Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > E90 Aftermarket Suspension Guide (aftermarket options list)
      10-07-2011, 05:01 AM   #111
noovis
noovis's Avatar
Czech_Republic
Drives: E92 335i
jsidhu510, have you got the answer? I'm having the same question.
      10-14-2011, 08:46 PM   #112
moonriver
moonriver's Avatar
Drives: E46 -E90 -F30 - F10 520i
Hi all,
I'm new member and seeking for help. I installed Hamann springs with stock shocks for my E90 LCI 320i and it doesn't ride as I expected. I am finding new shocks for it can you help me to choose correct shocks that can be fitted with Hamann springs? Tks
My Hamann springs:
      11-06-2011, 11:56 AM   #113
Ferdie
Drives: bmw E90
Originally Posted by E90Newbie View Post
This is such a newbie-question i'm almost embarrassed to even be asking but here goes:
I researched some prices online: the H&R sport springs are listed at approx. $300... so that's for a set of 4, right? In general, how much would it cost to drop the car (parts + installation)?
i paid 550 alignment included.
      11-06-2011, 12:01 PM   #114
Ferdie
Drives: bmw E90
I am finding new shocks for it can you help me to choose correct shocks that can be fitted with H&R springs? i changed the springs but not the shocks for my E90 and its Bouncy..Tks
      11-09-2011, 10:00 AM   #115
mookie45
mookie45's Avatar
770
Drives: 2017 AW 340i M-Sport
I'm looking for an OEM sport suspension kit or OEM performance suspension kit.
      11-10-2011, 09:32 AM   #116
Bimmer325z
Drives: 2006 BMW 325i
Help
If I lower my car with the pro-kit eibach springs do I need to purchase Any camber kits as well???
      11-10-2011, 04:12 PM   #117
Bimmer325z
Need info
I have a e90 325i 06 n was wonder if I lower my car with the pro-kit eibach springs do I need to purchase Any camber kits or control arms as well???
      03-19-2012, 07:40 PM   #118
Marc Fitz
Thailand
Drives: E90 320d M Sport
BMW Performance Chassis Kit
Need some advice, I have a E90 320d M Sport and looking at installing the BMW performance Chassis Kit does anyone know how much this will lower the car.
      04-17-2012, 12:03 AM   #119
BMW Junge für Leben
BMW Junge für Leben's Avatar
Drives: LCI E90 335i
hey so im hoping to get some advice on spring rates.
Im getting an AST 5100 coilover setup with swift springs from HP autowerks for my e90 335i.
I want some opinions on spring rates... something stiff for track use but comfortable enough to use on the road.
      06-29-2012, 05:44 PM   #120
1fast335i
Boostin Daily
Drives: 08 Alpine White 335 Sed/6AT
great info! eibach sportlines sound like a good option!
      08-01-2012, 09:17 PM   #121
manutdas11
EL JIMMY NEURON
manutdas11's Avatar
Drives: Jet Black E90
I'm a Noob.
What's up guys. So, I have an '07 328i with around 79k on it. I have 19" wheels on and I was thinking of lowering it. I got suggested by somebody to go with Eibach sport spring and camber correction kit...would it be okay to put that on my stock shocks, or would I have to buy new shocks (Bilstein for example) to achieve this? And what do the coilover kits normally include? Thanks in advance!
      09-10-2012, 06:03 PM   #122
tblagdon
Drives: 2007 328i
hey guys,
i literally have the same scenario as the above ^^^^
My 2007 328i sedan is lowered with Vogtland springs, and my shocks are wasted, very soft and floaty. 70k miles.
Need to get new ones, thinking koni or bilstein if you guys could help me out, that'd be awesome. Part numbers would be over the top helpful.
Thanks, Taylor
      09-10-2012, 06:14 PM   #123
Haasman
Drives: 07 335i
If it were my car I'd be checking on the
Koni: FSD
www.koni.com/58.html
or Bilsteins
Haasman
      09-24-2012, 06:24 AM   #124
GreekboyD
411
Drives: 2009 BMW 335d
2009 BMW 335d  [8.00]
I'm in the process of swapping out my entire OEM suspension parts with M3 ones. I'm already on KW V3s. Going to go with Megan Racing toe arms and Powergrid adjustable sway end link sets. Quaife LSD too at the same time as I don't want to waste more money dropping the subframe two times.
Great topic and open to suggestions.
      09-24-2012, 09:54 AM   #125
cvc 22349a
cvc 22349a's Avatar
Drives: 335i
I've got one: research the heck out of the M3 sway bars. If you don't mind loosing some of that independant suspension feel and don't punch it coming out of turns, I guess they're ok. Personally, I'd install the 15mm rear sway bar from the E93 335i instead of the M3 bar. Maybe you can drive a 335 w/M3 sway bars before you install them?
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS
      09-24-2012, 12:16 PM   #126
GreekboyD
411
Thanks for the suggestion. I purchased the rear M3 sway bar a couple of months ago so I'm sort of stuck with it in a way. I've heard what you said from a few guys already. Haven't purchased a front one yet.
      09-24-2012, 08:06 PM   #127
GreekboyD
411
One more thing:
As you guys know I'm piecing out the M3 suspension parts and I keep seeing the xenon rod and ABS sensor:
Front:
Xenon regulation rod - part #: 37142283867
Rear:
ABS sensor bracket - part #: 34522283017
Are these things I would need to buy too or are they there for people looking to replace them? My car is a 2009 BMW 335d.
Thanks.
      09-25-2012, 01:15 PM   #128
cvc 22349a
cvc 22349a's Avatar
Drives: 335i
You'll need the headlight leveling rod if you install the M3 front wishbone links and the plastic abs bracket if you install the M3 rear upper links
      09-25-2012, 02:56 PM   #129
GreekboyD
411
Thanks a lot. Looks like I will need them both.
      09-30-2012, 10:15 PM   #130
jvsxn
jvsxn's Avatar
Drives: e-ninety
Sup bro! The thing about this is that it's a quick fix for what you what for your car at the moment. If you choose to run stock shocks with aftermarket springs, it puts more stress on your shocks and it'll eventually go out so I wouldn't recommend running something aggressive. Keep in mind that if you go with shock+spring combo, you're at a fixed setting in terms of dampening/ride height.
Hiatus
      10-01-2012, 12:05 AM   #131
yamazaho
Wang D.D.S.
yamazaho's Avatar
Taiwan
185
Drives: 14' WRX, 15' W205
2006 325i  [7.76]
Originally Posted by moonriver View Post
Hi all,
Best choices IMO you got are Koni Yellow Sports shocks and Bilstein HD shocks.
No, but if you want to dial in the camber in the front, then yes you will need camber kit.
      10-01-2012, 03:07 AM   #132
manutdas11
EL JIMMY NEURON
manutdas11's Avatar
Sup broski! Daaaaayyyuummm, you dug up an old post haha I ended up getting ST V1 kit haha
2007 Jet Black E90 328i
Thread: http://www.e90post.com/forums/showthread.php?t=825249
Instagram: manutd_as
