BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > N55 Injector Issue!
Extreme Powerhouse
      03-11-2024, 11:01 AM   #1
bennyg1810
Drives: 435i
N55 Injector Issue!
Hi all!
Needing help with an injector issue I’ve been having.
Car was chuffing and stank of fuel so I had the injector replaced. It was explained to me that it wasn’t sealing properly due to movement from the injector, so the seal and bracket were also replaced.
The car was running fine until I started hearing a weird noise (no symptoms yet) and it was progressively getting louder as I was driving the car (over a week or two).
Weird noise video here:
https://streamable.com/y4mfn4
The car has essentially gone back to square one and is chuffing again, lurching if in drive (auto) and stinking of fuel.
Video here:
https://streamable.com/fvd5th
What could be causing the injector to not seat properly if the bracket and seal have been changed?
      03-11-2024, 11:43 AM   #2
NEWTRON
NEWTRON's Avatar
85
Drives: F32 435i
It could be a few things. Was the decoupling element replaced? Was the teflon seal compressed properly? They are both one time use. If the injector was not installed correctly, you could have had combustion escaping through the injector port causing damage to the head.
VRSF RACE IC, FTP CP, VRSF CATLESS DP, BORLA ATAK CATBACK, CTS TURBO INTAKE, MST V2 INLET, PURE STAGE 2, TURBOSMART BOV,FTP TURBO OUTLET, SPOOL FX180, BM3 ETHANOL ANALYZER, PRECISION RACEWORKS COILS, BM3 STAGE 2+ E30
      03-11-2024, 01:25 PM   #3
bennyg1810
Drives: 435i
The car is going back to the garage that fitted the bracket and seal.
I’m not too clued up on the intricacies so can’t speak as to if the seal was compressed properly or if the decoupling element was replaced but thank you for asking - it gives me some insight to question the garage.
I’m hoping no damage to the head 🥲
      03-11-2024, 02:36 PM   #4
LA1Z24
Drives: 2014 435i M Sport
Cylinder head needs replacing or you can use the heli-coil style kit to repair the hole. The decoupling element wasn't installed, which in turn ruined the cylinder head.
      03-11-2024, 02:44 PM   #5
bennyg1810
Drives: 435i
For when I take it back to the garage, what makes you so sure it’s this?
Any more info on the heli-coil style kit?
      03-11-2024, 10:43 PM   #6
NEWTRON
NEWTRON's Avatar
85
Drives: F32 435i
Because its the only reason that would cause a loose injector. They are press fit into the head.
      03-12-2024, 04:54 AM   #7
LA1Z24
https://ppifpr.com/ppi-BMW-injector-bore-repair-kit/
      04-02-2024, 03:08 PM   #8
bennyg1810
Drives: 435i
Managed to get the injector issue sorted but can hear this ticking.. sound like anything to you?
I know the engines are ticky by nature but this seems like a new noise:
https://streamable.com/qibzuj
