      01-24-2015, 11:21 AM   #1
Brearley_III
Brearley_III's Avatar
94
Drives: 11' E82 S65 1M, 21' F95 X5MC
1LittleMonster 135i > 1M Build (#1littlemonster)
BIMMERPOST
     Featured on BIMMERPOST.com
Here's my 135i > 1M Conversion, thanks for checking it out! My build was inspired by; ilikebmxbikes & TUN3D for your detailed parts lists and inspiration to start this project.
Recaro Sportster CS Heated Black Leather Seats
Macht Schnell Seat Mounts & Recaro Sliders
VAC Custom Bolt-In Roll Cage
VAC Wheel Spacers (Rear Only - 15mm)
Sprint Booster
BMW PPK2 - Performance Power Kit 2 - (high output cooling fan, secondary radiator)
Cobb Catted DP
Meisterschaft GTHAUS 1M SS Exhaust
Agency Power FMIC
BMS Charge Pipe
BMS Modified BMW Clutch Valve
BMS Oil Catch Can
aFe Stage 2 Magnum Force Cold Air Intake
aFe Dynamic Air Scoops
M3 Front and Rear Sway Bars
M3 Rear Subframe, Differential, & Suspension Components
1M Drive Shaft
1M Strut Mount Brace
AirLift Performance 3H Management
AirLift Performance Air Bags & Fully Adjustable Dampers
Accuair trunk decklid mounted 5 gallon air tank
BMW Performance Blackout Grille
Hankook Ventus RS3 265/35ZR18
APEX ARC-8 18x10 ET22 Square
APEX Race Wheel Stud Conversion
BMS Amber Angel Eyes
Vorsteiner Rear Carbon Diffuser
Revozport 1M Front Splitter
Revozport 1M Trunk Lip Spoiler
Revozport Single-Sided Carbon Hood
iND Painted Side Markers
1M Gauge Cluster
Xpel Protective Coating - Full Kit
Custom coding & features from NTX
(01.03.2016 update)
Appreciate 5
Bimmer TV125.00
uzone0212.00
      01-24-2015, 11:26 AM   #2
e90Nick
Drives: White e46 M3
Nice garage and car! Are you doing the rear quarters by yourself too?
      01-24-2015, 11:31 AM   #3
Brearley_III
94
Thanks e90Nick! No I'm still making my rounds to talk to some body shops to see if I'm going to order the full quarter panel and have them piece it in or do it like ilikebmxbikes.
If anyone can recommend a body shop on the East Coast I would make as long of a drive as I need to have it done perfectly!
'87 E30 M62 V8 6MT -- '11 E82 1M CLONE S65 6MT -- '21 F95 X5MC
      01-24-2015, 11:36 AM   #4
mvallido
mvallido's Avatar
Philippines
70
Drives: M235i Estoril Blue
Wow very nice.
2014 M235i {Dinan P1 Power Package}
2015 F30 320i
2006 E90
2004 C240
97 E39 VF5 Supercharged
      01-29-2015, 09:09 AM   #5
Brearley_III
94
I have parts on the way!
ECS Tuning; OE BMW 1M parts needed for exhaust & battery re-location
AutoCouture Motoring; Meisterschaft SUS Super GT Exhaust
* They will also be coding my Braille Battery & doing a valve cleaning, check these guys out! http://autocouturemotoring.com/
Amazon.com; Braille B3121 Lightweight Battery & 1232 Charging Solution
EAS: Macht Schnell - Aluminum Lightweight Battery Enclosure
And the GRAND FINALE!
Revozport - Lightweight Bonnet w/ Aerocatch & Interior Carbon Trim Kit
      01-29-2015, 10:07 AM   #6
Fidiman
Fidiman's Avatar
France
114
Drives: BMW 120d e82 M Sportpaket
2010 120d E82  [10.00]
I will follow this thread, maybe I will have some new ideas for my build
M Sport package, Stage 1, CDV, BMC airfilter, VMR vb3, ST XTA, BMW Performance stuff, M3 arms, E93 M3 anti-roll bars F and R, ...
