TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Coding options for BimmerGeeks ProTools app.
      10-27-2020, 03:56 AM   #1
Serf27
Serf27's Avatar
2851
Drives: 335i
Hey all, I made this list for my own agenda and figured I’d post it here for everyone else to use.
Here is a list of options that can be coded via Protools.
I will edit the post and add more options as I find them, or add options that someone else posts in the comments. Feel free to comment other options you’ve used!
A quick guide on how to code options.
Example: Setting fog lights to welcome lights.
(1st selection-Main category) Safety.
(2nd selection-Sub category) FRM.
(3rd) Coding
(4th) Edit coding
(5th) It will prompt you to make a back up. You can make a backup if you want to save your settings before changing anything else.
I made a back up for my E90 FRM. A back up is good in case a module is default coded and you lose all your settings.
Once in edit coding, you will see a “popular” category, this lists the options other people are coding.
Standard coding shows almost all the options available.
Expert coding has some things that are not in the standard category, but it’s not in English.
(6th Select what you want to code) Click welcome light fog lights
(7th Change the option to enable
(8th) Click finalize and done. Now your fog lights should turn on when you unlock your car if light switch is set to Auto.
I highly suggest coding 1 thing at a time so you can easily reverse it if you do not like what you have coded.
EDIT: New feature.
If you’re unsure of what you’ve coded, it now shows you all changes that do not match factory settings to the module you are viewing.
Click the module you want to view changes in.
Click coding
Click edit coding
Click tools at the bottom
Click view parameter changes
It will show you a list of things that do not match factory settings.
It’s easy to use, but use at your own risk!
These particular options were from an e90. All options should be similar on all E chassis Bmw.
NOTE! There is differences between FRM1/2/3 and other modules.
Some options may not be available depending on your model year/module.
Protool Codeable options:
Light bulb error delete.
Safety-FRM-Coding/Edit Coding-disable cold and warm checks of the bulb.
Turn signal blink count 3 to 5.
Safety-FRM-Coding/Edit Coding-Turn signal blink count(4 options) all set to active/5blinks.
Welcome light fog lights.
Safety-FRM-Coding-set welcome lights-fog lights to active.
LCI halogen angel eyes as DRL.
Safety-FRM-Coding-angel eyes as DRL(3)-set to USA.
Front turn signals as DRL.
Safety-FRM-Coding-DRL turn signals-enabled.
Front fogs as DRL.
Safety-FRM-Coding-expert mode-options(2) DRL_TFL_MIT_NSW
nicht_aktiv --> change to aktiv
PWM_NSW_TFL
wert_01-> change to wert_02
Fogs and high beams on at the same time.
Safety-FRM-Coding-fogs and high beams-disabled.
Double flash impulse hazard lights
Safety-FRM-Coding-double impulse hazard-enabled.
Double impulse hazards at crash
Safety-FRM-Coding-double impulse crash lights-enabled.
Driver window one touch up when door open
Safety-FRM-Coding-driver one touch up-enabled.
Folding mirrors /windows up with FOB.
Safety-FRM-Coding-folding mirrors with fob-enabled.
Folding mirrors/windows up with FOB.(cont)
Safety-CAS-Coding-comfort closing fob-enabled.
Unlock doors when engine shuts off.
Safety-CAS-Coding-unlock after engine off-enabled.
Auto lock via speed or accessory.
Safety-CAS-Coding-auto lock via speed-enabled.
Auto lock after accessory is turned on-enable option 1 and 2.
Close windows and sunroof with rain sensor.
Safety-CAS-Coding-close windows and sunroof with rain-enabled.
Wipers complete sweep and come down with key off.
Interior-JBBF-Coding-wipers complete cycle-enabled.
Digital speedometer on BC menu.
Interior-Cluster-Coding-digital speedometer-enabled.
Adjust bulb voltage output.
Safety-FRM-Functions-Adjust voltages-adjust whatever bulb you want.
NOTE! It is recommended not to exceed 14V on any bulb. I have adjusted some bulbs to 14V, but actual voltage on pigtail reads 12V.
Cold temp warning removal.
Interior-Cluster-Coding-temp warning-enabled.
TPMS delete-FTM enabled
Disconnect TPMS module first right rear on top of battery in trunk for pre LCI. Behind right rear wheel liner for LCI.
Vehicle-Vehicle options-Click edit-find and unselect $2VB-click save-click save both locations(CAS&FRM)- App will prompt you to default code CAS&FRM(maybe a few other modules depending on model yr)click ok.
Default coding your CAS/FRM will restore factory settings on them. Take notes of any options/changes you had in those 2 modules.
Default code/code in New/USED FRM.
Safety-FRM-functions-default code FRM.
Enjoy.
E90 335i-408WHP. Alpine over Terra brown
E70 X5 35i M Sport-Stage1 Tune. Alpine over Black
E91 328 M Sport-Alpine over Black-Alpine over Saddle brown.
E93 335i-DINAN tuned. Alpine over Saddle brown
Appreciate 5
      10-27-2020, 08:43 AM   #2
fgpalmer71
Drives: 2016 Genesis sedan 3.8 AWD
Thank you for this!!! Extremely helpful!!
      01-28-2021, 10:06 AM   #3
Derek Keenan
Derek Keenan's Avatar
10
Drives: bmw 335i
A quick run down for anyone not familiar with the app.
First selection will be the catergory, second selection will be the sub catergory, third selection will be the option you are coding, and final fourth selection will most likely be enable or disable.
You will have to click finalize after disable/enable is selected.
Example:
(3rd, the option you are coding) DRL Turn signals.
(4th) Enable.
(5th) Finalize.
Safety-FRM-disable cold and warm checks of the bulb.
Safety-FRM-Turn signal blink count(4 options) all set to active/5blinks.
