07-21-2020, 08:44 PM | #89 |
14
Rep 19
I came across this thread after getting ready to pull the trigger on either Bilstein or H&R coilovers, only to learn what a pain this EDC business is. I just read the entire thread, and am I understanding right that folks here are successfully using the Dinan software, aftermarket lowering springs, and stock shocks with no issues?
07-21-2020, 09:46 PM | #90 | |
155
Rep 2,266
07-22-2020, 08:26 AM | #91 | |
15
Rep 57
While the Dinan setup is great. The EDC shocks do have limitations. I have a 2013 M sport with about 60k miles. I ran this setup for about 50k miles and the shocks are toast. My gripe about EDC is how expensive the shocks are vs the VW/Audi platform. Imo for what BMW shocks are bringing to the table is not worth it. You will always get better performance going passive and saving money. I'm going to install Koni Yellows and keep the Dinan Springs. |
07-22-2020, 08:49 AM | #92 |
Rep 519
152k on the original shocks still? Those things have to be toast by now
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
07-22-2020, 01:53 PM | #93 |
2070
Rep 2,640
Apparently they're not, they still work, I felt no changes in the suspension since the day I installed Dinan springs/shockware.
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
08-03-2020, 05:48 PM | #94 |
Rep 8
Am I safe in assuming the Dinan Shockware will not interfere with my Bootmod3 Tune? Also, is there any reason to avoid this if I am currently on H&R Super Sport springs? Thank you all. I've been contemplating this upgrade but had a few lingering questions.
08-03-2020, 06:03 PM | #96 | |
Rep 8
08-06-2020, 08:29 AM | #97 |
Rep 519
Got mine installed yesterday and definitely makes a big difference, $199.95 + $90 labor. This is how the car should have been set up from the factory.
Comfort mode is actually usable and doesn't float all over the place. Sport mode is much more plush and not as jarring on bumps yet handles and feels way more planted
08-21-2020, 03:08 PM | #98 |
BMW CCA Member
488
Rep 808
Yep +1. Add me to the Dinan Shockware converted.
Eco/Comfort is now Sport and eliminates all the weird diving about on the freeway after rolling bumps. Around town, a little stiffer, but marginally only noticeable. The new Sport mode is pretty awesome, it's like you upgraded shocks. Easily 25% stiffer then sport, but it's usable for hard cornering. I'm OCD picky about my mods and over-research like hell before install. For $199 and 30 min of whatever shop you choose for labor, it's pretty solid upgrade for adaptive suspensions. The ONLY caveat... it seems 2013 to 2016 cars -ish take the software right off the bat. The tech said most of the newer F30s require a couple attempts. Thinking it's the initial software revision/version that may be causing that issue. |
11-17-2020, 05:59 PM | #100 |
3912
Rep 3,129
11-17-2020, 07:33 PM | #101 |
74
Rep 143
My car, before CPO'd, had Dinan Stage 1 and Shockware that were subsequently removed to CPO the car. I understand how the piggyback was physically removed, but is there a way to tell if the Shockware was actually removed?
11-17-2020, 08:17 PM | #102 | |
3912
Rep 3,129
11-18-2020, 01:13 PM | #103 | |
Rep 884
11-20-2020, 06:39 AM | #104 |
Rep 519
Sorry, but compared to the stock "sport" yes it is.
11-29-2020, 04:27 PM | #105 |
16
Rep 132
Dinan shockware with Run Flat Tires (RFTs)
anyone stating their experience with Shockware should specify if they are still using RFTs. My 2014 335 Xi does not take Shockware it seems since a communication link from my ECU was changed later in the build and Dinan only links to that. The point of my message is that with RFTs long since thrown away in favor of Michelin AS3+ the stock normal setting is both floaty and harsh, if that is possible. I have to use Sport setting always. Just wish I had shockware for even better setting options and have OEM sport engaged when choosing the "normal" setting in the cabin. The Michelins are SOOO much better, btw.
Charlie |
12-01-2020, 06:30 PM | #106 |
Rep 884
The dampers are tuned for more stiffness; yet the ride is plusher than the stock sport setting. Yeah, okay.
01-19-2021, 10:31 AM | #107 |
Rep 849
Drives: BMW 435i
I finally pulled the trigger and had the Shockware installed on my '16 435 yesterday.
Put me down as one very happy customer. The car now rides like it should have from the factory. I noticed an improvement almost immediately when pulling away from the shop. In both modes the car has far better body control, all of the float and bounce found in BMW's comfort mode is gone and even the new sport mode feels much more stable than BMW's version. I know there has been endless debate about whether Dinan actually changed anything from BMW's sport mode when they made it their "normal" with this software. My butt dyno tells me it is different and not essentially a "copy and paste". The differences are very subtle, but I do think it is different, and for the better. I guess the best way to describe it is the car feels much more stable in Dinan's "normal" mode than it ever did in BMW's sport mode. As for the new Dinan sport mode, I haven't had a chance to really give it a test. Between a drive home on fairly straight roads, and the fact I'm running my winter tire/wheel set up, safely pushing the car isn't really possible right now. In the little bit I could test out in the few transitions/turns I encountered, the car stayed much flatter and stable. I give it a big thumbs up. I'll also give a shout-out to the guys at Bimmers R Us for a great experience at their shop.
Stop by and check out my blog: The Car Geek
03-03-2021, 12:17 PM | #108 |
Rep 4,879
Echoing what others have said. The handles beautiful now. Corners that were a bit on the edge at 50MPH are now at 58MPH.
Ride isn't that much worse than before, with comfort feeling a more like sport on stock form. Super happy and perfect "cherry" on the sundae of powertrain mods I did. |
03-03-2021, 12:19 PM | #109 |
Clutch Rider
Rep 148
I'm so jealous, I tried having this installed twice and the computer wouldn't take the program. My MPPK tune was deleted in the process and that had to be reinstalled.
RootCanal-
