11-30-2013, 03:38 AM | #1 |
47
Rep 81
LED DRL Brightness Adjustment
Yeah, finally coded the DRL on my Japanese version
The lights are extremely bright though. I tried all options in TFL_MODUS from off to Tfl_s but no effect on the brightness... Any idea ? |
12-01-2013, 01:18 AM | #2 |
General
10447
Rep 40,805
These affect the Halo Brightness with the headlights on, but you can check and see if they also affect the DRL Brightness:
MAPPING_STANDL_V_L_PWM_LEVEL_1 MAPPING_STANDL_V_r_PWM_LEVEL_1 MAPPING_PARKL_V_L_PWM_1_LEFT MAPPING_PARKL_V_L_PWM_2_RIGHT
12-02-2013, 02:50 PM | #4 |
15
Rep 92
does a value behind "PWM_LEVEL" adjust the brightness or is it just PWM on and off?
Could parking light "Standlicht" set to DRL brightness level or won't it dim then, when lowbeam is on? |
12-03-2013, 09:13 AM | #6 |
49
Rep 173
So just to confirm:
MAPPING_STANDL_V_L_PWM_LEVEL_1 MAPPING_STANDL_V_r_PWM_LEVEL_1 controls the Halo brightness while the headlights are on, correct ? They usually dim out once the headlight is turned on for the F30s in the US. |
12-03-2013, 02:13 PM | #7 |
15
Rep 92
thanks for the sheet.
Why is there Standlicht left and right - Standlicht should be all parking lights on, I thought. Parklicht is parking lights on one side only. Btw. how do you name these two modes in English? Are the more values related to this functions? I would like to disable the automatic DLR and turn it on and off with the light switch. Could the DLR be assigned to parking light; position =|) (|= But they should dim again when lowbeam is on //D |
12-03-2013, 05:36 PM | #8 |
47
Rep 81
Nice drawing
Not sure why, but the module allows you to control each bulb individually hence L/R. Just try to play with the codes to see how it impacts the brightness. Note that on a Japanese blog, a guy was pointing out that the brightness of his LED were changing whether the car was stopped or moving ! |
12-04-2013, 04:54 PM | #9 |
15
Rep 92
Unfortunately I have no coding equipment (and no F30 or F32 - will be my next car).
I recently noticed that the F30's DRL doesn't include the taillights anymore. Did you activate them as well? Referring to your sheet there is a DRL option in iDrive - can it be accessed easily (shortcuts?) - sorry I hope this is not too much off topic. |
12-05-2013, 01:58 AM | #10 | |
47
Rep 81
Yes the shortcut can easily be accessed Menu > Settings > Light if I recall correctly. |
12-08-2013, 02:20 PM | #12 |
Rep 11
Can anyone tell about the DLR voltage options equal in verte values?
I have options for parking and with headlights on like 11.5v , 12.4v,...... 13.7v(8%,10%,12% also) 13.7 with verte 64 ???? any ideas guys?? Thanks. |
12-15-2013, 03:37 AM | #14 | |
Rep 11
13.7V=137 13.5V=135 13.4V=134 maybe we need to code DRL voltage settings by that way??? |
12-15-2013, 06:47 AM | #15 |
15
Rep 92
LEDs are very heat sensitive, I wouldn't set them to full brightness when headlights are on. Insufficient cooled LEDs will lose brightness and shift to red color, quite apart from the fact that they will degrade much faster.
01-10-2014, 10:33 AM | #16 | |
Rep 583
The Side beams still are low brightness. Have you had any luck with this?
Driving: F30 330e
// /M-Sport | Mineral Grey | Coral Red Leather | M Sport Plus Pack | Media Pro Plus Pack | Active Security Pack | Adaptive LED Lights | Advanced Parking Pack | Interior Comfort Pack | Enhanced Bluetooth with Wireless Charging| Black Performance Grill | Heated Seats | Heated Steering | Speed Limit Display |
01-10-2014, 01:59 PM | #17 | |
1ST CLASS AWMSPORT
74
Rep 789
Drives: 13' 328 MSPORT
My cousin has a Audi q5 2013. when he coded his , he was able to change the % of brightness from their stock 20% to now 50%. They completely changed the look for the better...now is this possible with the BMW, i love the look of stock, but i recently changed my HID D1S bulbs to 8K and now you can see the difference in my halos. If it is possible to make the halos a little brighter to give it that same effect....
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon: JB4,DP,H&R sports,rear diff,! |
01-13-2014, 03:15 AM | #19 |
45
Rep 235
Drives: 2014 F31
The codes prevent the car from performing checks on aftermarket LED replacement bulbs for the turn signals. When these checks are performed, during startup and every few minutes after, the turn signals blink even when they are not engaged.
08-01-2015, 11:33 AM | #20 |
Rep 683
Interesting. Anyone has experienced degradation yet?
10-25-2016, 12:44 PM | #21 |
27
Rep 191
anyone know how to set 50% with low beams on?
12% doesn't seem bright enough, but 100 seems too bright.... i tried 12.4v but that looks like it's 100...
2012 335 2016 435 2019 440 GC |
10-25-2016, 04:40 PM | #22 |
Rep 8,364
