01-13-2020, 11:33 PM | #67 |
Gettin It Figured Out
1823
Rep 2,669
not necessarily.. .
01-13-2020, 11:36 PM | #68 |
Rep 928
Would it work with the Supra pump hpd6 evo pump? Basically want to go with a pump that will run on a factory tune so I can pass an emissions test if needed.
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
01-13-2020, 11:40 PM | #69 | |
1823
Rep 2,669
No reason why it wouldn't .
01-13-2020, 11:43 PM | #70 |
Rep 928
That's probably the most powerful pump that would right? The xi-35, spool, and dorch engineering all wouldn't run very well with an ots or mppk tune right?
01-13-2020, 11:45 PM | #71 | |
Rep 5,399
Remember that a tune like BootMod3 only suppresses the CEL from popping up on your dashboard. An emissions test will still see it as soon as they plug into the OBD port under your dash. |
01-13-2020, 11:49 PM | #72 | ||
Rep 928
01-13-2020, 11:50 PM | #73 | |
1823
Rep 2,669
All pumps are capable of running any Map...including S1. Only difference, XDI, SPOOL and Dorch need the calibration files to run. With the exception of the HP6, if you ever have to flash back to stock and lock DME, your car won't run .
01-13-2020, 11:53 PM | #74 | ||
Rep 928
01-13-2020, 11:55 PM | #75 | |
1823
Rep 2,669
Obviously you'll still need a custom tune to maximize your pump .
01-13-2020, 11:59 PM | #76 |
Rep 928
Yep I plan on having a custom e50 tune along with 93 octane stored in the cloud.😎
01-30-2020, 03:56 PM | #77 |
@_sunbish
284
Rep 611
These pumps are weak and stressed when trying to run ethanol. I feel as my vehicle runs good with map E30 v7.0, even though I know my HPFP pressure drops, but it still runs smooth. I want a good race fuel map, since it is less stress on the HPFP, but that makes more power.
01-30-2020, 08:13 PM | #78 | ||
68
Rep 241
I found my logs to actually be much cleaner than 6.4. They werent bad before but i did have some timing pulls here and there and now there really arent any. Power actually feels smoother in delivery at low rpms. My only gripe is that seems HP isnt increased much so after the significant low end torque you dont make much more power north of 4.5k rom which leaves things feeling a bit flat. |
01-30-2020, 08:24 PM | #79 | |||
119
Rep 289
01-30-2020, 08:39 PM | #80 |
Rep 1,105
It's odd how people chime in with the comment of zero issues with v7 but when asked for logs, it shows overboost and HPFP crashing.
Stop relaying on your butt dyno people and start logging more often. Just because it "feels" a certain way it doesn't mean all is well. |
01-31-2020, 10:55 AM | #82 |
Rep 1,499
Not necessarily. You can make a copy of your stock tune then click the upgraded HPFP option in the customization menu and flash.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
ronanz1822.50 |
01-31-2020, 11:17 AM | #83 | |
1823
Rep 2,669
Ahhhhh......GREAT point! .
01-31-2020, 11:28 AM | #84 |
181
Rep 252
Drives: 2017 Model S P100D
Made a quick log with v7.0
It looks like there is a dip halfway through on one of the parameters even though I was WOT. Anyone have an idea of what's going on? It was a second gear pull not third if that matters http://www.bootmod3.net/log?id=5e2f795dae729b14a40e9238 |
01-31-2020, 11:34 AM | #85 | |
Rep 1,499
That's throttle closure due to overboosting. You can see your boost target is 17.2 but you hit 20.2 so the DME closes the throttle. This seems to be consistent behavior for this version. I'm not sure if it is expected or not. Not much explanation from Halim at PTF.
01-31-2020, 12:50 PM | #86 | |
119
Rep 289
01-31-2020, 03:01 PM | #87 | |
181
Rep 252
01-31-2020, 08:21 PM | #88 | |
68
Rep 241
http://www.bootmod3.net/log?id=5e2acc10ae729b2690cc2720 http://www.bootmod3.net/log?id=5e2ebc6aae729b43f9a73e69 |
