your help...
      10-09-2009, 07:02 PM   #91
warzilla
warzilla's Avatar
148
Drives: E46 M3, f31 330, f31 328d
This is a unique set up, but for my winter set-up I want to do the following:
Wheels: VMR V710 18x9.5 square set up.
Tires: 255/40/18 Blizzard LM-25
No spacers (don't want to do spacers). I am doing a non-staggered set up cause I heard the V710 18x8.5 do go in a bit on the M3 up front, so I would either have to do spacers in front or go up to 18x9.5.
Thoughts on this setup? Will it work?
2006 M3 ZHP in IB (Crashed) | 2005 M3 ZHP in IB (Sold)
2004 M3 in IR - Current
2018 330ix Wagon - Current
2017 328d Wagon - Current
      10-13-2009, 08:20 AM   #92
ben@tirerack
M3Post Supporting Vendor
87
Drives: 740i
255/40R18 is fine all around. A little wide in front for deep snow, but definitely workable. The 9.5 will be a tight fit up front, but if you can get it to fit that should be a workable setup.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions.
      10-13-2009, 08:48 AM   #93
Robo Squirrel
Robo Squirrel's Avatar
Drives: 991.2 GT3
would it be possible to get 245s or 235s for both front and rear...and just stretch the rears a little bit? i have the OEM 19"s btw...
      10-13-2009, 04:37 PM   #94
Subw00er
Bates '08 Interlagos Launch
Subw00er's Avatar
Drives: 440i xGC, ZL1, JCW
What rim width is ideal for a 245/40-18 tire? My plan is a square setup with repo M6 wheels and these PA3 tire sizes. I'm not sure which rim to choose.
Custom Exhaust Project: Bates Valvetronic exhaust: http://www.m3post.com/forums/showthread.php?t=253661 -- Exhaust Mod pics in here: http://www.flickr.com/photos/40236795@N03/
DON'T BUY Race Ready Performance electronic cutout valves. Here's why: http://www.m3post.com/forums/showthr...40#post9589740
      10-13-2009, 11:51 PM   #95
Projectile
Projectile's Avatar
28
Drives: 2017 M3
BMW recommends 235/40/18 all around (square setup) for 2010 (as they apparently did in 2009).
Everybody else, including Tire Rack, seems to recommend avoiding this (255/40/18 in the back).
What gives?
Does Tire Rack also provide the square setup that BMW recommends (even though I can't find it on the website.)?
Gone but not forgotten: 996Targa6MT, 997C2S6MT, e92DCT, e926MT, F826MT
      10-14-2009, 06:01 PM   #96
Yellowlab
Drives: 2021X7M50-Loaded-arriving soon
What to do?
Ben,
I bought a M3 this summer with the 18"OEM wheels. I had a 535i with the sports package before and was using the Dunlop sport 3D 245/40/R18 XL on4 wheels that I can no longer use, however the tires are in great shape.
So my options are:
Buy 4 A7 wheels with the TPS...but I don't like the fit in the back
Buy 2 rear tires 255/40/R18 Dunlop 3D Winter sport and fit them on the 18"OEM wheels.
Just keep the 4 winter tires that I have and put them on the OEM wheels, I think that they would fit on the 9.5" rear wheels, however it's pretty stretched...
Or just try to sell the 4 tires...won't get much fot it and buy the 4 pirelli's...
      10-15-2009, 05:14 PM   #97
ben@tirerack
87
Drives: 740i
To answer the questions above:
Yes, the square setup is fine. I often recommend it for those who need the best snow/ice traction. 235/40R18 or 245/40R18 are best for maximum winter traction. 255/40R18 can work all around too. To buy a square setup, just buy four of the "front" size and none of the rear. You sacrifice aggressive looks and the ability to put the power down more aggressively on dry pavement for better snow traction and more simplicity (no need to limit to matching front/rear pairs).
245/40R18 fits a 9.5" wheel. That is the widest it is recommended for, so it will look a bit stretched, but not horribly so. The recommended range is 8"-9.5". So "ideal" would be 8.5", with 9" a close second. (8.5" is the width they put it on to measure all the specs like width and total diameter etc).
235/40's actually have the same width range, so the above applies to it as well, although I would not want to put 235/40 on 9.5" width if I could help it.
      10-16-2009, 03:31 PM   #98
bryanr
bryanr's Avatar
14
Drives: 2008 e92 M3
What would you say to 245/45/18 fronts and 255/45/18 rears on OEM e92 18" wheels? Will the 45 vs 40 height make it a no-go?
      10-17-2009, 12:43 AM   #99
eddiek
Drives: '15 F83 DCT '09 E93 DCT
I have a couple of questions. The first is a really basic question, but would there be any significant change in the rolling radius in going from the OEM 19 to the recommended 18" winter tire/wheel combo? 2nd, I have the 19" wheels which I need to get winter tires. There is mostly rain in the Pacific NW but the occasional snow where it is hilly. Are the Michelins that much better than the Blizzaks or Dunlops? Thanks.
