08-07-2020, 01:51 PM | #24 |
Rep 993
08-07-2020, 07:16 PM | #25 | |
207
Rep 354
Thank you for the help!
F80_BK75.00 |
12-07-2020, 10:33 PM | #27 | |
271
Rep 326
For those who have "Front Light Electronics Left" and "Front Light Electronics Right" control units here is exactly what I did. Front Light Electronics Left - Navigate to Front Light Electronics Left - Click on Expert mode - Click on 3006 LED1 - Click on LM_ID_LT4 - Change to 02_VALUE / 0x00 - Go back to the 3006 LED1 page - Click on LM04_NAME - Change to 02_VALUE / 0x00 - Back on 3006 LED1 page and click code Check & verify if value changes worked for the Left headlight. If no-go, revert back. If good, then proceed with the Front Light Electronics Right control unit. Front Light Electronics Right - Navigate to Front Light Electronics Right - Click on Expert mode - Click on 3006 LED1 - Click on LM_ID_LT4 - Change to 02_VALUE / 0x00 - Go back to the 3006 LED1 page - Click on LM04_NAME - Change to 02_VALUE / 0x00 - Back on 3006 LED1 page and click code Enjoy! Thanks all to previous posters for cluing me in. Last edited by EezyBeezy; 12-07-2020 at 11:46 PM.. |
12-10-2020, 02:25 AM | #28 |
Rep 4,203
I wish I could get mine to work...... I was told by Alex that coded my car it could not be done on my 2015 cuz it had the files updated somewhere along the line
01-24-2021, 04:48 PM | #29 |
Rep 993
Wanted to update my situation with the wierd folder names. In Esys 3.3.4, i used detect CAF for SWE and code on both TMS modules. After, i was able to see the correct folder names in Esys launcher pro 2.8.2+Esys 3.27 and successfully coded out the 3 amber LEDs using instructions in post 3.
Also, i found another method to disable the 3 amber LEDs, remove the corner light module from the headlight and disconnect the connector to the 3 amber LEDs. No coding necessary. Last edited by hC1001; 01-26-2021 at 12:11 PM.. |
05-04-2022, 05:15 PM | #30 | |
The Muscle Milk.
96
Rep 670
Drives: 2018 F85 X5M
05-06-2022, 02:20 PM | #31 | |
271
Rep 326
05-26-2022, 10:49 PM | #32 | |
Rep 526
05-27-2022, 03:22 PM | #33 |
Rep 765
Drives: G80 Comp
just wanted to say..it works…thank you
05-30-2022, 12:51 AM | #34 | |
Rep 526
EezyBeezy271.00 |
10-28-2022, 09:11 AM | #36 | |
I'd hit it
1066
Rep 1,107
EezyBeezy271.00 |
11-04-2023, 11:19 AM | #38 | |
33
Rep 70
The lighting stuff is in the Front Electronic Module and I don't see 3006LED1 at all in the expert section. There is a cornering lights deactivation but it's already showing active . Thanks for the help. |
11-04-2023, 12:06 PM | #39 | |
1792
Rep 3,059
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
11-04-2023, 12:22 PM | #40 |
33
Rep 70
11-05-2023, 04:14 AM | #41 |
1792
Rep 3,059
FLE modules then.
Sloblk832.50 |
11-05-2023, 08:22 AM | #42 |
33
Rep 70
02-14-2024, 04:54 PM | #43 |
Rep 7
02-15-2024, 03:02 AM | #44 | |
1792
Rep 3,059
https://bimmer-remote.com/products/b...f395e811&_ss=r
vermethlln0.00 |
