The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Best Dual Cone Intake for N54
      05-07-2013, 06:22 PM   #23
Gemballa1980
18
Drives: 335i
CPE!
      05-07-2013, 06:39 PM   #24
Colo M/Sport
Drives: 2009 335 M / Sport
Originally Posted by WLF View Post
in terms of performance how do injen,afe and bms intakes compare?
In terms of sound, how do they compare?
      05-07-2013, 06:55 PM   #25
WLF
Drives: n54 e92
huh?
      05-07-2013, 08:11 PM   #26
Colo M/Sport
I thought I read that changes here could cause added noise from the engine compartment. Is this noticeable or did I just misunderstand?
      05-07-2013, 11:21 PM   #27
SaviorXi
SaviorXi's Avatar
Drives: 2009 335i xDrive coupe
I had the injen in my 2008 335 and I now have the new white filter BMS ones. They both function the same. The injen looks better and the BMS sounds better and is cheaper. If I could go back I would have skipped the Injen and got the BMS and saved around $300.00 Injen is a pretty waste of $$$ but if you don't care about wasted money and zero performance gains over a cheaper alternative then by all means get the injen. Check my pics for installed injen shots. I will take some pics of the BMS intake soon. Injen is a quality peice of metal with some nice metal "injen" stickers.
      05-15-2013, 09:54 PM   #28
6MTF80
Drives: 2007 335i
Originally Posted by Gemballa1980 View Post
CPE!
What is the benefit to this one vs the regular BMS intake?
      05-15-2013, 10:06 PM   #29
1up
1up's Avatar
Drives: E92 335i
Are the white filters dry filters like afe? Took off my dci's due to fear of oiled filters damaging censors
      05-16-2013, 03:29 AM   #30
Gemballa1980
18
Drives: 335i
Looks. There may be a difference in the flow rate or the neck design, however it would be so minimal that I doubt you'd notice. I went for the white ones as I think the red look cheap & nasty. Plus, the white is just a little different.
The cfe filters come in both oiled and dry setups. The oiled ones have a better flow rate though as the mesh is wider and uses the oil to trap unwanted bits. The dry mesh has a tighter weave to filter everything and thus more restrictive. Back to back you wouldn't notice AFAIK.
I originally ordered the dry filters but the guy stuffed up and sent me oiled. (both are white / silverish). I wouldn't worry about sensors though as there aren't any between the pods and the turbos and doubt oil would get far once it hit the heat in the turbo.
      05-16-2013, 04:04 AM   #31
cstavaru
cstavaru's Avatar
314
Drives: 2009 335i M Sport Sedan 6MT
All dual-cones are bad, I had the Injen and you could feel the loss of power while driving around town because of the hot air under the hood. Get a cold air intake like the Stett. Between BMS and Injen, I would choose Injen because it is really well made (but with a price to match). The BMS intake hangs around in the engine bay, you can move the filters around with your hand.
      06-28-2013, 11:01 AM   #32
bmwm3redblack
bmwm3redblack's Avatar
59
Drives: BMW ///M3 E46, BMW E92 335Xi
Hey man ia bms really sounds better then injen? by how much?
So if the gains are the same on all intakes, and bms has better sound so it's the best???
Bmw 335xi/FBO/ black on black/ 6sp manual/Cobb AP/BMS DCI/AA BOV KIT/VRSF DP'S/VRSF 7'FMIC /FULLY CATLESS/H&R sport springs/ 19' ac schnitzer wheels.
      06-28-2013, 11:19 AM   #33
Xzach92X
New kid on the block
Drives: 09 335i coupe
2009 335i  [10.00]
2009 E92 335i  [0.00]
I have injen and i personally like it it doesnt look as cheaply put together as the bms but performance wise i dont believe there is a difference looks injen price bms
      06-28-2013, 11:48 AM   #34
Uzi_335xi
Uzi_335xi's Avatar
Drives: 2014 Ford Mustang GT
I have Injen's on my car, they are amazing. Clean install, easy if your somewhat mechanically inclined.
They have the sound & the looks.
08 335XI- Mods~ JB4 G5, Injen Intakes, VRSF 7" FMIC, Southbend stage 2 clutch (first XI clutch made by southbend), Eibach pro-kit
"It's now okay to own a BMW, it appears all of the Douchebags have moved over to Audi's"
      06-28-2013, 12:28 PM   #35
bmwm3redblack
59
personally me i wouldn't go cai, because of heavily rains, and danger of hydrolocking.
It's better to lose another 5hp, but save your engine. But if you don;t drive in rainy days the best is probably cai!!!
      06-28-2013, 12:34 PM   #36
ken1137
ken1137's Avatar
Drives: BMW S1000XR
2009 e90 335i  [6.40]
Man...why bump these old threads?
BMWCCA member
      07-01-2013, 03:43 AM   #37
cstavaru
cstavaru's Avatar
314
CAI does not mean "filter in the bumper" but "cold air intake". The OEM intake is a CAI.
Here is a CAI with no filter in the bumper:
http://www.e90post.com/forums/showthread.php?p=8762970
And you don't lose 5hp with a DCI, in fact, the high-end is fine. You lose like 20% of your spool-up torque, at least according to my feeling of driving it.
      07-02-2013, 08:44 AM   #38
hayman63
Drives: e90 335xi
Injen one s really nice!!
