E91 N47 320D - Complete loss of power over 3k revs
08-11-2017, 03:11 AM | #1 |
Rep 11
Morning all,
Looking for some help please. I have a 57 plate N47 (D20A) 320d touring. Timing chain failed so I replaced the engine. Car starts and runs great, revs freely up to 4k etc. The problem is when its driven under load, its pulls well up to 3k revs then completely loses all power....almost stalls but doesnt quite then recovers to drive fine under 3k and does the same if i go beyond 3k revs. Checked the live data and all looks normal except the fuel 'pre supply pressure' this drops significantly down to 1 bar when i hit 3k rpm. I compared the live data with my 120d and all parameters match except the pre supply pressure which drops to around 9 bar when i hit 3k rpm rather than the 1 bar. Im thinking its either the pre supply and might replace the pump in the tank....or its a red herring and the pre supply dropping when i hit 3k rpm because the ECU is telling the car to go in to limp mode.. Any suggestions would be greatly appreciated. Thanks in advance, Kris. |
08-17-2017, 02:54 AM | #5 |
Rep 11
I thought it may be turbo related - over-boosting. But when it gets to 3k it loses all power, not just the boost.
Anyway the turbo and the actuator have both been replaced and didn't cure it |
08-23-2017, 10:45 AM | #6 |
Rep 11
I Still haven't managed to find a solution to the above problem.
When i replaced the engine i used the engine loom from the donor car (318d) and not my car (320d). The replacement engine has the exact same engine code but does anyone know if there is a variation in the loom that could be causing my problem? |
08-28-2017, 02:52 PM | #7 |
Rep 1,993
Drives: F30 335d
Did you swap over your injectors from your old engine to the donor engine?
if I've helped - an Appreciate would be, er, very appreciated!
09-01-2017, 10:50 AM | #9 |
Rep 1,993
Drives: F30 335d
Ok, I think it's only the injectors that are different between the various engines.
I would go with your original suggestion and look at the fuel supply.
09-14-2017, 09:20 AM | #11 |
243
Rep 2,026
i doubt that would have anything to do with it.they are not numbered.and when you have a replacement injector it would have to be same number..i m sure it will be fuel pump related,,on another note..have you changed the fuel filter recently..been known to cause all sorts of probs..
09-16-2017, 04:32 PM | #12 | |
Rep 1,993
Drives: F30 335d
Having the injectors swapped round without updating the ECU means they won't be running as efficiently as possible.
09-16-2017, 04:34 PM | #13 | |
Rep 1,993
Drives: F30 335d
09-17-2017, 01:30 AM | #14 |
243
Rep 2,026
when replacing fuel filter.its best to fill it up with a bit of diesel,then when fitted,turn key in ignition without turning car over,this primes the fuel line using the fuel pumps,although on a push button start car i guess this is not possible...or is it?
09-17-2017, 07:38 AM | #15 |
Rep 1,993
Drives: F30 335d
Yes that's what you do, you just don't put the clutch pedal down, pushing the button will turn on the ignition but not start the motor. Sorry, I didn't make it clear in my earlier post.
09-17-2017, 06:41 PM | #16 |
Rep 1,247
We have a 16 plate Mini Cooper SD with the N47. A couple of weeks ago this threw an error on the dash showing restricted performance, proceed to a dealer. This came up a few times and resulted in the car not being able to accelerate above 80mph. There were probably issues at lower speeds but the car didn't throw the issue until on the motorway.
BMW Assist came out and diagnosed a faulty EGR Valve which, once replaced cured the issue. |
06-26-2018, 03:14 AM | #19 |
Rep 11
Solved!!. Tried lots of different sensors, diagnostics, premium fuel, new turbo, egr etc. Plugged the car in to a new diagnostic system last week and did a standard 'erase all codes' and the problem is gone. Must have been a historic fault code that was throwing the car in to limp mode over 3k rpm
03-11-2022, 07:53 AM | #20 |
Rep 20
Just to add here, injectors can be coded to the car in the DDE service functions in ISTA. These N47 engined cars also have a fuel bleed service function which should be used whenever the high pressure side or fuel filter has been changed. Although they will self bleed eventually, this service function should be used rather than spinning the engine over till it starts to avoid potential high pressure pump damage.
3k revs, loss of power, n47, presupply |
