08-28-2018, 10:53 PM | #1 |
Rep 8
Changing NBT Country Coding
Hi Guys,
I am looking to flash a Japanese NBT to Australia/New Zealand version. From what I have found I need to edit my FA with the following changes and then flash the NBT. Change: L810A from L807A S852A to S853A Has anyone on here done this before or something similar? My current I-Step is F025-13-07-505 which is PSdZData 50.3. Is there any issue only flashing the NBT to the latest version? Thanks Last edited by kiwidecal; 08-28-2018 at 11:09 PM.. |
08-30-2018, 05:13 AM | #2 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
Keep in mind you use a ICOM and flash KOMBI to.
08-30-2018, 04:50 PM | #4 | |
588
Rep 2,302
Change the Salapa-Options in your VO and then only code the NBT. All changes will be automatically set. |
08-30-2018, 06:26 PM | #5 |
Rep 8
12-17-2020, 08:00 PM | #8 |
Rep 4
Hey Dave I did it successfully!! after your VO coded all settings will shift to AUS standard automatically. So it gives accessibility to load AUS/NZ map, but if you having Japanese NBT(Asia version) which may have to rewrite FSC application back to ECE/US version then it will be activated. Otherwise in my case that the NZ NAVI were usable for just 1-2mins then suddenly greyed out.
12-23-2020, 11:43 AM | #10 | |
Rep 12
I did it on 2015 F30 imported from Korea I removed L802A and S867A from the FA and replaced them by my home country language and version. I used this thread to get the options number: https://www.bimmerfest.com/threads/f...ements.966607/ After that, I replaced the FSCs by new ones and put new map data via USB. |
12-25-2020, 03:03 AM | #11 | |
Rep 4
00A0 Navigation System Professional ECE/US 00A1 Navigation System Professional Asia Initially i used FDL coding changed the Hu_NBT county(Japan to AUS)/Navi_Variante(Japan to ECE), I was able to put Australia map with New fsc code and map data. However it has not been activated while Japan map is still workable when I Coded back FDL to Japan which means I am having 2 map data in my NBT unit LOL. So even after VO coded with my country language and version(just overwrite FDL section as I have done before) where the Navi still greyed out. Due to the different unit version of NBT which I eventually relised that... After rewrite FSC application someone from eBay my Australia map works perfectly. So im thinking if your area is within the version then it may only need FDL coded Navi region and converting NAVI use new fsc code and map data. |
12-25-2020, 09:29 AM | #12 | |
Rep 12
1. 00A0 2. 00DE 3. 00xx where xx depends on what map you want to have. e.g. 00A8 US 00A9 Europe 00AB Middle east 00AC North Africa 00AD South Africa 00AF South America 00B0 India 00CA Turkey .. These FSCs must be accepted. You could load 00A1 but there is no point in doing that if you are not in Japan, Korea.. |
12-26-2020, 12:20 AM | #13 |
Rep 4
Many thanks!!!
Wow that’ll makes more sense to me now. Anyway my NZ map is usable now after I struggling nearly a month.. Will see if there’s really a chance to take her back to my hometown or Japan even for a big road trip after COVID! |
01-17-2021, 04:50 AM | #14 |
Rep 21
Hey team, can one of you please elaborate on what my next step should be.
I vo-coded NBT and Kombi with 810 and 853. Now I need to load AU/NZ maps. Do I just need the maps + FSC code or there is more to it? Navigation menu is currently greyed out. Cheers |
01-20-2021, 09:37 PM | #15 |
Rep 4
Yes it will let you load map with AUS/NZ fsc code now. So have you loaded NZ map yet? Did it greyed out also? if so the solution in my case was to get plug-in fsc usb file via eBay and done.
01-20-2021, 09:42 PM | #16 | |
Rep 21
Yep got it all sorted in the end. 2021 maps, generated activation FSC code + FCS retrofit pack to enable ECE navi. |
06-03-2021, 05:05 AM | #17 |
Rep 30
Hi Guys. I looked into this when I first got my car and was under the impression to change to NZ maps on a Jap import car was not so straight forward and required something like a new image of the Hard drive to be installed. I am hoping you are saying this is not the case. I can do the changes to the codes with esys and have a copy of the AUS/NZ maps (I think 2020 NEXT from memory). I pulled the current FSC (DE) code from my car, and used it to generate a new code for the maps I have. I have both a lifetime and single use code. Is this all I need or is the 'FCS retrofit pack to enable ECE navi' mentioned something else again. Would be great to get the NZ maps working if possible. wlu17 or sobanoodle ( or kiwidecal) - I would be keen to contact you to discuss in more detail if you were happy for me to PM you my number. (assuming you are in NZ) Thanks in advance David (Auckland NZ)
06-14-2021, 02:32 PM | #18 | |
General
10447
Rep 40,805
06-14-2021, 03:31 PM | #19 |
Rep 30
Thanks again Shawn. I will give it a go. Just to confirm - when you say "then pull DE (not current one) and then use it for Map Update" is that different from " I pulled the current FSC (DE) code from my car, and used it to generate a new code for the maps I have." (this was using an FSC code generator off this forum somewhere.) Do I still need to purchase some other code from somewhere. Thanks David
06-14-2021, 03:43 PM | #20 | |
General
10447
Rep 40,805
06-16-2021, 08:06 PM | #21 |
Rep 30
Hi Shawn. I have not tried to install the maps yet - so it may just work BUT, I changed the FA ( by changing SALAPA elements L807A to L810A and S852A to S853A) - and flashed NBT with the new FA. I then Re- Extracted my DE file and used it in the FSC Generator to generate an FSC code for the map installation.
The (possible) problem I have is the generated code is exactly the same as the one I got last week when I pulled the DE file before doing the FA changes. I have no easy way to check if the pulled DE file is different. Was there something else I needed to do after writing the new FA to the car( and flashing the NBT ) to get it to change the DE file before I extracted it. Or more of a worry do I need the "FCS retrofit pack to enable ECE navi." mentioned in previous posts. i.e will it not automatically regenerate the DE file itself to incorporate the changes. Thanks again David |
06-16-2021, 08:18 PM | #22 | |
General
10447
Rep 40,805