      10-21-2009, 01:08 PM   #100
ben@tirerack
87
Drives: 740i
OEM 19" and OEM 18" are the same diameter, so this will apply equal to either.
OEM Front Diameter 25.7"
OEM Rear Diameter 26.3"
BMW Alternate winter size 235/40R18 diameter 25.4"
Just for good measure, going up one width front and rear, 255 front and 275 rear with the OE aspect ratio (40 for the 18" and 35 for the 19") makes very slightly taller diameter:
255/40R18 and 255/35R19 are 26" diameter
275/40R18 and 275/35R19 are 26.5" diameter
Keep in mind that like shoes or pants, tires can run a little big or small by a tenth of an inch or two, so these numbers are approximate.
      10-21-2009, 01:10 PM   #101
ben@tirerack
87
Drives: 740i
I would not go up to the 45 aspect ratio. Rolling diameter will be tall by about an inch, rather than just small fractions of an inch with some of the other alternate sizes.
      10-22-2009, 11:59 AM   #102
jamesq
Drives: 2015 SO M3 6 Spd
Any comments on a 255/40 rear 225/45 front set up for snow on original 18 inch rims for a 2009 M3?
      10-22-2009, 12:44 PM   #103
bryanr
bryanr's Avatar
14
Drives: 2008 e92 M3
Good point, I wasn't thinking about how the aspect ratio is being applied to a wider tire.
That said, would an extra inch of diameter be that bad for the winter? Would the extra 1/2" on each edge cause any clipping? The clearance and extra cushion might be nice for the Boston winter.
Thanks!
      10-27-2009, 04:14 PM   #104
bunnn
bunnn's Avatar
86
Drives: like a grandma
Hey Ben,
I just picked up some 18x8.5f/18x9r on Hankooks W300 ...running 235/40/18 front and 245/40/18 rear...any issues with this set up? only worry is that they are going to effectively change my rolling diameter...but from what I read here, i'm thinkign it's fine..just wanted some confirmation.
Thanks!
Cheers
Ben
      10-27-2009, 04:30 PM   #105
bobbyd1961
Drives: 2009 M3 sedan LeMans Blue
I HAVE THOSE RIMS WITH MICHELIN SNOWS 3 MONTHS ON THEM ONLY. they were 17s for my 335. 600 for 4 wheels with snows
      10-28-2009, 09:33 AM   #106
ben@tirerack
87
Drives: 740i
Originally Posted by bunnn View Post
Hey Ben,
Thanks!
Should be fine. It falls between a square setup with all the same, and a normal stagger setup with 2 widths wider in the back, so it is within the range of normal setups.
      10-28-2009, 09:35 AM   #107
ben@tirerack
87
Drives: 740i
Thanks!
The way the wheel well is set up, height does tend to be more of an issue than width for rubbing. It is tighter than I would want to go for a winter setup. Even if it doesn't rub, it would make you more prone to getting ice/snow chunks wedged up in between the tire and fender and getting rubbing on the snowpack.
      10-28-2009, 10:17 AM   #108
ben@tirerack
87
Drives: 740i
Rear is very common to use 255/40R18 on OE 18's. The 225/45R18 recommended to fit a maximum of 8.5 wide wheel. So they'll look a little bit stretched up front, though nothing unsafe. You will have = height front and rear with that setup.
      10-28-2009, 10:46 AM   #109
03SG///M3
Drives: 328
I understand going with 18/8.0 all around will not look as good as the staggered setup but will it be much better in the snow/ice? In other words, is it worth it to sacrifice looks for snow/ice performance? I was going to place my order for the recommended staggered setup through tirerack although now i am considering going with a square setup for more traction.
      11-07-2009, 07:00 AM   #110
rcornelius
Faster
rcornelius's Avatar
Germany
Drives: M3 Coupe Melbourne Red/Black
Originally Posted by rcornelius View Post
I've purchased these rims and the Dunlop Sports for my M3. As always Tire Rack came through and I had the tires in about 5 days, yes all the way to Germany. Tires look fine and should be ok in the snow. I've used Dunlop Sports for many years on all of my other BMWs with no issues.
UPDATE::: I've had this winter package on my M3 going on two years. Absolutely NO problems in the snow. And I work in Germany and often in the early mornings I have to travel roads that have not been plowed. Mr M3 and the Dunlops handle the snow with no problems. I preferr Dunlops over the Brigstone Blizzaks. The Dunlops seem to be better in rain as well as dry roads. I believe the Blizzaks may have a slight advantage in snow, but not enough to really make a big difference.
m3post
