BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > MHD "take a look at my log" thread
      06-22-2016, 10:25 PM   #67
hellokitty
hellokitty's Avatar
Drives: '17 M3 ZCP DCT
Originally Posted by d8rknight View Post
Cyl 2 misfire 29CE. I can never go WOT cause I'll get a misfire. will pull plug and see if it follows plug, followed by coil
I'd do the coil first since it is easier. Swap a coil for another coil in bank 2 and see if it misfires on the swapped cyl.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race
      06-23-2016, 12:39 AM   #68
MannySingh
MannySingh's Avatar
40
Drives: 335is
Originally Posted by hellokitty View Post
Sounds like its time to start having some fun with new turbos and FBO/inlets
Really not trying to spend that much as of right now, tight on budget. College Student probs
      06-23-2016, 09:47 AM   #69
krukedking
Drives: 2007 335 xi
Originally Posted by Supra2k6 View Post
heard mixed o2s will throw a bunch on codes 2c6a
but is that the only thing causing the half engine???
      06-23-2016, 10:55 AM   #70
hellokitty
hellokitty's Avatar
Most likely
      06-23-2016, 11:11 AM   #71
krukedking
Drives: 2007 335 xi
Most likely
shoutlndt the rears be shut down with mhd?
      06-23-2016, 11:53 AM   #72
d8rknight
d8rknight's Avatar
39
Drives: 2010 335i
2005 Yamaha R1  [0.00]
2011 Infinity G37x  [0.00]
2010 335i  [0.00]
Update for folks getting misfires after plugs and coils... Turns out had a bad injector and a valve cover gasket... And cover (hairline crack up near pcv). No vacuum leak up top yet but the cover is about $300-$400 gasket $35... With about 4-5 hours of labor
2010 335i Coupe / 6MT / MHD | FBO+ MMP S3 /AUBURN WDE / PATRIOTS / CELTICS / REDSOX
      06-23-2016, 11:59 AM   #73
Nonecure
Nonecure's Avatar
Drives: 2013 M3
I think your turbos look fine, but you are running a little rich. Try cleaning your MAP sensor located on your intake manifold. The slow response from you turbos can be many factors (boost solenoids, vacuum leak, or a small pressure leak), but it does not look like you need to worry about it.
You are in a serious need for an intercooler. For now have some soft cruising time after a strong pull.
      06-23-2016, 10:36 PM   #74
MannySingh
MannySingh's Avatar
40
Drives: 335is
When I posted my first log someone mentioned a leak in the intake or exhaust. And if the boost solenoids are the problem could I clean those too or would I have to replace them.
I have stock DV on a Cobb chargepipe, could that be the issue w anything?
      06-24-2016, 12:03 AM   #75
hellokitty
hellokitty's Avatar
Might make sense to find some used upgraded DVs... Solidify your intake tract before looking at mechanical issues for leaking boost since the DVs are the weakest link
      06-24-2016, 10:59 AM   #76
89mustaine
Stuff and Things
89mustaine's Avatar
Drives: E60 535i Sport W/SAT MHD
What are upgraded DVs? You mean a blow off valve?
      06-24-2016, 11:44 AM   #77
hellokitty
hellokitty's Avatar
http://www.turbosmartdirect.com/Prod...t-KIT-BMW.html
      06-24-2016, 03:41 PM   #78
89mustaine
Stuff and Things
89mustaine's Avatar
I see, why go with these when a charge pipe and bov would be cheaper? This is for those who absolutely do not want the noise?
      06-24-2016, 03:52 PM   #79
hellokitty
hellokitty's Avatar
Depends... the turbosmart dual port has the option for full recirculation (no woosh sound) or 50% vent to atmosphere and 50% recirculation (loud!). You just attach the blocking plate to the blow off side if you want 100% recirculation.
I had these before I went for my Tial BOV and with inlets, they were insanely loud... nice woosh sound. I really loved the sound with inlets... it sounded MEAN.
You could also go the BOV route as well... but the proven BOV is Tial and it's extremely quiet compared to the turbosmart.
      06-24-2016, 04:05 PM   #80
89mustaine
Stuff and Things
89mustaine's Avatar
Interesting even after checking out the site I didn't realize they were variable. Why did you go to Tial in the end then?
      06-24-2016, 07:12 PM   #81
Supra2k6
Drives: 335i
hellokitty was kind enough to check my logs and yeah my lpfp is on it's way out but had one more question thought it would be more appropriate here. if anyone can chime in as well thanks
Why am i running so rich? i can tell by the smell but my mpg is under 10mpg.
mods
e90 lci
dp,inlets, chargepipe bov, mhd stg 2 91oct map runing 93 gas as safety until custom tune.
3rd gear pull a/c off i believe
http://www.datazap.me/u/supra2k6/log...og=0&data=4-21
http://www.datazap.me/u/supra2k6/3rd...og=0&data=4-21
      06-24-2016, 07:49 PM   #82
Banana Clipper
Jewel Runner
Banana Clipper's Avatar
Drives: G01///G20///I20
mods
e90 lci
LPFP is my guess, dipping into the 30's but wait for someone more knowledgeable (edit, I thought you said lean, my bad, buy your LPFP is struggling)
www.BHANANA.com
2009 335i - SOLD
2021 M340i - GONE
2024 iX - Yea, she fast
      06-24-2016, 08:48 PM   #83
Nonecure
Nonecure's Avatar
Drives: 2013 M3
mods
e90 lci
The first thing I would check is your MAP sensor in your manifold. It could be fooling the DME to add more fuel. Try cleaning it first and replace if necessary.
Before getting a custom tune you will need a new lpfp, intercooler, and get this fuel issue fixed.
      06-24-2016, 11:52 PM   #84
Supra2k6
Drives: 335i
i will go ahead and clean it and report back tomorrow any other suggestions
i can't read logs well but besides my lpfp dipping under 50 i can tell and feel i'm running rich. Doubt is injectors car starts up fine and runs fine.
      06-25-2016, 12:26 AM   #85
hellokitty
hellokitty's Avatar
My CP was leaking so I decided to get a new CP + BOV.
      06-25-2016, 12:36 AM   #86
nismo
Drives: 335 e90 2008
Take a look at my log please
http://datazap.me/u/nismoy33/log-1466419757
      06-25-2016, 12:42 AM   #87
hellokitty
hellokitty's Avatar
I'd run the usual test for boost leak. You should be hitting target boost but you are not. What mods do you have? Miles?
      06-25-2016, 02:01 AM   #88
Msport335
Msport335's Avatar
97
Drives: 2009 335i m-sport e90
track night....here are a couple logs on my e60 wedge tune.
was hoping for better times but couldn't hook up.... logs are from 12.2 and 12.3 runs both at 120mph
http://datazap.me/u/msport335/mhd-e6...og=0&data=3-22
now definitely in the market to run meth but don't know the first thing about it as far as what i need since i run MHD flash only.
also will be picking up a set of 275/40/17 drag radials .... which are best between the 555r or nt05r?
E90 LCI M-sport/ 6AT/ LSD/ FBO+
