02-07-2015, 07:20 PM | #1 |
Rep 791
Drives: 2011 550xi
Well... DCT died today
So I was washing my car today, and I go to start her... Starts fine, push the shifter into gear and bam. Car starts having a seizure, violently shaking and throttling back and forth. I quickly put it into D from manual, where it moved to 2nd and was fine. I got the transmission problems warning on iDrive. I continued driving, and the car would shift 2-4-6. You could not put it in R-1-3-5.
I soon after restarted it, and it ended up stalling itself out a few times before I could quickly slip it into 2nd. I was then greeted with the red cog and "transmission overheat" as well as transmission malfunction. I brought it to BMW and set up a service appointment, but when I got in it again later to move it for them it was perfectly fine... I am still leaving it with them to diagnose. I'm sure the nasty bucking too and fro caused a few 1000km worth of instant wear on the components. Did some google-fu and couldn't find anyone else who had the exact same problem as me.
2017 Nitro Blue Ford Focus RS 2008 Sparkling Grey Metallic 135i 6MT - JB4 G5 - MHD Race BEF - N54Tuning DP's - ER Chargepipe/w HKS SSQV - Coolingmist Progressive Meth - MMP Hot Side Inlets - AFE Exhaust - Seconday Cat Delete - AMS FMIC - BMS Catch Can - Rob Beck PCV - LUX 160 AE |
02-07-2015, 09:25 PM | #3 |
Rep 791
Drives: 2011 550xi
38,000km. Just bought it 3 weeks ago.
02-07-2015, 11:09 PM | #5 | |
Rep 791
Drives: 2011 550xi
It went away after the car sat for 30 min or so. The part that worries me is I got a "transmission overheat". If there's nothing wrong that they can find will they charge me for bringing it in? |
02-08-2015, 03:24 AM | #6 |
Rep 19
Of course they will, no mechanic will look at a car for free... if anything, they can cut some diagnosis time off reducing your bills final cost.
02-08-2015, 07:44 AM | #7 |
Rep 3,422
Depending upon your relationship with the dealer they may or may not charge you for diagnosis time. I'd allow for the potential for it to be a temporary electrical gremlin. If someone is going to have to continue to drive the car to actually establish that there is a problem, might as well be you.
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
02-08-2015, 10:13 AM | #8 |
Rep 3,736
Drives: 2018 M2
If you bought it from a dealership Id definitely make them diagnose the car for free...problems after only three weeks doesn't sound like pure coincidence...check of your clutches are properly adapted
02-08-2015, 11:20 AM | #9 |
Rep 791
Drives: 2011 550xi
Well I do work for a shop that has an account with them too. But why check out my own car when I have warranty?
I got the car from a Mercedes dealership of all places... |
02-08-2015, 11:36 AM | #11 |
Rep 791
Drives: 2011 550xi
Felt pretty dead to me. I've never had a transmission try to rip my car apart and be "fine", and I've had my fair share of cars.
Actually last time something like that happened the clutch disk had actually fused itself to the flywheel and required a tranny drop. Last edited by Alohaaaaa; 02-08-2015 at 11:49 AM.. |
02-09-2015, 11:36 AM | #13 |
Rep 855
If you were washing your car, ever think you could have gotten water in some place it shouldn't be?
Makes sense since the car was fine later on (the water dried up) Edit- Lets speculate.. The last owner sold the car because everytime he washed it, he had an issue. If I'm correct, I would have the dealer inspect all plugs and wiring harnesses corresponding to the trans for openings. They should know it happened immediately after a wash..
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
02-09-2015, 12:20 PM | #14 | |
Rep 791
Drives: 2011 550xi
I've washed it like 10 times, no issue. |
02-09-2015, 02:40 PM | #15 |
Rep 791
Drives: 2011 550xi
UPDATE: just heard back from BMW. Clutches weren't properly adapted.
02-09-2015, 03:58 PM | #16 |
Rep 1,326
good luck. hope you get your issues resolved..i'm currently facing a DCT issue myself. let us know if it improves after the new adaptation.
i will be doing a fluid flush/filter change + new adaptation to try to fix my issue.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
02-09-2015, 04:37 PM | #17 |
Rep 3,736
Drives: 2018 M2
Looks like I was right!!
02-09-2015, 08:36 PM | #18 |
Rep 791
Drives: 2011 550xi
Drives pretty good now. No more throttle lag off first gear too.
03-01-2015, 07:03 PM | #19 |
Rep 791
Drives: 2011 550xi
Well shit. It's back. Right after a car wash again, so it has to be water getting in. It fixes itself after 30 min...
I'm telling the SA to soak the car before the techs check it out.
03-02-2015, 07:09 AM | #20 |
Rep 855
Sorry to hear your issue didn't go away. Do you drive the car in the rain?
Do you spray the under side of the car when you wash it?
03-02-2015, 06:56 PM | #21 | |
Rep 791
Drives: 2011 550xi
Nope. Just the surface.
03-14-2015, 05:10 PM | #22 |
Rep 791
Drives: 2011 550xi
Ok... Third time it's happened. Caught it on film. They couldn't re-create it the first or second time, so I emailed the video to my SA. He says they will hold onto it until it happens... But he also said "clutches and transmissions aren't under warranty unless you have service inclusive plus"??? There is no way this is user fault, it's obviously an issue from BMW. I hope I don't have to have a big fight over this. My car is 2.2ish years old, and only has only 40,000km (BMW Canada gives 80,000km warranty from new). This is without even washing it today. Just starting it after grabbing some lunch.
