09-12-2019, 08:46 AM | #89 |
Rep 3
I will be swapping the brakes over for sure. I wanted to swap the M steering wheel with paddle shifters, I'd like to find a way to make the M HUD work in the diesel. Might swap the ventilated seats and controls. I'd also like to update the suspension to as many M spec parts as I can.
09-12-2019, 09:29 AM | #90 | |
Rep 676
Couple notes which might be helpful. - I would check the performance of the ventilated seats before swapping them. My D has them and I can't even tell they are cooling while wearing thin athletic shorts. Maybe mine just suck but I think the system might suck in general. Plus all the pores just collect small grains of sand and similar. If you already have comfort seats it may not be worth it, regardless of cooling. - With the HUD, my understandingi is the "M" interface can activated by simple module coding, no special hardware needed.
N54 Powered M5 Wagon:
- M5 Shaft, M5 LSD, M5 Axles, M5 Brakes, M5 Front End, M5 skirts, M5 Mirrors - Manual Swap, MFactory SMFW, Spec Stg 3+, KW V3, RD Sport Sways, F14 SDC - EOS Port Injection Manifold, Fuel-It: Stg 2 LPFP +Lines +Ethanol Sensor - JB4, Hexon RR550s, Custom Inlet, AR DPs, 3" Exhaust, VRSF 7" IC, ER CP +Tial |
09-12-2019, 11:19 AM | #91 | |
Rep 3
09-13-2019, 12:04 PM | #92 |
Rep 676
From what I have seen all the "static" suspension and drivetrain components like control arms are essentially the same or without significant differences. The sways, differential, steering are all active so upgrading those would require retrofitting the complete systems. Curious to see if you find value in those active systems, personally I just view them at more complex systems with more sensors to fail and more hydraulics to leak.
09-13-2019, 12:58 PM | #93 | |
Rep 433
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread https://www.xbimmers.com/forums/show....php?t=1529213 |
09-14-2019, 09:02 AM | #94 | ||
170
Rep 328
09-14-2019, 02:50 PM | #95 | |
Rep 433
09-15-2019, 06:20 AM | #96 |
170
Rep 328
09-16-2019, 11:05 AM | #97 |
Rep 676
Played around with the with configuring an inlet system. There might be some subtle changes but I am pretty confident the setup I sketched out will work.
The OEM system seems to perform well for what it is, the goal with this system is to achieve similar filtration and low intake temps while shortening the intake systems length. There are some high HP 335ds which essentially run an ultra short; filter - MAF - turbo inlet pipe. The benefits of the short run and high flow seem to outweigh disadvantage of having the filter in the engine bay and sucking hot air. I hope to have a system that is as short as possible while introducing cold air. Turbo noises and having a unique inlet which cleans up the engine bay are bonuses. The key to the system will be a 3.5" 90 degree oval pipe made by CXRacing. This X5M intake was the closest thing I found to what I want to achieve. Here is a scribble of the system. It's worth noting the OEM air filter is a larger 9.5x12" panel filter and looking that size up on K&N's website it should flow ~600cfm, that's K&N's panel filter and is thinner than the Bosch unit BMW uses so I assume the stock filter flows a bit less, maybe 500-550cfm. K&N offers two filters that will work, the RC-5000 which flows 600cfm and the RC-5040 which flows 1,000cfm. I might see if I can atuff the 5040 but if it's too much hassle then the its nice to know the 5000 essentially flows the same as stock. Conveniently the OEM turbo inlet pipe houses the PCV connection With the upper portion of the pipe being removable there is a nice flange to clamp onto Here is the everything but the turbo inlet pipe installed The next 2 photos show the MAF mocked up and spaced as if there was a 3" to 2.5" reducer between it and the turbo inlet pipe. Off the MAF will be a 3.5"-3" reducing 90 degree silicone elbow directly connected to a 45 degree elbow which connects to the oval pipe. The goal is to have the oval pipe inline with the vehicle and have the silicone do the bending but if space is limited then I might skip the 45 bend and run the pipe direclty off the 90 degree elbow, we shall see. When