BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Active Sound Design (ASD) Retrofit progress
ARMA SPEED
      12-03-2016, 03:24 AM   #111
Lancelot
France
573
Drives: 2017 m550i
Originally Posted by atzebmw View Post
Polarity you can see here.
KCAN2_H is Pin 18 and KCAN2_L is Pin 19.
Coding of ASD is very easy.
It's only VO Coding.
You only have to activate your VO, choose the ASD in Esys and push the button "code".
Then the ASD will be written with your VIN.
The ASD is listed in the ECUs now, but the "code" button in the coding interface is greyed out, am I missing something? It's available for all other ECUs, not this one.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
      12-03-2016, 06:20 AM   #112
Lancelot
France
573
Drives: 2017 m550i
OK I managed to put a CAF file using the "Detect CAF for SWE" command.
The remaining issues I have:
- Most annoying: sound shuts down completely when my ActiveHybrid goes to electric drive, or when the engine is shut down at stop. Very strange.
- Maybe related: when I try to change settings, they seem to revert to some default values, which are not completely incorrect but annoying.
Installation :
- KCAN2 signal comes from the trunk COMBOX wiring, I tapped the signal there
- Power comes from the POWER/GROUND cables of the Hifi harness and I see a 12V signal there even with engine down.
- Other wiring is audio signal which is working fine when the engine is running.
Then I chose one of the propositions, without being sure which is right:
I tried to FDL code this way:
But when coding and reloading it forces me back to other values
      12-03-2016, 07:21 AM   #113
CIWS
Moon Parasite
CIWS's Avatar
Drives: F98 X4M Competition
I'd stay off of page 1 of this thread. I'm getting malware warnings / blocking occurring from it. (this one is fine)
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged
      02-01-2017, 09:09 AM   #114
anom3
Drives: F30 335ix
Does anyone know how this works with a Tophifi (H&K) sound system?
There is no audio coming out of the head unit with my amp. Its sent via MOST to the AMP which spits out the full L7.
      02-01-2017, 09:59 AM   #115
atzebmw
Germany
590
Drives: Tesla Model 3
On page 4 of this thread I have inserted a graphic where you can see it. It is easier with hk, because you have to wire less cables.
      03-29-2017, 08:50 PM   #116
DrGadget
DrGadget's Avatar
Australia
46
Drives: M140i F20 LCI-2
2018 BMW M140i  [0.00]
Originally Posted by BmwFlooner View Post
This may be a dumb question, but why isn't the approach to try and pipe in the actual engine/exhaust sounds into the cabin by bypassing the sound-deadening material?
In my view a M2 Pure sounds like two people farting through tin cans. So, I can see why owners want to have a sweeter sound inside the car.
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016.
Sold: Alpine White 123d e82, 2010, 150kW/204hp.
      03-30-2017, 12:16 AM   #117
jmg
jmg's Avatar
18872
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
Why would anyone want to fool themselves? Is self inflicted ignorance still bliss?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
      04-14-2017, 04:00 PM   #118
anthony_harvey1
Drives: BMW F30 320ix
Sound cuts when stop/start cuts engine
Hi Lancelot did you ever get to the issue of the sound cutting out when the engine stops? I have a similar issue with the base speakers, in that when the auto stop/start cuts my engine, all the sound cuts out on my car? I'm not sure if this is a coding issue or not, I wonder if anyone has any advice on this?
Thanks
Tony
      04-15-2017, 01:31 AM   #119
Lancelot
France
573
Drives: 2017 m550i
Thanks
Tony
Hi
Yes you need to wire the RAD_ON pin to a 12V source (or to the proper wire from the head unit preferably), so i don't this issue anymore.
But i never got the ASD to produce any sound though.
      04-21-2017, 07:10 AM   #120
hsk1610
Drives: 2013 328i xDrive
Found a vendor who can provide a PnP wiring harness for the ASD, but only for NBT equipped vehicles. He's located in Korea and is charging about $230 USD for the harness. Unfortunately, I have the CIC. But if the ASD is suppose to connect to the line before the Hi-Fi amp and then to the speakers, does it matter which head unit I have? I assume he knows what he's talking about- since he specifically mentions he only has the harness for the NBT.
The used ASD amp that I purchased has the wiring harness cut off on one end. Do I just match the diagram and splice into the wiring going into the Hi-FI amp?
      04-21-2017, 07:48 AM   #121
atzebmw
Germany
590
The wiring for NBT and CIC seems to be near the same.
