Fishtailing
01-28-2014, 07:11 PM | #1 |
Rep 88
Fishtailing
So Atlanta is getting a few inches of snow today and I decided to do some spirited driving entering a parking lot. As I made a turn into the lot, I gassed it and to my surprise my 330xi's ass-end fishtailed like a RWD. This is my first snow experience with the car. I don't recall my old A6 Quattro behaving anything like that. Granted Quattro is a much better snow technology than xDrive, but I am still surprised. Is this what others experience with their xi's?
Thanks! Mike |
01-28-2014, 08:27 PM | #2 |
40
Rep 124
Drives: s2000
That's normal, Audi's are FWD biased and BMW's RWD biased. An Audi will overpower the front first, a BMW the rear first.
̶m̶2̶0̶ > ̶m̶2̶0̶ > ̶m̶2̶0̶ > ̶s̶1̶4̶ >F20C->1̶.̶8̶t̶-> n54
01-28-2014, 10:45 PM | #3 |
Rep 1,188
Drives: 2008 e92 335xi
Seems odd to me. Were you playing with DTC or DSC modes? Quattro Torsten systems have 50-50 splits whereas xi/xdrive is 40-60 so there isn't that much difference. Coming from my old A4 Quattro the BMW fishtails ever so slightly in the situation you were describing, but then DSC kicks in and points you in the right direction.
01-28-2014, 11:16 PM | #4 |
Rep 1,681
RWD based AWD will fishtail. My FX is AWD, but based on RWD platform and I fishtailed a little bit in the same snow today. It's pretty advanced AWD too based on the Attessa system from the Skylines. Glad I wasn't in the E92, I saw a lot of RWD cars having trouble with hills. It was also getting icy, so even with AWD, at some point the tires just lose grip.
01-29-2014, 08:30 AM | #5 |
Rep 88
I would have thought with all of the 'sensing' going on that the AWD and traction control would save me from myself, but I guess not. But at least I wasn't one of the RWDs having trouble getting up hills.
01-29-2014, 08:43 AM | #6 |
Rep 956
I was going to drive the my 335i today for work but didn't want to risk it so I ended up driving the TL. What type of tires do you have? Think winters would've had more grip?
If I drove my 335 more, I probably would've bought winters for the car.
2008 E93 M3 (Jet Black/Black) - SOLD - Progress Thread 2007 E90 335i (Jet Black/Terra) - SOLD Instagram: @aluooo |
01-29-2014, 08:49 AM | #8 | |
226
Rep 2,387
Rest of you guys down south, this is a great opportunity to play around with your cars in empty parking lots, see how they behave in snow and ice. Play with DTC/DSC button. BTW have read Xdrive at low speeds and sharp steering angles goes RWD only. |
01-29-2014, 09:06 AM | #10 |
226
Rep 2,387
01-29-2014, 09:11 AM | #11 |
Rep 43
01-29-2014, 09:17 AM | #12 |
226
Rep 2,387
Yeah it has to, it basically has an ordinary unbroken rear drive shaft and the transfer case only engages or disengages front driveshaft. Rear is always engaged IOW, and front can get no more rotation than rear.
01-29-2014, 09:50 AM | #13 |
Rep 88
01-29-2014, 09:55 AM | #14 |
226
Rep 2,387
Aha, well one might infer then that your tires had something to do with what was going on. AWD does not repeal laws of physics.
01-29-2014, 10:34 AM | #15 | |
3442
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
01-29-2014, 10:55 AM | #16 | |
Chief Executive
304
Rep 2,889
Drives: 2008 335xi 6spd Coupe
If it's snowing out, I hit the DTC button right away, no matter what. With that setting, this car behaves like a normal AWD vehicle, and if you want, will allow you to send the ass out much more "normally" With it all off, the car is hilariously fun, but basically a sled. As noted above, your summer tires were probably the largest player in that condition. |
01-29-2014, 12:59 PM | #18 |
Chief Executive
304
Rep 2,889
01-29-2014, 01:01 PM | #19 |
226
Rep 2,387
Missed this comment earlier. System cannot go 100% front, at most 50%. As noted earlier rear axle cannot be disengaged. I know what BMW marketing says they are being dishonest.
01-29-2014, 01:38 PM | #20 |
Rep 4,773
ahh too true.. you are correct sir
e90 330 > e90 LCI N54 > e70 x5 50i > f12 M6 GC > f15 x5 50i > f90 M5
01-29-2014, 02:54 PM | #22 |
Rep 88
Thanks for all of the great discussion. I am going to go with it is normal for a heavy foot, large steering input, and slow speed to result in an ass-end that fishtails on an xi. Yes, tires will play a role in how dramatic that fishtail is, but there is enough torque in these cars to make any tire compound/tread-pattern/etc. break loose. I guess one thing I failed to mention is that my 330xi has a manual transmission. That probably has little to do with what happened, but it does eliminate the possibility for any slip in a torque converter.