reinstalling the turbo inlet pipe the PCV pipe split, you can see it was cracked in multiple locations. I had some heater hose lying around which fit well. I am excited to delete this leaking CCV system in favor for a vented oil catch can. Upgraded the switch for my QTP exhaust valve, not sure if I will end up using a wireless controlled but if I do a hardwired switch this toggle is much easier to operate and offers a cleaner design. Did a few 0-60 runs, 6.5 was the best but it was also on a slightly uphill road so I expect a 6.3 could have been achieved. Not very exciting but nice to have some sort of baseline before power increases. Currently running JBD @10 and a trans tune. Speaking of trans tune I was having some delay in acceleration from a standstill, part of it seems to be electronic off the pedal but there is also an elastic like delay which I assume is related to the torque converter. Rod's trans tune does manipulate the TC so I asked him about it and he sent and updated file V12.3 to HP5 IIRC. In the continued spirit of preventative maintenance I replaced the fuel filter. Turns out the one installed was dated 2014... overdue! New filter installed, notice 2019 date. I also noticed some water ingress via the cowls and I am aware the injector related issues this can cause and although I live in San Diego where precipitation isn't so common, I still wanted to nip it in the butt. Central cowl piece removed, notice the ends where the oem foam has been smashed and morphed into a goo. I cleaned off the edges and installed some OCI butyl. I do a lot of headlight work so I conveniently had this laying around. I laid a thick bead at each end. With the panel reinstalled you can see the excess squishing out. This is what I wanted to make sure there were no gaps but its a bit of an eye sore and butyl can be a mess especially when warm so I trimmed it with a razor and gave it a leak test. Good to go! My "engine acoustics" were chewed up from a rat at some point and contaminated with carbon via boost leaks so I trimmed up the eye sore a bit and I decided not to install the OEM engine cover, because of this I also removed the oil filler neck extension. I like to tidy up the engine bay as I go and keep things minimal as it makes it easier to wrench.
09-16-2019, 04:33 PM | #98 |
Rep 1,055
That's funny I was think something exactly like that for the intake piping the other day. I'd just love to get rid of all that clutter over the intake manifold and I'm sure it would make for better airflow too.
I was think of actually doing duals like on the x5m intakes systems like you said. Apparently the x5 m50d oversea has a dual intake pipe setup, but I would like to flip it and make something like that with two fat filters in the grille Hardest part would be that oval piping, then a 3.5" silicone 90, maf sensor, then a 3.5x3.0" reducer. I don't know how to tig weld so I was thinking of going the carbon fiber route.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
09-16-2019, 06:15 PM | #99 | |
Rep 433
09-16-2019, 07:35 PM | #100 |
Rep 1,055
Yes I know that but have dual intake pipes going into the grille like that just flipped 180 degrees on the other side 90ing straight down to the hp turbo inlet. Like for dual intakes instead of single. Just so the intakes look symmetrical, plus more air flow.
09-16-2019, 07:53 PM | #101 |
Rep 433
Even if you manage to get more airflow, isn't the bottle neck still the turbo inlet?
09-17-2019, 07:23 AM | #102 | |
Rep 1,055
Sure I'll for sure need a pre-filter and running it in the winter in Maine might not be a great idea with all that "stuff" they put on our roads but hey who cares. I'll switch from stock to that every season.
09-17-2019, 10:31 AM | #103 | |
Rep 676
It will be a tight fit to stuff all of those items in the engine bay with such a short run but I think it's possible, it at least seems possible enough for me to try. As for the OEM dual intake piping, I guess if you wanted maximum filter surface area that is a good way to go but then again if you are that concerned about filtration then sticking filters in the direct line of ram air may not be the best idea.
