TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      10-31-2016, 09:14 AM   #1
E70'11
Drives: || E70 35i | R32 GTR ||
New! Tuning Option (MHD FLASH N55) 35i E70/71
First off, I am not associated with nor do I represent MHD in any fashion there of. This is strictly an informative thread to let those who own a 2010-2013 X5 35i another tuning alternative.
I believe I am the first X5 35i to have successfully use the MHD tuning option. This release was just updated early this morning after speaking with MHD on options for our vehicles and another DME version they weren't aware of.
I'm sure some of you might have some FAQ's so below is the original post for MHD off the e90post
http://www.e90post.com/forums/showth...5#post20764655
Read the thread for more overview, make sure to follow the steps regarding the DME version.
First impression: I automatically feel no turbo lag from just taking off in the car itself. It drives very smooth, I feel constant boost and it does pull pretty hard for only being the stage 1 on 91oct. I wanted just a little pick me up and I feel it's been succeeded. I will try to find other ways to monitor how much boost is now being utilized. It has been said it has jumped from the standard 9 psi to roughly 12-14 psi.
I've used MHD tuning since they were first around and I've had zero issues with them
__________________________________________________ __________________________________________________ __________________________________________________ __
Below is some helpful info regarding the stages and how many lbs of boost/tapering with this tune per which stage/mods are installed to your specific vehicle.
Stage 1 is 12-13psi taper down to 9psi
Stage 1+ is 15psi
Stage 2 is 13-14psi taper down to 11-12psi
Stage 2+ is 16-18psi depending on fuel variant
While Stage 1+ might see a higher PEAK boost target it will taper very quickly. The reason for the increased taper is because the Stage 1 and 1+ maps were designed for a car with a stock downpipe. The stock downpipe has a restrictive cat in it that will cause EGT's to increase quickly. The taper is used to keep EGT's low to prevent turbo damage. The Stage 2 and 2+ maps were designed for catless downpipes which are less restrictive, there for EGT's are not an issue and boost doesn't need to taper as aggressively.
Stick with Stage 1+ for a daily map, if you want to play around you can run the Stage 2+ map but refrain from repeated pulls, give it a couple minutes to cool down. If it is hot outside, again do not make repeated pulls as your stock intercooler will heatsoak quickly.
***********************ATTENTION BELOW PER MHD TUNING*********************************
It's time for MHD to enter the open beta state on N55 E Series! You'll find below the product description.
The app is in an open beta state. It is fully functional but may need here and there some polish. Currently only the stage 1 maps (stg1 and 1+ for acn91-91-93-95oct) are available.
It won't take long before we add the stage 2 maps, maybe a week. So long the stage 2 maps are not available, you can purchase a stage 2 license and flash the stage 1 maps. And once the stage 2 are available, your stage 2 license will be valid for the stage 2 maps.
The user guide is a good place to start, especially is you need a reliable KDcan cable (page 5 of the user guide, available in the app or at http://www.twisted-visionz.com/mhdguide).
Have fun, drive safe and we're looking forward to your feedback - both in terms of logs and driving experience. The maps will quickly evolve as we get the precious community's feedback.
MHD Flasher is the first Android handheld application to bring ECU tuning and monitoring to the BMW N55 engine for E series. The MHD Flasher reveals the good margin of power BMW left on the table with the N55 while still retaining the sophistication of the original engine management program.
→ Easy to install
Connect any compatible Android device to your car using a standard K+Dcan cable along with an OTG USB adapter, install one of the pre-purchased MHD maps and enjoy the power and performance benefits of the MHD maps by Twisted Tuning.
→ Keep an eye on the tuning
Monitor your engine behavior using a configurable gauges layout to keep an eye on any of the 50+ engine monitors like oil temp, boost pressure, actual load or individual cylinder ignition timing. Activate the logging mode to save up to 50 monitors to a standard CSV file for later analysis. Track issues by reading the error codes, and delete them once resolved.
→ Flash your ECU back to a stock anytime, as often as you need to. No ECU backup is needed.
→ Custom tuning support
As an alternative to built-in maps, many tuners can provide advanced custom mapping for those who have higher or special performance needs.
The MHD Flasher can be downloaded here: https://play.google.com/store/apps/d...hd.flasher.n55
Main features description:
═══ Flasher module ═══
- Flash built-in maps (purchased separately), custom user-tuned .BIN files or JB4 flash maps.
- Provides an ever growing list of handy options like PPK exhaust burble duration or cold start noise reduction.
- Read / delete engine trouble codes.
- Reset adaptation values (Lambda sensors, Lambda regulation, Octane rating, VANOS, Throttle, and Battery).
- 4 minutes map switching; initial install time: 33 mins (this will be improved later)
═══ Monitor module ═══
- Extensive logging values list, up to 50 values at the same time.
- Save logging session to .CSV files
- Integrated csv log viewer
- Up to 8 configurable gauges
- Automatic or manual log session start.
═══ Optional MHD maps packs ═══
- Maps by Twisted tuning
- Stage 1 pack. Eight maps: 4 fuel octane variants, stock / upgraded FMIC variants.
