10-15-2012, 12:57 PM | #1 |
Administrator
41187
Rep 21,246
BMW iPhone 5 and iOS 6 Functions, Bluetooth and Y-Cable Overview and FAQ
BIMMERPOST NEWS BMW iPhone 5 and iOS 6 Functions, Bluetooth and Y-Cable Overview and FAQ Apple recently introduced the new iPhone 5. There are three key differences between it and earlier iPhone models that affect its integration in BMW vehicles. First, the physical dimensions of the body of the new phone are thinner and longer compared to the iPhone 4/4S. Second, the iPhone uses a new 8-pin connector in place of the traditional 30-pin connector used on all other iPhone variants as well as iPod touch and iPod nano. The third is the elimination of the analog video signal. Taken together, the result is: 1. iPhone 5 is not compatible with any of the current snap-in adapters available through BMW. 2. The PlugIn feature as a means of accessing one’s music library is not available on the iPhone 5. (Owners are still able to access their music library using a USB cable, see details under “Will I need an adapter to use my iPhone5?”.) 3. Also, watching videos stored on the device, on the car’s screen while parked is no longer possible. FAQ Below is an FAQ regarding the use of iPhone 5 and iOS6, as answered by BMW: Can I connect my phone via Bluetooth to make phones calls, see my contacts and play music? • Yes.Can I still play music from my iPhone 5 in my BMW? • Yes, via the External Devices menu in iDrive.Will I need an adapter to use my iPhone 5? • This depends on the options in the vehicle:Can I use PlugIn and/or play videos from my iPhone 5?◦ No, if you currently use an Apple "white cable" to connect your iPhone to your vehicle. In this case, all you need is the new Apple Lightning cable, included with your iPhone 5. (See our member's DIY guide for creating a cradle and integrating the lightning cable)◦ Yes, if you currently use a Y-Cable to connect your phone. In this case, you will need a "Lightning adapter" to connect your iPhone 5 to the Y-cable. (See "USB vs. Y-cable" on below to determine when a Y-cable is needed for MY 13 vehicles.)◦ The "Lightning adapter" is an adapter available via Apple to convert the old 30-pin plug to the new 8-pin connector or "Lightning cable". It is already on sale by Apple and retails for $29.99 (for the adapter) or $39.99 for the adapter cable. • No, the iPhone 5 Lightning connector does not support analog video, therefore making the PlugIn feature and video playback incompatible. • PlugIn and video playback are still supported when using an iPhone 4/4S with iOS 6.When will the iPhone 5 Snap-In Adapter be available? • BMW's official word on this is that there is currently no timeline set for the release of the iPhone 5 Snap-In Adapter, but as we recently reported, our sources indicate that its currently in developemtn and to expect it sometime around June 2013.Is "BMW apps" compatible with iPhone 5 / iOS 6? • Yes, owners with iOS 6 (incl. iPhone 3GS/4/4S/5) and a "BMW apps" equipped vehicle can continue enjoying the same great app integrations, just as they did with iOS 5.1. This includes Pandora, MOG, Aupeo, Stitcher and BMW Connected. • Pandora is still not compatible with the New Navigation Professional System (SA609) vehicles, but an update is expected from Pandora by November 30, 2012.)Can I use Mobile Office with iPhone 5 / iOS 6? • With the release of iOS 6 (incl. iPhone 3GS/4/4S/5), Mobile Office is now supported for Text Messages and iMessages. This is available in cars with option code 639 / 6NL "BMW Assist with Enhanced Bluetooth". Owners will be able to see their text messages / iMessages on the screen, • Not all of the Text Messages / iMessages on the phone will be displayed in the vehicle. Only new messages received while the phone is connected to the vehicle will be available in the vehicle. • Owners will have to configure their phone as follows to activate this feature: 1. Pair the phone to the vehicle as normal. 2. Under "Settings" and "Bluetooth", press the blue arrow to the right of the paired vehicle: 3. Then turn on "Show Notifications": 4. Also,notifications must be turned on for "Messages" as well: 5. Owners then have to reconnect their phone to the vehicle. This is done by scrolling over the paired phone in the vehicle’s “Bluetooth” menu and pushing the iDrive controller. 