03-20-2012, 11:04 AM | #287 | ||
2948
Rep 21,783
- Do people ride in the back? - Road conditions such as steep driveways, speed bumps, - Driving habits aggressive or daily driver? - Do you carry gear in the trunk? These are variables that can affect ride height, which ultimately will affect spacer sizing. In your case best thing to do is to measure. http://www.m3post.com/forums/showpos...67&postcount=2
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 03-20-2012 at 11:30 AM.. |
03-20-2012, 09:37 PM | #288 | |
Green Beemers
86
Rep 348
Drives: 27 BMWs...and counting
I did the measuring thing for about a half hour, with straight edges, squares, millimeter rulers, and a full tank of gas, 180 lb. person in the driver's seat, etc. It is kinda voodoo magic though, because you don't really know what part of the tire is gonna hit where if the suspension moves (on an arc? etc.) That's why I was hoping that somebody here has already experimented with a spacer set up that works with the ZCP wheels on a non ZCP car and 255/35, 285/30 tires... Anyways, I got measurements from the worst case spot on the tire, the rim protection bead to which the straight edge was touching, but it seems unlikely that bead area would never normally compress all the way up to the fender lip? I measured about 12mm in front and about 7mm in the rear. If I could un-naturally compress the suspension and see the geometry at work it would make things much easier (obviously), but I am fairly certain I am not going to have any problems on the stock springs with a 12mm spacer in the front and 10mm in the rear. PM me please. |
03-22-2012, 04:35 PM | #289 |
310
Rep 3,635
Drives: R56 Cooper S
Year/model BMW:
2008 E93 M3 Wheels/offset: Front: 19x8.5 OEM M3, ET29 Rear: 19x9.5 OEM M3, ET23 Tire size: Front:Michelin PS2 245/35-19 Rear: Michelin PS2 265/35-19 Suspension: Stock Spacer size: Front: 15mm Rear: 12mm Last edited by anthony @ eas; 03-23-2012 at 01:33 PM.. |
03-22-2012, 10:06 PM | #290 |
Green Beemers
86
Rep 348
That's an E93 not an E92...and since nobody from EAS wanted to take the time to PM as requested (twice in this thread), I have decided to go with another offering. Sorry fellas.
03-22-2012, 11:42 PM | #291 | |
8298
Rep 18,866
Drives: BMW
This is a technical thread, but any sales-related questions can be directed towards any of our sales team via PM, email or by phone.
04-04-2012, 11:33 AM | #293 |
8298
Rep 18,866
Drives: BMW
Not that I'm aware of. 12mm is already available, I doubt 13mm will be hitting the market anytime soon.
04-04-2012, 11:45 AM | #294 |
732
Rep 3,735
I personally recommend these spacers over most of the others that are available. They have always been great when installed correctly.
Malek
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
04-04-2012, 12:03 PM | #295 |
310
Rep 3,635
04-04-2012, 08:58 PM | #296 | |
Rep 244
I received my EAS 12mm and 15mm spacers a few days ago. I changed out my winter tires and installed my summers with 12 spacers at the rear and 15 at the front. The stance improvement is excellent. The handling with the M button MDM setting is very good. |
04-05-2012, 06:36 PM | #297 |
Rep 92
Hi EAS,
What size spacers will I need in order for my car to have a flush stance with no rub? Here are my info 1. 2012 E92 M3 2. Wheels/offset: ZCP wheels Front: 19x9" ET31 Rear- 19x10" ET25 3. Tire size: Front: Hankook V12 255/35/19 Rear: Hankook V12 285/30/19 4. Suspension: non ZCP suspension Thank you |
04-06-2012, 02:41 PM | #298 | ||
310
Rep 3,635
04-06-2012, 02:48 PM | #299 |
310
Rep 3,635
Year/model BMW:
2011 E92 M3 Wheels/offset: Front: 19x9.5 Work Meister S1 3P, ET26 Rear: 19x10.5 Work Meister S1 3P, ET23 Tire size: Front:General Exclaim UHP 275/30/19 Rear: General Exclaim UHP 305/30/19 Suspension: KW Sleeve Over Kit Spacer size: Front: 20mm Rear: None Last edited by anthony @ eas; 04-06-2012 at 04:49 PM.. |
04-09-2012, 02:40 AM | #301 |
///M
161
Rep 1,867
I'm picking up some ZCP 359m rims, what would be the best spacer setup without any rubbing? I'm lowered on Kw Sleeve
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI |
04-09-2012, 11:51 AM | #302 |
549
Rep 5,695
On OEM ZCP wheels with the Michelin tires, the common set up is 15mm front and 12mm rear. You do also have to take into consideration your alignment specifications (more spacing needed if cambered in, for example) and if you have a different tire.
04-09-2012, 02:41 PM | #303 |
///M
161
Rep 1,867
Im currently running Michelin Supersport 245/35/19 fronts and 265/35/19 rears, planning on getting 255/35/19 and 275/35/19 on my next set of tires. with the new setup i can still run 15MM front and 12mm rear without any rubbing?
04-09-2012, 04:38 PM | #304 |
549
Rep 5,695
Upsizing the tires might cause the wheels to rub with the same spacer size, especially if you are lowered more than 1" from OEM height.
04-09-2012, 05:29 PM | #305 | |
///M
161
Rep 1,867
thanks
04-09-2012, 05:44 PM | #306 | |
549
Rep 5,695
04-09-2012, 06:08 PM | #307 | |
///M
161
Rep 1,867
04-12-2012, 12:29 PM | #308 |
310
Rep 3,635
Year/model BMW:
2011 E90 M3 Wheels: Front: 19x9.0 OEM 359 ZCP, ET31 Rear: 19x10.0 OEM 359 ZCP, ET25 Tires: Front: Continental Conti Sport Contact 3 245/35/19 Rear: Continental Conti Sport Contact 3 265/35/19 Suspension: B&G Lowering Springs Spacers: Front: Macht Schnell 15mm Rear: Macht Schnell 12mm |