- Stage 2 pack. Eight maps: 4 fuel octane variants, stock / upgraded FMIC variants. High flow downpipes recommended.
- Ethanol mix map (e30). FMIC+DPs recommended.
Supported vehicles: N55 equipped Exx series.
!!! Important !!! Vehicle equipped with a MEVD1726 DME (built dating from around 03-2012) need a once time DME removal and bench flash to allow OBD flashing. See FAQ below.
2010-2013 135i, 135is and 335i
2013-2015 X1 xDrive 35i
2010-2013 X5 xDrive 35i
2011–2014 X6 xDrive 35i
This racing product is for competition closed course use only.
Required hardware:
- 1 device running Android 3.2 and up, USB OTG compatible.
- 1 K+Dcan cable. See page 5 of the user manual for a recommended cable: http://www.twisted-visionz.com/mhdguide
- 1 USB OTG cable.
Price list (licenses are VIN Locked and stored by Google along your Play store account):
- Flasher module: $199
- MHD maps packs: $49 each. Requires the Flasher module.
- Monitor module: $69
FAQ
Q: Can I test the connection before making a purchase?
A: Yes, simply tap the MHD Store button. The ECU connection is checked before displaying available purchases.
Q: Does my Android device need to be permanently plugged to the OBD port?
A: No. Once a flash is performed you can unplug your device.
Q: Do I lose my licenses if I delete the app or the Android device breaks?
A: No. licenses are stored online by Google, you can use your purchases on another device as long as you use the same account on Play store.
Q: Do I need to purchase a new license each time I flash a map?
A: No, you can ref lash as many times as needed.
Q: Is a battery charger required?
A: It is highly recommended for long flashes (install, uninstall). A healthy battery will handle short flashes (map changes) fine but the use of a battery charger remains recommended.
Q: How can I determine if the DME is directly flashable or needs a one time bench flash?
A: got to http://www.realoem.com/bmw/enUS/select and enter the last 7 digits of your VIN in serial number. Click Browse parts the ENGINE ELECTRICAL SYSTEM and check both CONTROL UNITS > MEVD1726 section. If the it says "No parts found matching your car." you have a MEVD172 which is directly flashable.
2011 E70 35i MHD Tune Stage 2+ (CURRENT) Daily Driver
1989 R32 Skyline GT-R (CURRENT) The Hunter
2010 E90 335i 1M FBO MHD Tune (SOLD)
2009 E92 335i FBO JB4 G5 ISO (SOLD)
Appreciate 5
      11-02-2016, 11:27 AM   #2
Laguna Seca Blue
Laguna Seca Blue's Avatar
Drives: N54 E92 | N55 F15 | N55 E70
Surprised no one has responded to this! Awesome news. Making me wish I had the N55 now.
E92 335i 6MT | Balloon White | Black Dakota Leather - Sold
PROcede Rev3 V5 | AE Quad Exhaust | BMW Performance Short Shift Kit | Gunmetal 19" M3 GTS Wheels | BF Goodrich g-Force T/A KDW 2 | AST 4100 Coilovers | Swift Springs F:280 R:560 | ER Charge Pipe | Tial Blue BOV | VRSF 3" Downpipes | VRSF 7" Intercooler
http://www.e90post.com/forums/showthread.php?t=782212
      11-02-2016, 02:32 PM   #3
racermp
racermp's Avatar
Drives: F30 330i
haha i was gonna comment, great job on being the first. i am on jb stage 1, i just ordered a obd cable from the reference in the mhd guide. i'll probably try it on my n55 335i first, then use my other google id for the x5.
do you see better throttle response? have you tried the liner throttle option?
      11-02-2016, 04:33 PM   #4
E70'11
Haha right, I felt it was awesome news for us in the X3/X5/X6 world.
I think you will be pleasantly surprised with the MHD tune, just last night my vehicle just wanted to keep pulling even doing an 80 roll. I used the MHD on my old N54 335i and loved it. So I'm sure you'll see differences in both your cars
To answer your questions, yes there is a better throttle response which really makes a difference. I haven't tried the liner throttle option, this weekend I'll mess around with more settings after I find my tablet charger.
      11-02-2016, 10:14 PM   #5
mitch808
Drives: 2012 X5 35i
Of course there is cobb for select 2011-2012 models too. Much more mature and lots of protuners to choose from
      11-03-2016, 08:06 AM   #6
E70'11
That is very true also, granted I can't see myself spending over $500+ on that tune vs. this tune being way cheaper. Plus a protune is an option as well, maybe not as much because Cobb has been around awhile. However, MHD is still producing great numbers. N54 platform shows and I'm sure once more information about the N55 is shown you'll see the same trend.
      11-11-2016, 05:13 AM   #7
racermp
racermp's Avatar
Drives: F30 330i
Hey just curious, how are you liking the tune so far?
I just got it on my 335i n55 for test last night. Gonna do x5 soon
      11-14-2016, 09:16 AM   #8
E70'11
I'm actually enjoying the tune on the X5 honestly, I'll just randomly cruise and do a WOT lol It feels like it wants to just constantly pull through all gears which is nuts for just being bone stock.
