2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Anyone mounted original M5 343M 20" rims on an F10/F11
      05-18-2012, 04:37 AM   #1
g75y
13
Drives: F80
From what I've read, the original 20" M5 343M rims (Front 9Jx20 ET34 and Rear 10Jx20 ET34) should be able to fit onto the F10 / F11 without rubbing, but was wondering if anyone has actually mounted these on your car and know for sure?
Understand that for the rears in particular, would be advisable to go with PSS tyres (255/35/20 front and 285/30/20 rear) or more conservatively use a 275/30/20 rear tyre?
Thanks
      06-05-2012, 02:18 AM   #2
RR80
RR80's Avatar
17
Drives: F10 535i
Thanks
Yes, somebody did it already. I think 275/30/20 would be safe but not sure on the 285 setup.
2003 E60 530i - PSS9 Coilover/M Kit/BBS GT-RS 19" wheels - retired
2006 E91 335i - Procede V5/Forge DV & FMIC/Bastuck quad exhaust/P1 Steering Wheel/Sachs Coilover/M kit/19" RS wheels - retired
2011 F10 535i - Stock
      06-05-2012, 10:12 PM   #3
marqueex82
Drives: BMW future owner
where's the best place to purchase a set of M5 wheels?
      06-05-2012, 11:21 PM   #4
LACSTER
Drives: Hybrid
The dealer would be the only place I can think of to get OEM M5 wheels but they will run you over $4000 for a set of 20's.
There's reps but I can only find 19's
http://f10.5post.com/forums/showthread.php?t=679914
      06-06-2012, 12:00 AM   #5
marqueex82
Thanks cousin! Thanks for that info!!!
      06-06-2012, 04:36 AM   #6
g75y
13
Drives: F80
Thanks. It looks good.
      06-06-2012, 11:39 AM   #7
Hunter5179
Hunter5179's Avatar
Drives: 2013 M6 Coupe
Did this guy use spacers or just slap them on as is?
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread:
http://www.6post.com/forums/showthread.php?t=794659
      06-06-2012, 09:51 PM   #8
RR80
RR80's Avatar
17
Drives: F10 535i
I think you don't need to put spacers since the OEM offset for the m5 wheels are on the low side.
      06-19-2012, 03:53 PM   #9
perisak
Drives: m550d
Thanks
I would also like to know this, and if it also fit the new M550dx?
anyone who know for sure?
      06-19-2012, 07:37 PM   #10
RumbleJay
RumbleJay's Avatar
27
Drives: 2011 BMW f10 550i M
Just saw some 20's rep on eBay. Item number: 110898538733. Not sure about the quality probably LPC.
      06-19-2012, 08:54 PM   #11
bobblehead
bobblehead's Avatar
256
Drives: warp speed
Just based on those spec. - the front has no issue at all. The rear is going to be pretty close border line clearing without rubbing. If you intend to lower the suspension later, then for sure, it will rub against the fender.
      06-20-2012, 04:21 AM   #12
perisak
Drives: m550d
How could then ACS sell there wheel kit:
FA: 9,0 x 20" offset 22 with 255/35 R 20
RA: 10,0 x 20" offset 33 with 285/30 R 20
seems like this is very close in the rear as the M5 wheel with ET34.
only 1mm different.
      06-20-2012, 06:01 AM   #13
bobblehead
bobblehead's Avatar
256
Drives: warp speed
The ACS setup
Front: +5mm from strut/+17mm outward extension
Rear: -2mm from strut/+24mm outward extension
Therefore, I think for rear, that +24mm outward extension is the highest limit that you can go with. Btw, ACS did lowered the car but their springs only lowered about 1 inch without any fender rolling. However, if you are thinking of lowering beyond that reference, there is a good chance it will rub.
      06-20-2012, 10:54 AM   #14
Damrong
Drives: F11
Hi Everyone I just install 343M wheels on my F11 MSport Package and tires are 255 35 20 for front and rear are 285 30 20. The offset was just nice without any rubbing eventhough with full loading passenger. Let me wash my car and I will show you few picture afterward.
      06-21-2012, 02:57 AM   #15
perisak
Drives: m550d
Xdrive or RWD?
Please post pictures
      06-21-2012, 05:06 AM   #16
remmib
General
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
Cool, wonder how it looks.
Xdrive or RWD?
Same fitment on both xdrive and rwd as far as I know.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      06-21-2012, 09:34 AM   #17
Damrong
Drives: F11
Sorry I am quite busy today and try to take few picture for you. Picture might not so nice due to I've taken from mobile phone.
      06-21-2012, 09:41 AM   #18
perisak
Drives: m550d
Xdrive or RWD?
I've read in other threads that it's best to have 245 in front and 285 at rear if you have xdrive. So it's same diameter. But i'm not sure how important this is.
I wonder if this F11 is lowered..?
      06-21-2012, 09:57 AM   #19
sbrown35
Chief
sbrown35's Avatar
Drives: 2012 535i M Sport Alpine White
20" M5 Replica on EBAY
Those are only 9.5" width for rear... Real ones are 10" width
Sean
2012 535i M sport Pkg - HUD - Alpine White w/ Beige
      06-21-2012, 10:44 AM   #20
Damrong
Drives: F11
Mine is 10" for the rear exactly as M5 and it is Forged Rims. Suspension are original I never touch anything.
      06-21-2012, 11:10 AM   #21
vinred26
Drives: BMW 5 Series
M6 wheels for 535 2012
Hello Guys,
I have a deal to buy Front : 255/40/19 Rear 285/35/19 wheel and tire set from M6. Wanted to know if any of you have tried to fit 2012 535 Xdrive.
I see tire width as 255 and 285 for M6 whereas most of the staggered I saw for 535 was 245 and 275.
Please let me know your thoughts and experience or suggestions.
Thanks in advance
      06-21-2012, 01:35 PM   #22
perisak
Drives: m550d
Is it original BMW M5 wheel or a copy?
5post
