New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > E89 Z4 Photos / Video / Media Gallery
      09-07-2016, 05:48 AM   #23
Fazerfahrer
Fazerfahrer's Avatar
Germany
58
Drives: 330d touring F31, Z4 35is E89
Originally Posted by jake169 View Post
Thanks for that detailed info Thorsten. Regarding 'boottming out', you interpreted correctly. I am heavily considering the Eibach springs, but don't want to get springs now and if I don't like it, then get the KWV3. Guess I will just wait till I save up for the KWV3. What spacers are you running in the front/back.
Thanks.
Jake.
Hi Jake,
i don`t use any additonal spacers. Please keep in mind that the 437M have the same offset as for example the 326M but are each 1" wider (9" & 10" x 19"), therefor you have the same effect than with 326M plus 12,7mm spacers on each side/wheel.
Regards Thorsten
Our rides: Skoda Octavia Combi RS TDI DSG / company car // E89 Z4 sDrive 35is / my summer fun toy // F31 330d touring / daily driver of my wife
      10-07-2017, 08:10 PM   #24
Seaice
Seaice's Avatar
47
Drives: 2020 Z4 30i
Type 276 with 15/10mm spacers
      06-14-2019, 04:10 PM   #25
taranfx
Z4 35is
taranfx's Avatar
Drives: 2011 Z4 35is || 2016 435i
Originally Posted by Zteve View Post
VMR V803
19x8.5 +35
19x9.5 +35
20mm spacers front
15mm spacers rear
Lowered on Eibach springs
what is the width of tires?
2011 Z4 E89 35is 2016 435i GC m-sport
      06-14-2019, 10:13 PM   #26
Zteve
Zteve's Avatar
Drives: Z4 sdrive35i
225/35/19 front
255/30/19 rear
2011 Atacama Yellow Z4 35i FBO
My Car Pics on Flickr
      10-27-2019, 06:11 PM   #27
orionx
Drives: z4 e89
Exclamation Advice needed on fitment
Question: How much extra space do we have between F/R stock wheel and stock suspension strut? Would a wider wheel that is 26mm closer to suspension strut cause rubbing?
A friend has a set of 9Jx18 ET42 square setup with 235/45 tires to sell and I'm wondering if this setup would work or not.
It seems like the front wheels will be 25.7mm closer to suspension struts whereas the rear wheels will be 8.4mm closer and poke out 4.4mm more. In the attached pics, orange lines denote the recommended stock setup whereas green lines denote the 9Jx18 ET42 setup.
URLs to actual calculations:
Front --> https://www.willtheyfit.com/index.ph...h=9&offset2=42
Rear --> https://www.willtheyfit.com/index.ph...h=9&offset2=42
Got the recommended stock specs from here:
https://www.wheel-size.com/size/bmw/...ve35i-usdm-300
Front: 8Jx18 ET29, 225/40ZR18 88W
Rear: 8.5Jx18 ET40, 255/35ZR18 90W
      10-28-2019, 10:21 AM   #28
scootr
scootr's Avatar
Drives: E89 Z4 3.0 6MT
10 front
18 rear
35 offset 17s
      08-15-2020, 01:07 PM   #29
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
Finally made the switch
ERnie
2016 BSM/f80/ZCP
      08-17-2020, 02:07 PM   #30
shockin330i
798
Drives: 2016 ZCP M3
Well that didn't work. Let's try this again...
ERnie
2016 BSM/f80/ZCP
      12-26-2020, 08:38 AM   #31
Z4Fool
13
Drives: E89 35is VO
Originally Posted by f5joe View Post
Damn right!
      02-25-2021, 05:27 PM   #32
buiyaa
Drives: 2015 BMW E89
BBS wheels on black 35is
2015 35is
H&R springs
BBS CI R (satin bronze)
Michelin Pilot Sport 4S
Front:19x8.5 et 35mm. 235x35x19
Rear: 19x9 et 44mm. 265x30x19
No rubbing issues at all.
      06-07-2023, 07:40 PM   #33
shadowe89
Drives: BMW Z4 E89 3.0i
Originally Posted by Fazerfahrer View Post
Hello,
I'm riding the M437 in 9x19 ET29 with 235/35-19 and 10x19 ET40 with 265/30-19 Goodyear F1. This set up should be close to your proposal. Springs are Eibach Pro Kit.
Sorry to revive an old post. But I just have to ask, did you do any other modifications to not rub?
I just picked up a set of 788M wheels 19x 9J ET 25 and 10J ET40 I want to know if these will rub.
I see Fazerfahrer isn’t active anymore but does anyone else have some input?
2011 E89 3.0i N52 stock suspension
      06-08-2023, 03:28 AM   #34
B21
B21's Avatar
153
Depends on the tyres but with 235/35 and 275/30 you should be ok..assuming stock geometry
      06-10-2023, 02:10 PM   #35
shadowe89
Thanks brother!
      07-01-2023, 01:11 PM   #36
spadman
125
Drives: Z4 35i; X4 35i, M850i G16
2013 Z4 E89 35i Wheel setup
      08-15-2023, 05:40 PM   #37
Sachak
Drives: 2009 E89 Z4 35i sDrive DCT
2009 Z4 35i
Continental sport contact 6
235/35/19 front with 15mm wheel spacers
275/30/19 Rears with 10mm wheel spacers
ISC Coilover suspension
https://e89.zpost.com/forums/attachm...1&d=1692139002
zpost
