Guide to Reset the E90/E91/E92/E93 Service Indicator Lights
08-27-2014, 01:46 PM | #67 |
DIE ANTWOORD
68
Rep 640
If you throw in new brake pads and a new sensor on one axle only you can't reset the brake warning when the sensor on the other axle is already worn down to it's second stage.
If you want to reset the warning light take the old sensor (the one you have replaced) cut off the sensor head and twist the two cables together (or solder if you want to use it more often) Pull the half worn sensor from its plug and push the dummy sensor in instead (no need to remove it from the caliper). Now you can reset the warning light as described. After resetting remove the dummy and reconnect the half worn sensor to its place. The board computer will calculate the remaining miles after some driving around. |
12-16-2014, 11:20 PM | #68 |
Rep 3,551
Could someone comment on the spark plug reset option.
I have never heard of resetting spark plugs. Could this have an effect on fuel consumption calculation? Did my plugs not long ago, and haven't reset anything. |
12-17-2014, 03:26 PM | #69 |
Rep 473
No difference. It's a life counter. If you have error codes due to poor firing plugs then you would use a OBD code clearer.
Become like water my friend.
12-18-2014, 11:53 AM | #70 |
Rep 3,551
I've actually checked the reset menu, and the option for spark plug that is in the video (if that symbol even represents a spark plug) is not even available on my car.
12-20-2014, 04:08 PM | #71 | |
Rep 473
My M3 doesn't have it either. My 325i did though.
12-30-2014, 05:35 PM | #72 |
Rep 1
Dealer service light reset
Can anyone tell me how to reset the Dealer service light? I do all my own maintenance and have been able to reset all lights except this one. Do i need an OBD II tool?
Thanks for the help, G |
01-03-2015, 06:29 PM | #73 |
Rep 473
It's also in the same menu as the video describes, when you scroll through them there will be one in red. I forgot if its reset twice or change date.
03-03-2015, 10:25 AM | #76 | |
Rep 443
Just wondering. Thanks. PS - I'm going to try the oil change reset this weekend. |
04-01-2015, 12:15 PM | #77 |
15
Rep 136
is there a way to reset the brake warning?
i have the message that comes on my display upon powering up the car, and then the brake light on the cluster thats always on. its driving me NUTS..and i cant figure out how to wipe it for the life of me. i have an 06 e90 |
04-29-2015, 05:07 PM | #78 |
Rep 14
I've got an 09 328i Wagon/E91. The only way I could get into reset mode was to hold both the trip reset button and the B/C button at the same time. Brake pedal did not work for me.
- Also, referencing brake sensors. I just changed out my front pads and rotors. I could not reset the brake service interval and I also got the red car-on-lift service warning and both front and rear brake service interval mileage read '_ _ _ _' - i looked closer and did have wear on the brake sensor. These newer sensors are not good/bad like the E46's. I've read that they increase resistance as they wear until a full open. Trying to reset the service interval with an old sensor will only work if there is no rubbing on the sensor. - NOW, the trick. Just take a metal garbage bag tie and jump the two sensor plug wires. This now shows zero resistance and the computer will allow a service reset! Plug the old sensor back in (as long as it's not a full open) and no more brake warnings |
05-07-2015, 03:44 PM | #79 | |
Rep 33
07-29-2015, 02:25 AM | #80 |
Rep 1,028
When the "Reset" prompt comes up, be sure to hold down the ">BC" button for 5-7 seconds as the little clock times out the request and the parameter is reset.
If not mentioned, the doors need to be closed while performing the reset. When I asked my local BMW dealership if they'd help me reset the oil interval on my out-of-warranty 335, the guy told me I would need an appointment and it would be $45. (*$^&%$!
"The likelihood of one individual being right increases in direct proportion to the intensity with which others attempt to prove him wrong."
2015 F82 M4 - Sakhir Orange Metallic 2013 E92 M3 / 2013 E92 335is / 2010 E90 335i / 2007 E90 335i |
06-13-2016, 09:34 PM | #83 |
Rep 1,347
Drives: 2011 335d
Does this work for cars with i-drive?
I have changed my own oil at less than the normal BMW service intervals but can't seem to reset the service due indicator. |
12-23-2016, 10:09 PM | #84 |
Rep 11
Hi, i reset oil service light in my 2007 bmw 328 xi everything ok ,it reset to 18000 but every time i turn on my car it comeback to 0.. do you know what could be? THANKS IN ADVANCE.
12-30-2016, 07:25 AM | #85 |
General
17401
Rep 18,791
How many mile?
05-06-2017, 11:32 PM | #86 |
Rep 473
anyone have any idea if you reset a menu by mistake twice is it possible to roll back the dates of the next service so it isn't like 5 years later?
10-04-2017, 03:22 PM | #88 |
41
Rep 164
Drives: 2016 M4/F82 MGM/SO
Did this ever get figured out? I was trying to reset my service required light (Car is on a lift in my cluster) on an 09 E92 and it would not change.
