10-09-2020, 01:46 AM | #1 |
Rep 1
Upgrading headunit
I have a 2014 328i with the basic screen (6.5in). I found someone who totaled their 2014 BMW 328i. They are selling the screen with navigation, headunit and control knob. Would I be able to upgrade my car and is it worth it? Or am I better of upgrading just the screen and getting a software with AppleCar play?
Thank you in advance |
10-11-2020, 12:24 PM | #2 |
Rep 833
Drives: BMW F36, E36, E93
Did you check his videos?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
10-11-2020, 05:16 PM | #3 | |
Rep 500
1) there are many diy videos 2) those videos make things seem easier 3) coding is required I don't know if the unit will work but as long as you can deal with these things, good luck! |
10-12-2020, 09:41 PM | #7 |
127
Rep 339
Almost anything is POSSIBLE, depending on how deep your pockets are... However not without a some issues...Does your car have connected drive might need a combox too. Some issues with coding (small) but still issues. If your car didn't come with NAV, you will need a separate GPS antenna and also a wifi one, depending on the year. Head unit has to be coded to your VIN...(can't use small programs like "Bimmercode" to do it either....I could be wrong on that...need to do a search.) But it CAN be done with computer programs. Might need a new harness, cable for USB in glovebox ect. If your car is HK or his was, either case speakers and amp might be also needed. Not really sure its worth the trouble, but it might be to you. You could always go apple carplay/androidauto box, a larger 8.8 factory screen and switch to the larger idrive button for cheaper and less hassle. The screen and the larger idrive button from a junkyard/crashed 3 series, but depending on your car, certain part numbers you can use, not others (screen can be coded with "Bimmer code" button is a straight swap depending on the year of your car... but carplay/androidauto box also have their little issues, but if you are not OCD, they shouldn't bother you too much. Unless of course you are getting a killer deal on the NBT EVO unit...
10-12-2020, 09:49 PM | #9 | |
Rep 111
C$ 336.66 42% Off | Carlinkit Carplay Wireless Decoder For BMW F01 F10 F12 F15 F16 F20 F22 F25 F26 F30 NBT System Android Auto/Mirrorlink/Airplay https://a.aliexpress.com/_mOdszM3 |
02-10-2022, 08:07 AM | #10 |
Rep 1
Head Unit replacement
02-11-2022, 05:37 PM | #11 | |
Rep 4,877
If it's an Android screen replacement, then you flip to the OEM, and it works like OEM, and then back to the Android side for the other apps like Android Auto and Carplay (Carplay is available on newer NBT versions). |
Tsaoster14.50 |
02-12-2022, 03:58 AM | #12 |
¯\_(ツ)_/¯
945
Rep 1,762
I bought an Eonon unit 2 years ago to replace my 6.5" display. I'm not that happy with it. I completely lost the stock function to disable my angel eyes.
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
02-12-2022, 04:44 PM | #13 |
Rep 4,877
How so? Looking at their site it looks like they just sell those Chinese Android head units. I have one from Aliexpress, and you can toggle back to iDrive with the console buttons. Other than my car being old enough that audio needs to come through the aux input with it, looks/feels/smells OEM at that point. OEM used the digital input.
02-13-2022, 04:31 AM | #14 | |
¯\_(ツ)_/¯
945
Rep 1,762
02-13-2022, 05:50 PM | #16 | |
Rep 9
Pros: system moves quick, full screen wired AND wireless apple carplay, nice and bright, really good touch screen although i only use idrive controller Cons: microphone is terrible as it is built in and you will have to explain this to all of your friends who are complaining about not hearing you properly; it does lower the audio quality by a bit but it's almost unpercievable after getting the built in equalizer settings right |
02-14-2022, 04:46 AM | #17 |
¯\_(ツ)_/¯
945
Rep 1,762
To make the car less noticeable and for other reasons for night driving.
02-14-2022, 06:13 AM | #18 | |
Rep 595
For the microphone issue go into the settings on the android screen and disable the change it to use the cars bluetooth instead of the android. It then uses the original car equipment for calls |
02-14-2022, 07:28 AM | #19 | ||
Rep 9
02-16-2022, 05:33 PM | #21 | |
Rep 4,877
Catch22 is you can no longer use wireless AA/wireless carplay after doing this since it needs to run through the android bluetooth module to work. The workaround (which works a million times better anyways) is buy a AAWireless or Motorola MA-1 wireless USB dongle and plug into the head unit. You then pair your phone to that, and it looks like USB AA or carplay to the head unit. That works flawlessly. |
08-02-2023, 03:00 AM | #22 | |
Rep 2
display, head unit, headunit, screen |