French community of 1 and 2 Series: One-Two-Bimmers
      01-29-2015, 03:08 PM   #7
Tony135
Drives: ‘22 Model 3
Good luck! You won't regret it. I still fall in love every time I see mine.
      01-29-2015, 03:18 PM   #8
Brearley_III
94
Thanks! Yours definitely came out amazing!
      01-29-2015, 09:23 PM   #9
suspenceful
suspenceful's Avatar
Drives: 2015 M3, 2008 135i, 2009 335i
I can't wait to see the progress...
750whp 135i Build | Budget 335i Build | F80 M3 Build
🎬 YouTube channel (35K+ subs): youtube.com/jakespence135
📷 Follow me on Instagram: instagram.com/jakespence
🏁 Shop BMW merchandise: bimmerstreet.com
      01-30-2015, 02:59 PM   #10
Brearley_III
94
update;
Huge THANK YOU for Status / Agency Power for Sponsoring this project!!
Should be seeing 2 of these beauties in 3-4 weeks!
Status Ring FIA Approved
And this!
      01-30-2015, 03:24 PM   #11
TUN3D
TUN3D's Avatar
193
Drives: none
LittleMonster_III > Really excited for you man! Can't wait to see it come together. Which way are you attacking the rear?
      01-30-2015, 03:39 PM   #12
ilikebmxbikes
Drives: S65 1M Clone & E92 M3 4.6L
awesome. cant wait to see this come together!
      01-30-2015, 04:43 PM   #13
Brearley_III
94
Thanks! So excited for everything to come in!
I ordered a Braille battery so I'll let you know how I like it! I will get that installed and coded 1st before the relocation... Then Ilikebmxbikes confirmed that the old 135i bumper will work with the 1M carrier... I will just remove the diffuser so I can run the quad exhaust while I wait for the rest of the parts to arrive...
      01-30-2015, 08:03 PM   #14
TUN3D
TUN3D's Avatar
193
Drives: none
LittleMonster_III > Are you changing the battery bucket and the whole 9-yards? Also, when i restructured the build and broke it down into different pages, I forgot to add the PPK2 section. Just haven't had time. If you're doing that as well, let me know.
      02-03-2015, 02:00 PM   #15
Brearley_III
94
I am! I saw your thread too... Almost ordered the wrong negative cable too! Thanks for the amazing work on that btw! Got the battery today too! I'll post pics later tonight...
      02-04-2015, 09:49 AM   #16
Brearley_III
94
Braille has arrived!
      02-04-2015, 11:14 AM   #17
TUN3D
TUN3D's Avatar
193
Drives: none
LittleMonster_III > looks nice. Seems to be on the taller/higher side. Did you verify that you'll have enough vertical space?
      02-04-2015, 02:21 PM   #18
Brearley_III
94
hmmm... you're right. I will check that tonight when I get home.
      02-04-2015, 03:09 PM   #19
TUN3D
TUN3D's Avatar
193
Drives: none
LittleMonster_III > I can double check and give you the height of my battery for comparison. You also have to account for the distribution box that goes on top -- bumps it up a little more.
In terms of length (assuming you're doing the 1M tray), it has to be under 11" for the floor-nut to be exposed -- this is where the battery-holder screws into.
      02-04-2015, 03:10 PM   #20
TUN3D
TUN3D's Avatar
193
Drives: none
I also noticed the Braille doesn't have an edge/lip along the bottom. Not sure the stock holder will work if that's the case. Did it come with it's own holder?
      02-07-2015, 11:51 PM   #21
Venom
Venom's Avatar
Drives: M2 Competition
2008 BMW 135i  [8.50]
You should bug Sk8fe He may have finished the rear quarters?
Good Luck! I hope you know what you are getting yourself into
      02-09-2015, 05:52 AM   #22
Brearley_III
94
TUN3D; I bought the Macht Schnell battery hold down for the 1M holder, ilikebmxbikes build had that info for me so I knew it would work.
Venom; Thanks! I'll definitely PM him. Still trying to find a body shop too so that'll help!
1m build, 1m conversion, hankook, quad exhaust, revozport