6. Returning a phone call via the displayed text message / iMessage is not possible. Owners should either dial the number directly or select a contact from their address book using iDrive. Y-CABLE / BLUETOOTH USB vs. Y-cable: USB is offered standard on all 2013 BMW models, but the available functions differ based on vehicle equipment. Audio playback through the USB port is always included, but may require the Y-cable accessory in combination with an iPhone / iPod. The BMW Apps features are only available in combination with option 6NR "BMW apps". Some of the app features are accessible using the Apple cable, but video playback is only possible with Smartphone Integration (6NF) in combination with the appropriate snap-in adapter. * Plug-In is not currently compatible with the new Navigation Professional system (SA609); a fix is expected later this year. The Y-cable is needed unless the vehicle is equipped with 639 or 6NL "BMW Assist with Enhanced Bluetooth and USB", which is standard equipment on all MY 13 5 Series, 5 Series GT, 6 Series, 7 Series, X5 and X6 models. On most other MY 13 models, 639/6NL is offered in combination with 609 "Navigation system" and/or in the Technology Package and/or as an option. See the chart below for more details about each model’s Y-cable dependency. Bluetooth: Bluetooth comes standard on all 2013 BMW models, but again, the available functions are dependent on vehicle equipment. Please refer to each vehicle’s ordering guide to determine which options are available. |
10-15-2012, 05:00 PM | #2 |
111
Rep 2,164
Drives: 2020 BMW 330i xDrive
delete my thread if you wish lol
Former BMW Client Advisor
10-16-2012, 09:53 AM | #4 |
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
10-22-2012, 09:16 AM | #5 |
114
Rep 118
hey ..ive got a MY2011 m3 with a y-cable but it wont work with 30 pin to lightning adaptor and iphone 5... no music or track list info in idrive (but it does show the device)
- any ideas? thanks aj |
10-22-2012, 09:30 AM | #6 | |
111
Rep 2,164
AJ, use the white cable your phone came with a ditch the y-adapter. It will work. PM me if you need more help.
11-21-2012, 09:23 AM | #9 |
BMW Motorsport
236
Rep 2,225
Drives: BMW ///M4 F82 / BMW ///M5 F10
has anyone using the ycable and the lightning adaptor able to charge their iPhone 5?
Neil J. //McRae -- Alive and Kicking -- neil at DOMINO.ORG --///M ARMY M5 CP Alpine White -- M2 LBB -- M4 DCT CP Alpine White |
12-01-2012, 01:41 AM | #10 |
106
Rep 167
12-08-2012, 02:03 PM | #11 |
m3gutguy
Rep 3
Thanks Jason
I have had my 2012 M3 since July and haven't been able to see texts or email. After updating to iOS6 I still couldn't get it to work until your post. I now can get my texts and email and am lovin' it. Thanks Jason.
06-02-2013, 02:27 PM | #12 |
21
Rep 164
So now that we're in June of 2013, has anyone heard any news on the new adapter?
Do you think the new adapter will allow for video playback, or is that a hard-wired / coded limitation with the lightning adapter? Reason I ask, is that I'm due for a new phone upgrade with Verizon, and I'm debating whether or not to wait for the iPhone 5S, or get the 4S, which allows for video playback. |
06-02-2013, 03:59 PM | #13 | |
Rep 586
Not that I'd endorse getting a new 4S even if video were important to you. Apple has already moved to the new connector and is doing everything in their power to move everyone over. The 30-pin will be the red-headed stepchild of connectors long before your new contract is over. Video is cool only for like 15 min anyway. Then you're over it.
2013 E92 M3 (the weekend good weather car), 2018 Tesla Model 3 Performance (the 20k mi/yr beater)
06-02-2013, 07:45 PM | #14 | |
21
Rep 164
11-18-2013, 11:34 PM | #15 |
Rep 6
anyone know why my iphone 5 isn't recognized by iDrive ('09 e92 m3)? I get "device not recognized" error. I am using the 9 pin white lightning cable that came with my phone from Apple.
I want to get the snap in adapter for phone (love the idea of improved reception by wiring to the external antenna). Has anyone successfully installed this feature? I'm wondering if i need to flash my iDrive to upgrade the software. |
01-02-2014, 12:22 AM | #16 | |
Elite Member
28
Rep 164
09-23-2014, 05:51 PM | #17 |
Rep 724
Thanks OP and others for sharing info and knowledge. However, after reading everything, I am left with questions. Can somebody please confirm whether or not I am able to use an iPhone 5s with the iDrive AND sterring controls in any way/shape/form with a 2008 M3 (Tech & Prem packages)?
Mmmm... M&Ms,
Dale |
01-30-2015, 11:26 AM | #18 |
Rep 614
I have an iphone 5 and a 2010 M3. Whenever I try to pair the phone with the car via bluetooth, it is unsuccessful. Any ideas why?
01-30-2015, 12:00 PM | #19 |
Rep 6,696
Drives: F30 340i
03-25-2015, 01:13 PM | #20 | |
62
Rep 122
12-05-2016, 10:07 AM | #21 |
Rep 14
