Tech Info: E90 330i N52 Three-Stage Intake Manifold
08-29-2016, 10:23 PM | #837 |
Rep 5
Drives: 2009 Jet Black E90 328i
Hey guys, sorry to revive this thread, I've got a used 3 stage manifold I'm planning on installing on my 328i, and I took it apart to inspect the DISA valves before installing... The large valve is broken, and the small valve appears fine (flap won't move when I wiggle it. I'm wondering if it's worth fixing the large valve with a repair kit, or if I should just replace the entire valve. What is making me consider replacing the entire unit is that the green seals are peeling off... What would you guys recommend. I'm also including a picture of the smaller valve, as that has some wear on the green seal as well...
09-14-2016, 09:28 AM | #839 |
57
Rep 114
Drives: 2008 E91 ZSP
Don't flame me. I searched and couldn't find a post in this thread about using the 3-Stage conversion/ecu flash and passing California emissions.
09-14-2016, 09:36 AM | #840 |
Rep 7,215
it should pass. the 3-stage is indistinguishable on the outside from the single stage. the only real difference is the manifold has mounting holes for the DISA valves - they are identical otherwise.
the 3 stage also came on cars that meet California emissions like the 330i and 328i with N51. |
09-19-2016, 04:14 PM | #841 | |
just another bmw douche bag
195
Rep 3,640
I can confirm that the 3IM does indeed pass california emissions with the AA tune. Actually, I need to go get another smog here in the next couple of weeks. |
02-24-2017, 10:36 PM | #842 |
309
Rep 394
so i did this today.
some comments, maybe covered here before. 1. long DISA connector goes UNDER the intake runners. i had to search more than i feel like i should have for this. 2. short DISA connector goes to outside connector. you can't plug these in wrong, due to cable length, but i am confirming this as above. 3. intake manifold 11mm bolts and nuts torque to 11ft-lb 3b. i torqued the throttle body to 7ft/lb when installing. not sure if right. but definitely not too little. 4. I removed the throttle body from the intake manifold before pulling the electrical hub underneath. i couldn't get the tabs loose so i unbolted the bracket from the intake. 5. i swapped all sensors from the old manifold to the new one. 6. even if the PCV is different on your donor manifold, your existing tubing WILL bolt up. 7. with enough patience, NOTHING will break, including the breather hose everyone seems to break. 8. there are differences between the pelican DIY and different cars. you do you and don't expect every step to be documented or the same as any DIY. 9. i did this job in 2 hours, taking my time. be patient. BMW engineers did a good job. have the right tools. 10. you'll need to remove the upper cowl, and pelican doesn't list this as a step. FYI. 11. i don't feel anything different, but have plans with a tune. good luck to anyone else out there! |
dancing__narwhal141.50 arciga181731.00 |
02-25-2017, 08:34 AM | #843 | |
Rep 647
02-25-2017, 09:31 PM | #844 | |
309
Rep 394
i will honestly say i spent 30 minutes trying to get the electrical harness thing off the intake before realizing i could just unbolt it. i also spent about 30 minutes taking the old manifold apart for the hoses, throttle body, and map, while spending some time cleaning a few areas i would never be able to get to otherwise. i also had to deal with a broken map on the new manifold that required fun removal. it's all very basic tools required. i cheat and use a small electric impact for everything except tightening of torque critical fasteners. i promise you will not break the pipe everyone breaks of you just give it some tender love. |
07-10-2017, 09:07 AM | #846 | |
3767
Rep 2,738
You can also use a 528i intake manifold but it has a large heatsink on it. (The heatsink is not removable because it forms the outer wall of 2 of the intake runners.) I was able to Bolt it up but I had to trim the large engine cover to fit around the heatsink and you can no longer use the long plastic cosmetic manifold cover that fits on the driver side of the manifold. So yes a 528i manifold also works but cosmetically it's not attractive. https://flic.kr/p/VjChL5 Last edited by Biginboca; 07-10-2017 at 09:22 AM.. |
07-28-2017, 01:36 AM | #847 |
Apex Forged 19", AA headers, MILVs, 3IM, Euro Intake, Swift Spec-R
87
Rep 255
Drives: 2013 328i coupe
3IM club
I am now the newest member of the 3IM club. I finished everything up about 30 minutes ago and just took her for an early morning joy ride.
