Mickey Mouse question
05-03-2023, 02:21 AM | #1 |
1007
Rep 2,244
Drives: 2007 328i / 2014 M235i
Do I need to drain the radiator when changing the Mickey Mouse flange?
I will use hose clamp pliers on the hose, how much coolant will drain out of the block side? Will putting the car on an incline / ramps help reduce the coolant flow from the block? The coolant isn’t old and I don’t care if some coolant spills on the belt as it needs changing anyways. |
05-03-2023, 06:13 AM | #2 |
Rep 423
Drives: 2007 E93 MT6
You may spill some coolant, but no need to drain the whole radiator. Just top it off after you are done, and run the coolant bleed procedure and you’ll be fine.
BMW: Doing Amazing(ly cheap) Things With Plastic (crap) Since the E90...
mecheng771007.00 StradaRedlands4998.50 |
05-03-2023, 06:45 AM | #3 | |
Baned
934
Rep 64
It`s a very simple procedure. If your battery is old, I would hook up a battery tender before bleeding the system. It takes about 10-12 minutes to bleed the system. Insert key in the key slot. With your foot off the brake, push the start button twice, or until all light come on the dash. You don't want to start the car. Turn both temp dials as high as they will go and put the fan on the lowest setting. Sometimes when you open the door after you started the procedure it turns off. So you might have to start the procedure again. Once the pump has run the cycle it will go quiet and you know your done. Don`t forget that you might need to add coolant while you`re bleeding the system. You need to have the cap off the coolant tank while you`re bleeding the system to see if you need to add coolant. |
05-03-2023, 08:03 AM | #4 |
Rep 504
Someone on the forum mentioned that the Rein metal mickey mouse flange sucks. I recently installed it, no issues, but get the ECS one for a tighter fit. I believe that's the one he recommended.
05-03-2023, 08:12 AM | #5 | |
1007
Rep 2,244
05-03-2023, 08:13 AM | #6 |
1007
Rep 2,244
05-03-2023, 09:23 AM | #7 | |
Baned
934
Rep 64
The only time I drain the coolant is when I change the oil cooler gasket. |
mecheng771007.00 |
05-03-2023, 09:47 AM | #9 |
Rep 6,312
I think the only thing I read was that the O ring over time leaks but then you can just buy the factory O ring part. I have a Rein one to for over a year now and no issues.
You don't need to drain coolant but do be prepared for some to come out the hole. |
05-03-2023, 10:46 AM | #10 |
Rep 3,662
I have the Rein one and no issues.
Back in 2018, I used an ebay one before any of the big companies started making them. That one had a VERY snug fit and I could barely draw it in even with the bolts. The Rein one I used on my current car drew in super easily so it's not as snug of a fit but mine hasn't had any leaks. |
mecheng771007.00 |
05-03-2023, 11:03 AM | #11 | |
1007
Rep 2,244
05-03-2023, 01:51 PM | #12 |
Art Collector
2427
Rep 3,450
I used the Rein one. No issues so far.
Just make sure you spit on it or otherwise lube it up. Don’t just stuff it in dry. You want to make sure the o-ring isn’t damaged when you insert it.
When I'm dead, just throw me in the trash.
AlpineBoost3927.50 StradaRedlands4998.50 |
05-03-2023, 03:57 PM | #14 | |
Art Collector
2427
Rep 3,450
K sorry I’ll stop
05-03-2023, 06:32 PM | #15 |
e91Owner
425
Rep 1,129
Another tip… just disconnect the return pipe to the reservoir put it into a large, clean container and run the bleed cycle for a few minutes into the container. You won’t leak any coolant at all that way.
I used the rein flange/hose combo on both my n52s. Still going strong 3 years later. Put a little silicone spray on the fitting and slid right in. |
mecheng771007.00 |