Have you tested the tune out on the 335 yet? I know I enjoyed on my N54 335i(s) and stuck with MHD due to the products results
      11-14-2016, 11:12 AM   #9
Bklynjoker
Bklynjoker's Avatar
85
Drives: G20 %E2%80%9C22%E2%80%9D MSpor
How is the MHD flash done? I'm interested in it, alittle bored of BMS juice box.
DINAN just released a stage2 for N55's. calmed to produce 400 lbs Tq & over 355HP. But for a hefty cost $1,399
LeXxiNGToN aka LeXxDiAMoNDS
      11-14-2016, 01:22 PM   #10
E70'11
Yeah I wouldn't pay so much for just a tune honestly, you can get these things tuned and have bolt ons making more than that with less cost.
Check this post out from e90post and it'll show you EXACTLY what you need to do. Flash takes roughly 35mins, that is what I experienced and I have ZERO issues. It's still the BETA phase so eventually with more feedback and logging it'll produce better OTS maps. However, there is a noticeable difference and since you already have the BMS juice box. You can compare to see if it honestly is better for you/noticeable.
      11-14-2016, 01:31 PM   #11
racermp
racermp's Avatar
Drives: F30 330i
Hey, so i flashed my 335i (stg 1 93) on friday last week then after disconnecting the BMS stage 1 tune, i flashed the x5 stg1 93oct also.
the throttle feels a bit more responsive. i haven't driven enough on both to see a major difference. both cars are definitely way better than stock. do you feel your tranny upshifts a lot sooner? seems like the torque converter is locking up quicker.
haha yea it does want to pull to redline better than stock on both. smoother curve. i felt like the bms peaked higher at 3k rpm but this may be smoother. not sure need to drive me.
i did measure the boost, with bms, highest i got was around 10psi, this on my 335i n55 i'm seeing 12 psi. using torque app. i'll check the x5 soon. turbo sounds like it's spooling up higher.
Last edited by racermp; 11-14-2016 at 01:35 PM.. Reason: dumb question on stage 1, opps
      11-14-2016, 01:50 PM   #12
E70'11
Awesome man, sounds like a good experience as well if you ask me which will help out others reading this post. My tranny does wanna shift quicker which can be a good thing. I did hear psi is roughly 12-14lbs on the stage 1 MHD so if you're seeing that with your torque app it might be accurate.
Definitely keep giving feedback man, I'm sure the X5 will be the subject to test due to the weight difference of your 335. But either way the smoother quality of drive won't change from either vehicle
      11-14-2016, 02:18 PM   #13
racermp
racermp's Avatar
Drives: F30 330i
yea man, it's good stuff. for 250 + cable, sweet deal. i can only imagine stage 2+ on a x5 lol. gotta be insane enough to hang with a 335
      11-14-2016, 02:23 PM   #14
E70'11
Haha yeah it has to be for sure, if I was aiming towards FBOs in the X5 I surely would post up a review with some dyno numbers. But this is just the DD/family car so nope lol Weekend warrior is between a GTR or another Evo 8/9 again
      11-14-2016, 02:28 PM   #15
racermp
racermp's Avatar
Drives: F30 330i
hahah yea same here, x5 is wifes car, my weekender. 335 is my dd. fun bunny lol
      11-14-2016, 03:41 PM   #16
Bklynjoker
Bklynjoker's Avatar
85
My situation is im running SprintBooster so my throttle is light as a feather on D,it's not really useable because it always was to downshift to the lowest gear and fly. I always use Tiptronic shifting so I control my gears bacause SprintBooster(red mode) is Out of control wth the BMS. BMS without SprintBooster is child's play for the X5, times I've turned off the booster I feel like it's a 4cly turbo.
I really wish I can see what type of PSI im getting with the BMS. I have ICarly app pro but can't seem to get a boost monitor going.
Guys really invest in a SprintBooster I wouldn't bullsht you, you will never get bored of ur power, it really kills all throttle lag what's so ever.
      11-14-2016, 03:47 PM   #17
Bklynjoker
Bklynjoker's Avatar
85
Is this available for iPhone iOS??
      11-14-2016, 04:12 PM   #18
E70'11
Ha awesome man, good deal for you BOTH then
"Happy wife happy life" lol
      11-14-2016, 04:14 PM   #19
E70'11
I've researched and heard the SprintBooster is worth it so thanks for the insite man.
As far as this being available for the iOS I believe it's only android, I saw someone ask on the e90post so I'm just referencing off of what MHD has stated
      11-14-2016, 09:11 PM   #20
racermp
racermp's Avatar
Drives: F30 330i
New updated maps out today, Time to refresh the maps! No charger needed for reflash, takes 4-5 mins. Ill do it tomorrow morning
      11-15-2016, 03:13 AM   #21
tremor1521
Drives: 2011 E90 328i 6MT
If anyone could do a 0-60 run using this tune that would be
I'm wonder what kind of power the stage 2 with downpipe 91 octane would produce...
      11-15-2016, 04:49 AM   #22
racermp
racermp's Avatar
Drives: F30 330i
I asked MHD in the e90 forum on power, they said it's still in beta so it would be premature....
xbimmers
