DIY: n52 Oil Cooler retrofit
04-11-2018, 02:07 PM | #23 |
Rep 17
So if I plan to replace headers, I'm guessing retrofitting this oil cooler would be a good thing to do at the same time?
2010 BMW 328i E90 - 6MT - RWD - Jet Black - No sunroof - Apex 17x9 ET30 Arc-8 on 245/40 PSS, sport package springs (D4/D3) with Bilstein B8 shocks, Stoptech Sport pads, RBF600 fluid
2010 BMW 128i E82 - 6MT - RWD - Crimson Red - No sunroof - Stock for now |
04-12-2018, 05:29 AM | #24 |
111
Rep 112
12-04-2018, 07:26 PM | #25 |
61
Rep 107
Question for those of you that have already done this swap, how much coolant ends up draining out when you pull the original pipe off? I'm going to tackle this this weekend and want to make sure I have enough coolant on hand.
12-05-2018, 05:07 AM | #26 | |
111
Rep 112
Each time I added right at 1 jug of coolant, and seem to be right a 50% mix. I use bottled distilled water going back in, so I can monitor how much of each goes back. Listed capacity for our cars is 8.2 L. One jug might be a bit shy once you dilute to 50%. Having a second on hand is a good plan. IIRC my BMW dealer isn't out of line on price. I busted a radiator in my truck a few winters ago because the book capacity for my vehicle was incorrect, so my mix was weak after a flush. It sat in my unheated, detached garage for about a week of sustained single digits. A hygrometer was under $10 from amazon and is cheap insurance going forward. |
StradaRedlands4991.00 |
12-05-2018, 06:54 AM | #27 | ||
61
Rep 107
05-30-2020, 01:55 PM | #29 | |
Rep 1,579
My pick and pull has an N52 X5 with the cooler which I can get for $10. Not sure I need a cooler but since it will be cheap and it was 115 degrees here yesterday. |
shuotong21.00 StradaRedlands4991.00 |
03-18-2021, 05:16 PM | #30 |
15
Rep 98
the additional oil cooler sits directly on top of the accessory belt and increases the risk of oil dripping onto the belt when the oil cooler gasket eventually breaks down. Unless I'm planning on doing a tune I don't think it's worth the risk
CTinline-six6883.50 |
03-18-2021, 09:36 PM | #31 | |
Rep 1,490
I was thinking to go same route, but in my case altitude is an issue, so I had to go full retrofit from 335 of oil cooler radiator as fluid/fluid heat exchanger won't do a trick here. |
03-19-2021, 07:09 AM | #32 | ||
Hoonigan
6884
Rep 3,000
Drives: '09 328i, '98 Wrangler
Noir883.00 |
03-19-2021, 08:26 AM | #33 | |
Rep 1,490
I would not worry about oil leaking from exchanger gasket to belt. The gasket on housing will do that when it gets too brittle. Problem with heat exchanger gasket is that it is known to mix coolant and oil. Also, heat exchanger can fail internally and mix coolant and oil. I still think you would benefit with this set up in your climate. Also, you can change gaskets preventively. You know well they will fail. OFHG will fail, cooler or not. But, based on my track experience without any cooler, oil will run much hotter than coolant, so with fluid/fluid exchanger you can keep in check temperature and put bit less strain on gaskets in that part. |
03-19-2021, 09:09 AM | #34 |
Rep 1,364
Drives: 09 E90 335i M-Sport 6MT RWD
The E60 and E83 N52 cars all had this cooler as well as the E90 N52 in hot climates.
My E60 N52 is the highest mileage and the only one to never need an OFHG replacement(YET). I have one waiting to go on my brothers E90 N52 as its a pretty easy replacement and if anything can run these hot running engines, why not(especially in winter climate they take forever to heat up). I have yet to hear of a water to oil cooler fail but 1 extra gasket which is even easier to change I dont see much of an issue. Just keep an eye on both of them |
03-23-2021, 02:30 PM | #35 | |
Rep 1,490
More common, actually very, is that sometimes gasket separating cooler from OFH leaks in place that separates coolant from oil line, and mixes coolant and oil. Best thing is just to preventively change it. |
03-23-2021, 02:38 PM | #36 |
Rep 1,364
I agree I mean I'm sure it does happen but you are right; Change it when you change the OFHG because BMW apparently cannot make rubber gaskets correctly.
03-23-2021, 03:36 PM | #37 |
Rep 1,490
03-31-2021, 09:11 PM | #38 |
87
Rep 144
I can certainly see the use in this for getting your oil up to temp faster, but if you have cooling issues, as someone already mentioned, the 335 oil cooler is the way to go. I paid about $200 in parts for everything used with another $40 or so for new gaskets. at 6000 ft of elevation, when I was bedding in my brake pads, I had to do about 30 4 seconds stops at 50% brake so I did 30 or so back to back 40-80 pulls at wot, and temps stayed at around 240 the entire time in 50f weather. The 335i oil cooler Install is definitely far more intensive as it involves removing the front core support to sandwich in the bracket for the oil cooler but it's more than enough to keep the car cool
04-02-2021, 10:02 PM | #39 | |
Rep 1,490
I managed to get oil cooler brand new for $200 The temperature stays at 110c when I am pushing the car very hard over Loveland Pass which is at 11,900ft altitude, and I do it once a week when going skiing at A-Basin. |
04-07-2021, 12:48 AM | #40 | |
15
Rep 98
02-21-2023, 04:02 PM | #41 |
41
Rep 70
Thanks to johnmyster for the original post. It helped me take the leap.
03-29-2023, 02:39 AM | #42 |
Rep 7
For those people who actually do this modification there is some bad information regarding one of the cooling hoses. You should use 11537526941 instead of 11537522999 for e90 applications. While the 11537522999 hose fits, it has a bad clocking of the fitting that attaches to the radiator that is not ideal. Hope this helps.
04-04-2023, 03:57 PM | #43 |
Rep 20
I'll be tackling this soon on my e92. All parts acquired except the hoses (Still not quite certain what exactly what should be replaced to get the job done vs the "while I'm in there" work)
I plan on upgrading the rad to the spiffy CSF simultaneously, so we can reject more heat when the fancy computer decides we need to. |
04-04-2023, 11:56 PM | #44 | |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
BMW changed the gasket material spec from HNBR to FKM recently (see Elring catalogue). Hopefully FKM is more durable https://polymerdatabase.com/Elastomers/HNBR.html https://polymerdatabase.com/Elastomers/FKM.html |
johnnyorange58.50 |
