Oil Filter Housing Mounting Surface, Corner Bolt Hole Broken Off
09-23-2018, 11:47 AM | #1 |
10
Rep 10
Hey guys,
A friend of mine wanted me to repair his OFHG on his 2008 328i. It appears that a previous owner worked on this....and broke off the corner of the mounting surface on the engine. I discovered this when removing the front bolt. The previous owner had repaired this corner with some type of putty/epoxy material.....possibly JB Weld or Belzona. I'm wondering what is the best way to go about repairing this? Is a cold weld material plausible....or will this need to be fixed by braze welding? I've never had to perform cast iron repair haha. |
09-23-2018, 03:15 PM | #2 |
Rep 589
The same spot is broken on mine. It's been JB welded for about 20,000 miles and it's been fine so far. There isn't much pressure there...the bolt is only compressing the gasket rather than fastening metal to metal. I've also been trying to figure out what to do about it, but it's been fine with the epoxy so far.
StradaRedlands4962.50 |
09-23-2018, 04:35 PM | #3 |
General
17371
Rep 18,769
This is most likely the result of a ham-fisted gorilla over torquing the bolt and cracking the head. I'd have the car towed, have the head tig welded, resurfaced and re-tapped at an automotive machine shop.
whyzee1251690.50 |
09-24-2018, 09:15 AM | #5 |
Rep 7,215
TBH the simplest thing to do would be to replace the head (used N52 heads with low miles are pretty cheap). Or leave it be if it's working ok.
You could try to weld it in place, but I think that will be tough, especially since now the surface is contaminated with both oil and whatever epoxy that is. You can't braze aluminum as far as I know.. |
09-24-2018, 10:29 AM | #6 | |
General
17371
Rep 18,769
Maybe affix a 1/4 aluminum plate to the head sandwitched inbetween the head and the OFH. It'd have to be machined of course to make the oil and coolant passages. Last edited by Efthreeoh; 09-24-2018 at 10:35 AM.. |
09-24-2018, 11:14 AM | #7 |
Rep 7,215
how much is all of that going to cost though. a good used head is like $300, it could be swapped at home in a weekend. Unless he owns an aluminum welder and knows how to do the repair himself, he's going to be paying a lot of labor.
09-24-2018, 11:50 AM | #8 |
851
Rep 2,793
i would either go the epoxy route and see if that doesnt hold.....if not i would fab up a notch and pull type screw to keep it sealed for a on the cheap fix.
the stealer would probably replace the head GLop |
09-25-2018, 01:30 AM | #9 | |
1007
Rep 2,109
If latter, there seems to be enough left on the main part for the bolt head to hold on to. My guess that is why the epoxy was holding on. Keep it same, as long as bolt can hold on there and apply enough pressure to clamp the gasket it would be fine. If you think the leak was because of that bolt, that is a different matter. If ain't broken don't fix it, if ain't broken that bad to fix it, still don't fix it |
10-04-2022, 09:46 PM | #10 |
14
Rep 10
Mine broke off too, try jb weld didn't hold, simple solution!! Just put a washer on and tighten it, the washer will hit against the engine block while you tighten.
10-06-2022, 05:17 PM | #11 | |
Rep 589
The JB weld on mine is still holding up fine after about 60k miles. Same gasket, no leaks, JB weld still appears to be holding. I guess I'll find out if I ever have to replace the gasket but it's been fine so far. |
StradaRedlands4962.50 Vnon3luv13.50 |
10-06-2022, 10:08 PM | #12 | ||
14
Rep 10
QUOTE]
I think why it didn't work because I try J-B Weld 37901 ExtremeHeat High Temperature Resistant Metallic instead of the original J-B weld. Regardless whichever materials you have in hand J-B weld original or put a washer. |
04-16-2024, 03:04 PM | #13 |
Rep 1
Is there a way just to replace whole thing i have problem where thing that holds hoes that pushes coolant trough broke off and i need to replace it i need as much info as possible like part number i have 2008 bmw 328i
04-16-2024, 06:21 PM | #14 |
Parts Pro
65
Rep 134
Drives: 2007 BMW 328xi 6MT
Have had the same problem myself from previous owner. the same crack location plus even little bit of the flat lower half. i tightened it down with the broken piece in there. Did multiple layers of Permatex Cold Weld, letting each layer cure in between coats. without coolant in the system for a dry mating area. there might be slight troubles removing housing (as the cold weld is holding the housing to block) when i need to but everything is sealed and FINALLY not leaking on me. (been 2 weeks)
E90 328xi 6MT | Intake Scoops | K&N + Charcoal Filter Delete | DIY Dinan 3in | 3.25in + 3.5in piping | N54 Manifold | Ceramic Coated Headers | Secondary Cat Delete | Xdelete | 3.91 Diffs | 22RPD Tune
04-17-2024, 01:48 AM | #15 | |
1007
Rep 2,109
2008 328i oil filter housing section from realoem.com: https://www.realoem.com/bmw/enUS/sho...diagId=11_3867 |
04-18-2024, 03:39 PM | #16 | |
Rep 582
04-19-2024, 02:21 PM | #18 |
Rep 582
Except every single photo and following response indicate otherwise. But yea RealOEM is where it's at for getting parts numbers.
