What type/brand of coolant can I put in my 335i?
08-19-2008, 09:27 PM | #1 |
Rep 1,914
Have gotten the low coolant level icon twice. Don't really want to trek up to the dealership to get the BMW fluid. What alternative fluid is compatible?
08-19-2008, 09:31 PM | #2 |
Rep 986
08-19-2008, 09:32 PM | #3 |
HESSEN///M3
10
Rep 225
I am not 100% but I am sure others will work but is your dealership that far away?
MB 330i ZSP Sport PKG
TIAG/Imola E46 M3/OEM ZCP wheels "A6 direction Saarbrücken" |
08-19-2008, 09:41 PM | #4 |
Schumacher
791
Rep 2,282
Drives: E30 325is,E93 M3,X7M50,F06 M6
There are a few aftermarket coolants that will work, but I dont think you will find any of them at the local walmart or autozone.
Please dont use regular coolant, most of it is highly corrosive and will wear out parts faster. Since its the summer and you are not that low, I would just add distilled water. The BMW mix is 50% coolant and 50% distilled water anyway so if the mix is 45/55 coolant/water it wont make much of a difference. Infact you could run on distilled water alone if you wanted if you were only in warmer weather. So two options, run to the dealer, or run to the super market and add some distilled water.
08-19-2008, 10:17 PM | #7 |
Schumacher
791
Rep 2,282
Evans NPG+ Waterless Coolant is another one but not easy to find.
Again if you aren't horribly low I would just add some distilled water.
08-20-2008, 09:46 AM | #9 |
Rep 11,857
Drives: MY24 G01 AW Msport
its recommend that u use bmw cooland
i was having the same issue..i think there something wrong with cap, evaporates the coolant faster then usual i only have 13k on my car, i poured about 1/2 gallon |
08-20-2008, 11:54 AM | #11 |
Rep 10,509
Personally, I would add in distilled water + water wetter for now and visit the dealer to get the leak investigated thoroughly.
Don't take your chances with aftermarket coolant. The additives could be corrosive |
08-20-2008, 01:03 PM | #13 |
pew pew
166
Rep 6,781
Just use distilled water and take it in. It's a closed system and if you're losing coolant then there's a problem.
CSL replicas are now CSL counterfeits. Jesus saves, like Valentine1.
08-20-2008, 01:10 PM | #14 |
Deny everything
219
Rep 11,378
Drives: 2006 330i; 2015 X6, S1000RR
I had the light too.
The container was empty! Called the dealer and they said it was "normal" due to evaporation but asked to bring it in to check. They recommended against anything other than BMW coolant. Or just pour water. I took it in and they top it off. Had no time to leave it so they just asked to keep an eye on it and bring it back if the light comes back on.
I need a drink |
08-20-2008, 02:30 PM | #15 |
Rep 151
Before you buy antifreeze, do your homework. Some of the advice given here is good; other advice is, well, not as accurate as possible. Fwiw, I like Zerex products and here is a link to their website showing which products we can use. As a side note, I have always added distilled water to antifreeze when changing out. If I really needed to get somewhere and my fluid level ws low, I would add water until I could change it out.
Here's the link: http://www.valvoline.com/zerex/pdf/Z...d=1B5D1AEA1AFC |
08-20-2008, 04:30 PM | #16 |
Schumacher
791
Rep 2,282
I have used Water wetter on my E46 with a 50/50 BMW coolant and distilled water mix. It does lower the temp slightly.
09-22-2008, 11:41 AM | #18 |
Rep 499
Just got this message this morning, but the next time I started the car (after driving ~20 miles) the message was no longer there. Weird.
I'm an hour from my dealer.. I don't want to go there just for coolant. I guess I'll check the reservoir and add water if it doesn't look too low... |
09-22-2008, 12:34 PM | #19 | |
Deny everything
219
Rep 11,378
Then it will stay on for good. Water will do.
I need a drink |
09-22-2008, 12:48 PM | #20 | |
pew pew
166
Rep 6,781
07-23-2013, 06:13 PM | #21 |
Rep 15
OEM BMW coolant is zerek G-48 and can only be bought at a BMW dealership as they have a contract with vavoline (makers of zerek g48). You cannot buy G-48 at any retail store, only G-05. The difference between G-48 and G-05 is that the G-48 has a higher pH, no nitrate, and other subtle differences. So the G-48 is more refined than the G-05. Some say the G-48 is better for the cooling system and engine due to less corrosion, some say that its total BS and it doesn't make a difference. It's all up to you as to what you want to do.
gde06116.00 |