The only difference i found is the fuse F159 instead of F126.
hsk1610108.00
      04-21-2017, 07:52 AM   #122
hsk1610
Thanks for the info. I will be in Korea next week. Maybe I can show this to him and he can reassign the pin for the fuse so I can connect it when I return home.
      04-21-2017, 07:39 PM   #123
CazuaLLUK
Drives: 2014 335i Black F30 M Sport
Can I retrofit this to my N47 320d UK engine?
      05-05-2017, 08:20 AM   #124
hsk1610
Originally Posted by vitchie View Post
It connects between the head unit and the amp. I don't have a amp from factory as our base audio in South Africa comes without an amp. US spec cars come with Hi-Fi sound as standard. You will manually have to connect 22 individual wires to your amp's wiring harness. I tried to get a harness from technic, but he couldn't or wouldn't help.
Vitchie, I was able to purchase an ASD amp with the harness with one end cut off from the main wiring harness. So do I just need to match the colors and tap into the wiring harness feeding into the Hi-Fi amp in the trunk?
      05-13-2017, 04:29 PM   #125
anthony_harvey1
[QUOTE=Lancelot;21566546]Hi
But i never got the ASD to produce any sound though.[/QUOTE
Thanks very much I'll give this a go
      05-21-2017, 11:37 PM   #126
Jadamczyk22
Drives: 12 f30 328
Currently trying to get it working on my 2012 F30 which has Top Hifi. Just something to note...I had to buy a 2014 or newer amp, identical except it has 8 additional pins to attach the ASD module to it
Will keep you updated
      05-27-2017, 11:32 PM   #127
Jadamczyk22
Drives: 12 f30 328
Finally got it working.
Single most important thing to note:
Any car with HK audio, which did NOT come with ASD, will also need a new HK amp which supports ASD.
**The cars with ASD have a different HK amp than the cars without ASD**
You will need to buy a new amp with the extra pins on the connector.
The NON-ASD HK amp has a connector like this:
The ASD amp has a connector like this:
The ASD connector for the upgraded amp can be found on ebay and other online sources, part number 1355795. But be prepared to buy a new amp if you have HK audio and want to retrofit ASD
      06-06-2017, 04:22 PM   #128
cjsansom
Drives: 2012 F30
Originally Posted by jmg View Post
Funny how this whole thread is about how to program Active Sound IN while all the F8X guys talk about coding Active Sound OUT.
I totally get it though. A few years back when I read that Porsche was adding this to their cars, my 'knee jerk' reaction was how stupid that sounded.
But now, in my F30 N20 328i, I realize that my car is 'fun'. I have so much fun driving this car, and giving me the sound of an M4 inside my car would be so much fun for me! It doesn't make my car go faster. It's not there to impress anyone driving around me. It's there for me to have fun.
      06-06-2017, 08:19 PM   #129
jmg
jmg's Avatar
18872
2019 i3 BEV  [0.00]
I think what I don't like about it is that when you hold a low gear it sounds way too loud and fake.
IG: Raging_G82
      07-06-2017, 04:53 PM   #130
hsk1610
Found a seller on Taobao that seems to have the wiring harness for the ASD to the amp. Wondering if the harness will support the power and connect to the KCAN line to get our car to recognize the ASD amp and have sufficient power to drive both amps in the trunk.
Here is the link:
https://item.taobao.com/item.htm?spm...ucket=3#detail
The seller wrote back- had a friend translate- he has both harnesses for the Hi-fi amp and the Harmon Kardon amp.
      07-27-2017, 07:01 PM   #131
hsk1610
received the wiring harness but the connectors don't match
So I received the ASD wiring harness and one end plugs into the ASD amp but the other two that plugs into the Hi-Fi amp and the line from the vehicle don't match. I specifically mentioned that I had the Hi-Fi Amp.
Doesn't look like the harness is for the Harmon Kardon amp either. Does anyone know if they sent the harness for a different model type? Here are the pics.
      07-28-2017, 04:11 AM   #132
Flagar
Drives: BMW F30 328i
I paid R3000 (Around $290) for the part, new from dealership. Then paid R100 ($10) from a scapyard for the connector. It's nearly impossible to get a ASD connector. In the end I got a HiFi amp connector (From E92, even amp connector from E46 will work). You just have to trim off some of the guides on the outside of the connector.
Why did you get a new part ? Isnt it already built into the car or did you get a m3/m4 part ?
