04-11-2017, 09:38 AM | #23 | |
Rep 648
/Krelle
Ist der Motor kalt, Gib ihn sechs ein halb.....
04-11-2017, 12:22 PM | #25 |
52
Rep 276
PS: Beware that the AH3 isn't the easiest to flash. I had to go back to BRP twice, and it looks like afranke is also encountering some (maybe the same?) flash issues.
04-11-2017, 12:56 PM | #26 |
Rep 1,295
No indeed there seems to be some complexity with the hybrid drive. Do you remember which drivetrain malfunction code you got on the first attempts?
proTUNING Freaks do you have some info to share on our AH3 tuning? Darkiedm4 wrote me back to say you're not far from figuring it out, I'd really like to know what you found/learned in the process or compromise (if any) we have to make. I'll probably plan something in coming weeks with Darkiedm4 @ pureturbos.eu indeed if i can get more specific info to confirm it's working fine - like you say your experience with BR showed it wasn't very straightforward, i'm lucky to have afranke being first with AH3 on bm3
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
04-11-2017, 01:10 PM | #27 | |
52
Rep 276
And the two times I went back I could feel the torque was decreased, but the car is still fast. I have a feeling this is the cause: The Electric motor delivers up to 230nm. Did you know? https://ci-portal.zf.com/global/medi..._DataSheet.pdf If that's correct, the N55 is not supposed to go give more than 470NM. If it does, it will result in the error because the gearbox can't handle more than 700nm. I'm not 100% sure about this theory though. But I'm pretty sure I had the same error as afranke. In any case your car will be in very good hands at Darkiedm4 . Give me a sign when you know the date. It's only a 10 minutes drive for me . Last edited by frackje; 04-11-2017 at 01:21 PM.. |
PeterPure677.00 |
04-11-2017, 01:20 PM | #28 |
Rep 488
The problem I'm encountering appears to be the same as the code being thrown is telling us the maximum total torque is exceeded (what a problem to have, right?), but the behavior itself is a little odd. The most recent appearance of the code I was cruising at 60MPH in Sport mode with the trans in Sport, 30% throttle, 6th gear, 2200-2300RPM. I can't imagine torque is exceeding 470NM in that scenario.
In any case, proTUNING Freaks are FANTASTIC and I'm highly confident that they are close to a resolution for this issue. The map itself I have right now is just awesome, and feels MUCH better than the JB4 (so much so that I've removed the JB4 entirely for the time being). I can't wait to see what results we end up getting, but as always it will take some time and work.
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
04-11-2017, 01:26 PM | #29 | |
52
Rep 276
04-11-2017, 01:27 PM | #30 |
Rep 1,295
Indeed the case you mention isn't likely to result in exceeding 700Nm... i wonder if the DME has some bug in calculation, or if another table needs to be updated to change the torque calculation.
At least with the JB4 the DME didn't think the torque had changed and isn't throwing any code, but the gear shifts are very brutal because of this, which is why i want to move tho bm3 Afranke you just convinced me to take the plunge with your last post @Frackje sure I'll let you know when i'm there, will be good to meet for real at last |
04-11-2017, 01:28 PM | #31 |
Rep 488
If you're talking current dyno numbers, can you open and save my WinPep8 files with the correct correction factor? The current version available doesn't seem to have STD anymore.
04-11-2017, 01:49 PM | #32 | |
52
Rep 276
But I'm not certain yet. The PDF also says 440NM Wet Clutch => Any idea what this means? Can you explain the brutal shifts? How much KM do you have? You don't have an acceleration video by any chance? |
04-11-2017, 01:52 PM | #33 |
52
Rep 276
04-11-2017, 02:09 PM | #34 | ||
Rep 1,295
This shows with a shift that insn't smooth for me compared to stock, i.e. when shift occurs you get a sudden torque surge when new gear is engaged, that can't be good for the transmission. That's a problem you don't have with a remap because the dme knows the real parameters and calculates torque accurately. |
04-11-2017, 02:48 PM | #35 | |
52
Rep 276
I have no idea about that, interesting theory. You don't have a video of your acceleration with the current settings? |
04-11-2017, 03:14 PM | #36 | |
Rep 1,349
Drives: BMW F80 M3
Then drilling a hole takes less time. But when you make a hole, always water could enter. If you take your time to properly open and seal the DME, then I dont see any issue with that method. Greetz, Peter |
04-11-2017, 05:22 PM | #37 |
Rep 488
So as it turns out DynoJet added STD back into WinPep. Thank god, that was a stupid move on their part. These are the dyno runs from my most recent flash running relatively low boost (only about 13 psi IIRC). Just got a new map from them, so back to testing!
04-11-2017, 08:21 PM | #39 | |
Rep 648
I'm just letting out information showing that even though you're super careful, the result isn't always what you like it to be. The rubber plugs prevents water ingress just fine when you apply a little sealant. Btw turbo project is progressing Hope to be all set for the May track day's How are you're new Super car doing? Greetings Krelle
04-12-2017, 05:56 PM | #40 | ||
1086
Rep 2,374
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
04-12-2017, 05:57 PM | #41 | ||
1086
Rep 2,374
(A Dane in China) |
04-13-2017, 06:37 PM | #42 |
Rep 709
When was the last time you did spark plugs? Graph looks a little rocky at the top end
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger |
04-18-2017, 08:53 AM | #43 | |
Rep 931
Hi Have been installed the HJS 300 Cell DP on the ah3 ?
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
04-19-2017, 02:34 AM | #44 |
Rep 1,295
No. I'm actually freezing my spending on the AH3 as I'm considering swapping for a used F80 M3 as they're starting to show up at more reasonable prices.
My work on chassis has been very educational so that now get a very good understanding of why and how an F80 chassis and engine is better, and since french regulations are very mod-unfriendly I'm thinking perhaps reverting the AH3 to stock in coming months, selling my aftermarket parts, and get an M3 is the way to go. For piece of mind.
GTBrandon260.00 |