09-17-2019, 10:54 AM | #104 | |
Rep 1,055
09-23-2019, 07:40 PM | #105 |
Rep 676
Replacing vacuum lines turned into bypassing the low pressure EGR cooler and deleting the high pressure EGR cooler.
OEM vac lines had ~80,000 miles on them and were nice and toasty. Even with expanding pliers I wasn't able to get the lines off the nipples without cutting them with a razor. The last vac line I replaced was for the low pressure EGR cooler (located under the LP turbo) and accidentally broke the plastic nipple off. After doing some research I sounded like this wasn't worth repairing since I plan to delete it eventually and the non functional valve should only throw a CEL, not put the X5 into limp. After learning my EGR delete intake pipe could be installed without limp mode I decided now was a good tie to do that as well. Even while on a stock tune I like having this done to slow carbon build up and have a nice bump in engine efficiency. The e61 that's for sale gets the garage so the workshop moved to the driveway. Roasted and toasted! The best tip I have is to figure out how to remove this rear solenoid, reaching many of the vac lines is awkward but these two are impossible unless you pop the solenoid out. I didn't see any holes but the lines were not in good shape Farewell cooler With the braces out I hit them with some sandpaper and applied some top coat, hopefully they stay looking fresh, I am a bit fan of brushed metals, especially in engine bays.
09-24-2019, 08:45 AM | #106 |
Rep 1,055
If you're servicing the vacuum system I recommend doing the three actuators and two pressure converters too! They're common failure items. What vacuum line did you end up using? Also I recommend replacing the gaskets on the vacuum pump as preventative maintenance. That should get your vacuum system running top notch!
Notice any difference in performance? I know when I did a complete refresh on my 335d at 100k it was like I was driving a new car! Way more response low in rpm!
09-24-2019, 11:05 AM | #107 | |
Rep 676
The actuators and converters were the meat and potatoes of what I did with this vac line refresh, pretty much everything on the hot side has been replaced. Good tip on the vac pump gasket. No real difference in performance TBH, I don't think my lines were leaking just in rough shape and getting worse. Curious to see if MPG goes up with the EGR bypassed.
09-24-2019, 11:38 AM | #108 | |
Rep 1,055
This is what I'll be buying when I do my x5 delete process along with other some other things (double check on the barb fittings I had a couple I needed/didn't need when I did my 335d): https://www.mcmaster.com/order/rcvRt...;device=iPhone And if you want to do the vacuum pump gaskets here's a link for that too, you want to make sure you get both of those gaskets: https://rover.ebay.com/rover/0/0/0?m...2F321320251247 Getting the vacuum system to 100% is definitely the most important thing on these engines since a leak anywhere in the vacuum system will affect the entire vacuum system (brakes, turbos, and engine mounts). My 335d was on my shit list for awhile because of the poor/inconsistent performance I was getting from multiple leaks, but now its a beast! Mpg probably won't be too different if any difference. Everyone always fights about how much of a difference removing the egr makes, me personally, felt a difference in response on initial acceleration and low rpm acceleration/cruising. But everyone has different opinions on what they feel.
09-25-2019, 12:31 PM | #109 | |
Rep 676
I have a fluidampr sitting here so I ordered a few specialty tools for that along with new belts, idler pulley, thermostat, LP EGR block off plate. After this a cooling flush, oil change, and installing an oil catch can are the only maintenance left to do on the engine before the performance mods can start.
09-25-2019, 03:27 PM | #110 | |
Rep 1,055
I went with a FAI Automotive Viscous dampener on my 335d. It's half viscous half rubber so the dampening is a lot better than just the fluid in the fluidamper HD so you might find that there are more vibrations than before. Also make sure you get the clutched alternator pulley since it's been found to be the reason for HD failure. And not sure your mileage but I changed the water pump while I was in there just incase. Looks like you're doing the process the right way though not doing what I did and delete first then fix everything lol. I'll be doing everything at once on my x5 when I'm ready to delete, make a weekend out of it and make sure its 100%. Goodluck man, your build looks to be coming together nicely
