12-31-2017, 12:05 PM | #1 |
Rep 4,180
Brembo GT pedal feel
I recently tried a friend's car with AP Racing bbk and the pedal feels much firmer than my M3 with Brembo GT bbk. Is this normal?
01-01-2018, 09:02 PM | #2 |
Rep 1,083
If you are using the brake pads that came with the Brembo GT, then yes the pedal feel as well as the stopping power will not reflect the capabilities of these brakes at all.
Perhaps you can ask your friend what pads he's using on his AP.
01-02-2018, 02:08 AM | #4 |
Rep 4,180
KW V3, forgot what tires but I think they were PSS. I have Ohlins R/T and Advan AD08R rubber.
How would suspension/tires affect pedal feel? |
01-02-2018, 03:16 AM | #5 |
Rep 12,736
pad compound will influence pedal feel more than anything. another factor is rotor design- are his rotors slotted? slotted vs drilled rotors has been debated to influence pad bite. another factor is fluid and stainless lines.
Instagram; @roastbeefmike
01-02-2018, 11:33 AM | #6 |
1446
Rep 1,614
Movement of the car through suspension may cause more brake effort due to the feeling of the weight shifting under braking.
R compound/slick tires requires more effort to stop when cold along with the pads. Pad compound plays a huge role. Also, maybe there is a little air in your system. Are both brake boosters the same? Brake booster pressure plays a role as well. The brake booster for cars with ceramic brakes is different than steel. |
01-02-2018, 06:07 PM | #7 |
Rep 476
Drives: e46 M3, e82v8 (s65 swapped)
hub bearings condition add a lot of pedal travel feel.
01-02-2018, 06:15 PM | #9 |
Rep 628
When I first installed my GT kit, I felt the same way. It didn't bit as hard as the stock brakes, but now I have come to love the pedal feel because you get so much more feel for brake modulation.
01-02-2018, 06:28 PM | #10 | |
Rep 4,180
Looks like may just be a difference between Brembo and AP products. |
01-02-2018, 06:29 PM | #11 |
Rep 4,180
Ok that's good to know. Cos I got my Brembo GT used and was afraid there may be something wrong with the calipers. Car stops very well, just the feel wasn't as good as stock or the AP.
01-02-2018, 06:53 PM | #12 | |
Rep 476
i had front bearing with play more then a year, and it didn't make any sound. i've seen it only when fitted winter wheels without spacers, with 2mm caliper to rim's spokes clearance. one side worked okay and on other spokes touched caliper under braking or cornering even without applying brake. also i had a problem before bearing was changed, that pads on this side overheating a lot quicker and worns two times faster. i saw similar problems on different cars (bmw, vw etc), and all of hubs make no sound. if you have trackdays (or regular fast driving) time to time, after 50k miles you have a lot of chances to get worned hub bearings. |
01-02-2018, 06:54 PM | #13 |
Rep 476
01-02-2018, 07:37 PM | #15 | |
Stop the hate, get a V8
3853
Rep 8,625
Honestly, it's hard to pin this down to a single reason. It could be a combination of things. A braking system is just that: a system. There are many components and it could be a lot of little things that add up, or it could be a bit of a placebo effect. You'd have to set up some pretty strict testing conditions to narrow it down. Ideally, something like this: same car, pads, fluid, track temperature, ambient temperature, airflow, etc. I also missed my chance for "inb4 because Brembo sucks".
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
roastbeef11591.50 |
01-02-2018, 09:36 PM | #16 |
Rep 4,180
I had the hub bearings checked numerous times by mechanic and alignment shop and all said no free play, no need to replace.
Lol. So much hate for Brembo? 😂 |
01-03-2018, 12:51 AM | #17 | |
Rep 1,083
AP is wonderful Brembo is great Alcon is pretty nice
jritt@essex1029.00 |
01-03-2018, 07:59 AM | #18 |
Rep 10,672
I vote difference in brake pads. Buy the pads your friend has if you have driven his similar car on a track similar to what you run on. Don't go by how they feel on the street and assume that is how they feel with heat in them on the track.
01-03-2018, 09:23 AM | #19 | |
Rep 12,736
vw owns porsche. porsche is better than vw. sup?
01-03-2018, 09:29 AM | #20 |
Rep 1,083
Porsche brakes are the best
01-03-2018, 10:22 AM | #21 |
Rep 1,934
zamboni1132.00 leftfootbr8king569.50 |
01-03-2018, 01:04 PM | #22 |
Rep 1,055
Seems you may be referring to bite. If so, then feel is going to be heavily pad dependent. More track oriented pads will not bite as well/feel mushy when not in optimal operating range.
You both would have to run the same pads for a better comparison, without factoring in the aspects others have mentioned. I run Hawk HPS 5.0, which is a street pad. Even then, the initial bite is not as good as oem when cold. Once up to temp though after a few stops, then it bites much better than stock.
aFe Stage 2 Intake | BW Race X-Pipe | UUC Corsa Exhaust | Alpine MS Tune | Brembo GT