I don't work on cars much, so it was a difficult job for me, probably the most challenging thing I've attempted on my car to date. It took me about 5 hours to finish. I had no problem at all getting the vacuum hose off, but I did have to remove the entire cabin air filter, cowl, and engine cover. The hardest part for me was getting the wiring harness to release from the metal bracket, what a pain in the butt. I broke one of the clips. The other goof I made was dropping one of the silver sleeves out of the power steering fluid reservoir rubber mounts. I'll have to order another one and put it back in. I'm not going to lie, I said a little prayer before I started it. I was just a bit worried I had missed something. To my relief, it started right up and idled nice and smoothly. I let it warm up, and then took it up to redline a few times and ran it kindof hard on some curvy back roads I drive all the time. The car feels more aggressive, for sure. I don't know if it will continue to adapt, or if the AA tune shows the full benefit immediately. Either way, it was worth it, even though it was tough. I'm glad I did it, but I wouldn't want to do it again! |
Seattlesquash905.00 |
07-28-2017, 07:52 AM | #848 | |
Rep 647
07-28-2017, 09:47 AM | #849 |
87
Rep 255
I used the Pelican guide and this forum, they were very helpful. Now that I've done it once I would feel a bit more comfortable doing it again, but I wouldn't call that a simple job for most people.
07-28-2017, 09:37 PM | #850 | |
1009
Rep 2,109
The correct way is to remove the metal bracket together with the wiring harness box from the manifold. The bracket has two torx screws on each end of it, undo those it is free from the manifold. The screws are not easy to see, but easy to find by hand. They are number 4 in second picture at this link: http://workshop-manuals.com/bmw/3_se...nifold_(n52k)/ |
03-02-2018, 09:44 AM | #852 |
36
Rep 38
I just finished dynoing my car today. 182 RWHP bone stock, and now it's making 216 RWHP. See below.
03-02-2018, 09:47 AM | #853 |
Rep 7,215
Do you not have a tune? That power curve doesn't look right. The dip at 4k is huge.
hit up bimmerlabs for a free basic one (exactly the same as a stock 330i) - or talk to BPC if you want the best full tune. You should try it on premium just for fun - I ran our E91 on 87 for years, and it's fine, but it really woke up when it could use the full octane maps. |
03-25-2018, 10:17 AM | #855 |
Rep 7,215
no - but why would you want to? you'll just lose power and get worse gas mileage. It's not like these engines are boosted and can take advantage of the effectively higher octane rating.
04-13-2018, 06:41 PM | #856 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
I just installed a 3 stage manifold on my 2009 E90 and I replaced the starter at the same time as preventative maintenance. I'm somewhat mechanically inclined and found it much easier than expected, but it still took 4 hours. It's a tedious process so give yourself enough time and don't rush it. For what it's worth, this was easier than the waterpump and thermostat.
I found it helpful to label wiring harnesses with masking tape even though it's quite obvious where they go. The tape helps prevent you from missing any harnesses during reinstallation. Unbolt the electrical junction box (under the throttle body) from the intake manifold with a T27. The little screws are a pain to put back in. The PCV connectors are a pain to disconnect but keep trying different ways to grip them and they'll come off. Be careful where you pull on the connector and you shouldn't break anything. I sprayed them with silicone spray to help loosen them up. The short DISA cable goes to the large DISA valve and the long cable goes to the small DISA valve. If you're also replacing the starter, the rear bolt is a joke if you have a ratcheting E14 wrench. This video is very helpful: |
6ixSpd6027.50 mattpete13122.00 |
04-15-2018, 01:07 PM | #857 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
Also want to add that hassmaschine goes into when the DISA valves open in this post: http://www.e90post.com/forums/showpo...78&postcount=6
tl;dr: <3270rpm - both valves closed 3270-4470 - small (?) DISA opened >4470 - both valves opened Last edited by The Nightman; 05-01-2018 at 02:45 PM.. |
04-30-2018, 07:45 PM | #858 |
122
Rep 368
Can't really find the exact answer I'm looking for to this simple question:
Is it even worth it to install the 3IM without the tune? I have the IM, just waiting to acquire a tune, MPE and intake. Funds are what's in my way... So should I just put it on or wait?? Thank you to all who have posted on this thread!!! |
