04-10-2024, 02:57 PM | #1 |
Rep 4
E-Sys error while flashing REM in 2012 F30
Hello,
recently I retrofitted my F30 with LCI taillights. It soon turned out I can't code them properly because my car is too old and it lacks parameters in ECU that can be coded... I've read that the way to solve this is to flash REM with more recent version. I'm using E-Sys 23.04.00. PSDZData is 4.39.20, I'm using full version, not lite. I-Step shipment F020-12-11-505, target F020-22-11-510, current F020-15-03-504. I followed the Flashing ECU Guide v.1.0.1 pdf dilligently. When I start TAL exeuction I get the following error: Read SVT Reference failed! [C912] MCDError Severity: 2051, Error Code 49184, Description: Object with name not found, Vendor Code:3, Vendor Description: provided name READ_SVK_REFERENCES_FROM_VEHICLE doesn't map to an item [2130755616]. I thought that maybe it had to do with an issue I ran while generating SVT Actual. Read (ECU) incl. smart actuators throws an error: Read SVT (with SMAC) failed! [C889] MCDError Severity: 2051, error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name READ_SMAC_CONFIG_FROM_VEHICLE doesn't map to an item [2130755616]. Read (ECU) without smart actuators and Read (VCM) work but I still get the exact same error while trying to flash. I'd really appreciate some help. I'm at my wits' end. |
04-11-2024, 03:50 PM | #2 |
Rep 530
Something wrong with your FA. Second did you check for dependance
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