Safety-FRM-set welcome lights-fog lights to active.
Safety-FRM-angel eyes as DRL(3)-set to USA.
Safety-FRM-DRL turn signals-enabled.
Front fogs as DRL.
Safety-FRM-expert mode-options(2) DRL_TFL_MIT_NSW
PWM_NSW_TFL
Safety-FRM-fogs and high beams-disabled.
Safety-FRM-double impulse hazard-enabled.
Safety-FRM-double impulse crash lights-enabled.
Safety-FRM-driver one touch up-enabled.
Safety-FRM-folding mirrors with fob-enabled.
Safety-CAS-comfort closing fob-enabled.
Safety-CAS-unlock after engine off-enabled.
Safety-CAS-auto lock via speed-enabled.
Safety-CAS-close windows and sunroof with rain-enabled.
Interior-JBBF- wipers complete cycle-enabled.
Interior-Cluster-digital speedometer-enabled.
Interior-Cluster-temp warning-enabled.
Tpms delete.
Interior-Cluster-tpms option 1,2,3-All disabled and tpms module must be disconnected.
Enjoy.
Can't code injectors?
Derek Keenan
Dpc2u11503.00
      01-28-2021, 10:07 AM   #4
Serf27
Serf27's Avatar
2851
Drives: 335i
Yes, you can code injectors.
      02-17-2021, 01:43 PM   #5
Steadyhand
52
Drives: E90, E70, F30, F97/G01 X3M
I would like to buy Bimmergeeks Protools and seem to be lost.
My DIY experience and capability with wrenches is at least a 7 out of 10 (don't have a problem dropping a transmission to install new solenoids type of DIYer, no gasket is too complicated and I successfully replaced two N54 turbos and coolant, lube, and air piping to boot).
I suck - have never done- coding, and am low-novice with diagnostics (using only the Schwaben 510).
I can't navigate the Master license purchase of Bimmergeeks Protools and the like - I messaged them, but no reply. I literally have no android apps to my name, never have, so google app store is foreign to me. I have no such phone or tablet, but am willing to buy whatever device needed just for this purpose.
Please get me pointed in the correct direction.
      02-17-2021, 04:36 PM   #6
Serf27
Serf27's Avatar
2851
Drives: 335i
This is the tablet I have. It was the cheapest I could find since I was only going to be using it for protools.
http://www.walmart.com/ip/RCA-Voyage...73W42/53990885
I think you either need to set up a google account in the tablet settings with a debit card or set it up through the google play store when you open the app.
Simply search protools and it should be the first app to pop up.
Once downloaded, you can enter the app and in the top right of the screen will be 3 dots that lets you accesses the licenses.
You purchase the master license through the app.
The app is easy to use once you navigate around.
This video I made should help some.
      02-17-2021, 08:58 PM   #7
Steadyhand
52
Awesome Serf! Huge thank you. Between our twins and myself, we have three E90s and each could use more help than the Schwaben can provide (coding or at least assigning VINs to some modules I have tried to replace...).
      02-17-2021, 10:57 PM   #8
Serf27
Serf27's Avatar
2851
Drives: 335i
Changing the vin is really easy with the app.
The coding options are nice too.
My favorites would be the wipers completing their sweep when the key turns off and when the driver window will auto roll up with the door open.
Mirrors folding automatically when car is locked is nice too.
      02-18-2021, 09:31 AM   #9
Pittz1
2018 M3 ZCP / 06 330xi
211
Drives: 330xi 2006 / 18 M3 ZCP
Nice work putting this together for people.
      02-22-2021, 01:22 AM   #10
Boosted12a
68
Drives: BMW 335i x
Good info!
      01-05-2023, 03:34 PM   #11
samrwil
samrwil's Avatar
Drives: BMW 335i E92
Exactly what I was looking for. Thanks!
      01-05-2023, 04:00 PM   #12
Serf27
Serf27's Avatar
2851
Drives: 335i
No problem!
I’ve written down a few more things I’ve found that I need to add here.
The app has been updated since the first post so some things may be different but relatively the same.
      01-05-2023, 08:59 PM   #13
Sgop335
Sgop335's Avatar
Drives: 07 335i e92, 08 535i
I saw in the first post, cold temp warning removal? Does it get rid of the gong while driving?
335i e92 TPC 19Ts
      01-05-2023, 09:15 PM   #14
Serf27
Serf27's Avatar
2851
Drives: 335i
Yes.
      01-28-2023, 04:47 PM   #15
trippleM
Drives: bmw 330i e90
Hey there i just got my protools all installed on to my windows 10 computer and i tried to code in a new frm module on a e90 and i get error check CABD and error message on NCS expert
Im thinking i need the new daten files? Could anyone help with this please!
      01-28-2023, 04:56 PM   #16
Tambohamilton
Drives: E91 330d
Protool is android software. You're probably meaning 'standard tools'...
      01-28-2023, 04:59 PM   #17
trippleM
Yes if thats what its called when its on the laptop then yes its standard tools i got it from bimmergeeks website
      01-28-2023, 05:06 PM   #18
39Xallday
Drives: BMW 335i
Thank you! Very helpful. Cold weather warning removal ftw!
      01-28-2023, 05:10 PM   #19
trippleM
I really need help coding a used frm module guys i keep getting a error message could you guys please help me out?
      01-28-2023, 05:11 PM   #20
trippleM
These are the error messages guys
      01-28-2023, 05:53 PM   #21
Tambohamilton
Drives: E91 330d
Google is your friend. This thread is about totally different software.
      01-28-2023, 05:57 PM   #22
trippleM
Tambohamilton
No bro this is the right thread. I know what help I’m seeking. I posted the pictures and these are the exact issues that everyone is having on this exact thread.
