BMW 320d DPF WARNING LIGHT?! HELP PLEASE!!! :(
11-05-2014, 03:48 AM | #1 |
36
Rep 191
Hi All
The following Warning Light came on my 2007 BMW 320d M Sport Coupe E92 94k miles on the clock yesterday. 1. Is this the dreaded DPF Filter light? It is a square with half filled dots (pic below). 2. I have noticed there are other warning lights showing the same box in which it is full of dots. Does the fact its half filled mean its not as bad of an issue? 3. I use my car regularly and commute 40 miles each day going 70mph+ hence thought the DPF should regenerate and not have this issue, so I am led to believe. 4. One point to note is that I went through a very big puddle under a bridge which was kind of flooded and thought to turn back instead went thought it very slowly. The light literally appeared minutes after and has never come on before. So perhaps could it be that the exhaust is just damp and it will dry out and the warning light will go away? Or is that just wishful thinking? 5. In terms of next steps, should I definitely get it seen to, leaving it, will it get worse and the entire car will mess up? 6. And in terms of cost what am I looking, is there a quick fix. I was thinking to just use it regardless since the car runs and seems fine, or is this unwise? Any feedback on the matter will be much appreciated! I hope this is not a costly month |
11-05-2014, 04:18 AM | #4 | |
36
Rep 191
Thanks in advance IYRIX |
11-05-2014, 04:20 AM | #5 | |
36
Rep 191
Could the fact I went through a flooded area have any impact on the light coming on? Thanks in advance CURPRAJ |
11-05-2014, 04:22 AM | #6 |
162
Rep 2,399
because the light come on doesnt mean its gone. many people get scared when it comes on and takes straight to indy to get changed. make sure everything else is working before you try regen. temps are ok etc. when i take mine i cruise it at around 85-90. 80 on a 320d should be ok. mine tends to regen after doing around 25miles in same speed non stop. light comes on now and then
11-05-2014, 04:47 AM | #7 |
Rep 476
Just going for a fast drive is unlikely to fix the issue.
There will be a reason the light has come on. First off check the engine temps. Follow these instructions and you'll be able to go for a drive and see what the temp gets to. http://e90.wikifoundry.com/page/BC+hidden+menus Regen can actually take place at low speeds. Long runs certainly do help though. |
11-05-2014, 05:01 AM | #8 | |
36
Rep 191
Furthermore, if I continue to use the car whilst this warning light is on, does it damage the car in anyway? Thanks |
11-05-2014, 05:09 AM | #9 |
162
Rep 2,399
i dont know how you know. but the car will run abit rougher until the regen. i think sometimes you can feel it when your in the seat it regenning. nothing on dashboard as far as i know
I had the DPF light on mine a couple of months ago and it came on everyday for around 3 weeks till i was able to take it down to Bristol so in the 3 weeks i had it come on everyday till it regenned Doesnt mean its safe though so i dont know but i used it and had no problems. There is quite abit of chinese whispers to how it regens. some say you need to clear the code first and regen and same say needs to be cleared after it wont do it by itself etc but i dont know. mine sometimes regens on its own and goes away and other time i have cleared before and didnt come back after i took it on good run. if DPF is gone i would simply just remove and re map the car. should cost around £300-£350 |
11-05-2014, 05:23 AM | #10 | |
36
Rep 191
11-05-2014, 05:28 AM | #11 |
162
Rep 2,399
no. you will need INPA to clear codes which is diagnostic tool. or any other diagnostic tool should work.
11-05-2014, 05:38 AM | #12 |
Rep 476
lol @ this. Try doing 150mph. That should fix it.
damn, didn't finish typing. Go get the codes read and go from there. Simple thing to do. Regardless of "chinese" whispers. Regen is affected by temp. This is very likely to be your problem. |
11-05-2014, 05:51 AM | #13 | |
162
Rep 2,399
I think there is more reasons to car not regenning than just temp. |
11-05-2014, 07:53 AM | #14 |
Rep 8,092
Or do 60 in a lower gear??
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
11-05-2014, 08:05 AM | #15 |
Rep 686
Point number 3 from the OP's first post
3. I use my car regularly and commute 40 miles each day going 70mph+ hence thought the DPF should regenerate and not have this issue, so I am led to believe. This should be sufficient for a regen i doubt that BMW would sell a car that you have to break the speed limit to enable a regen.....? Point 4 could supply the cause as it was a one time action that has triggered the error it could be this event or its coincidence. 4. One point to note is that I went through a very big puddle under a bridge which was kind of flooded and thought to turn back instead went thought it very slowly. The light literally appeared minutes after and has never come on before. So perhaps could it be that the exhaust is just damp and it will dry out and the warning light will go away? Or is that just wishful thinking? Could it be that some water has got into the exhaust or onto a sensor or if the exhaust was hot enough cracked something?. As alot have already said i would get the code read and then cleared and go from there. It may well never come on again or if it does then i would start looking into checking engine temps etc to make sure its not some other problem thats causing a knock on effect |
11-05-2014, 09:09 AM | #16 |
36
Rep 191
11-05-2014, 09:10 AM | #17 | |
36
Rep 191
Thanks Borinous |
11-05-2014, 09:14 AM | #19 |
Rep 686
No idea im afraid i bought myself a cable (£40) and have the BMW diagnostic tools installed on my laptop. Where abouts in London are you maybe there is a Forum user who can help out?
11-05-2014, 09:56 AM | #20 | |
36
Rep 191
Oh am I able to do it myself using my Laptop? Does the BMW Tool Software cost also or is it downloadable for free? And where can I get the cable from - does it just connect into the OBD port? Thanks |
11-05-2014, 10:30 AM | #21 | |
162
Rep 2,399
think there about £40 with cable and disk on ebay. and yup goes into OBD port Buying one yourself will help you in future if any other problems arise. well worth the money and loads of DIY's here how to use the programs |
11-05-2014, 03:05 PM | #22 |
20
Rep 177
Nee to get the code cleared before trying to take for a spin once a code is logged it won't regen all your doing is blocking it further to the point where even a forced regen won't work
