09-10-2014, 02:58 PM | #7239 |
General
10446
Rep 40,804
09-10-2014, 10:38 PM | #7241 |
General
10446
Rep 40,804
PM sent.
09-11-2014, 03:00 AM | #7242 |
Rep 3
Hi guys,
Please help me decide which HU I have. Esys show the following: SVT[WBA1A1100Exxxxxx] ECUs(12) ACSM[1] BKOMBI[60] DME[12] DSC[29] EPS[30] FEM_BODY[40] FEM_GW[10] HU_ENTRY[63] ICM[1c] IHKA[78] REM[72] ZBE[67] When editing CAFD it shows this: CAFD Editing (FDL Editor) CAF [HU_CICHB] Header Daten 3000 HMI, 78 3001 EXBOX, 78 3002 AUDIO_TUNER_TRAFFIC, 78 3003 TELEFON_TELEMATIK_ONLINE, 50 3004 SYSTEM_EINSTELLUNGEN, 64 3005 APIX CID, 64 3400 CAF_ID, 08 3401 SIGNATURE, 84 Do I have HU_ENTRY or HU_CIC? Thanks
BMW F20, 116i, July-2013, 6NH, NoNav, NoCombox, 5 button iDrive, 6" LCD, USB&AUX in armrest
09-11-2014, 06:21 AM | #7243 |
General
10446
Rep 40,804
You have Entry Head Unit. The CAFD name means nothing here.
09-12-2014, 07:09 PM | #7244 |
Rep 21
Hi Shawn, thank you for pointing me in the right direction. I found it, attached are the changes required for anybody interested in doing it. Searching for "country" in the KAFAS module finds 5 entries (this is for the F30 I have, other models may have different number of entries) out of which 3 have options selectable from the drop down menu. In my case all I had to do is replace "Canada" with ECE for the first 2 (in Country_Variation and TSM_Country_Variation) and ECE_White for the the third instance ( in Country_Coding_Display). This resulted in the speed limit sign being displayed just like in the European models.
09-12-2014, 07:34 PM | #7245 |
General
10446
Rep 40,804
Glad it worked for you.
09-13-2014, 01:21 PM | #7246 |
Rep 8
Hi Shawn,
I have some questions need you help. 1.activate idrive offce I saw bmw coding datebase has code,idrive office is disabled based on country controllers. this will enables you to have access to the office menu which will be located on the main idrive menu,so need to modify the read FA remove country controller code SL8AX from the vehicle FA then vo code cmb_media and hu_cic.but i find my vehicle FA ,I don't have SL8AX or vo 8AX,what's the SL8AX mean in us bmw vo code? my f35 vehicle FA salapa-element only has 1AK,1CA,255,2H3,2TB,2VL,3AG,430,488,494,4B8,4DM,50 2,522,534,544,548,5AH,609,676,6NK,6UH,6VA,6WA,702, 7K4,7S2,825,866,878,892,8AA,8KE,8SD,8SM,8IN,993.I searched bmwvin code P7K4A description means CKD CHINA HIGH,is this country controller? I removed 7K4 from FA and try to vo code HU_CIC CMB_MEDIA, code HU_CIC MACRO_PIM > AKTIV , HU_CIC=>3003 SYSTEM_EINSTELLUNGEN=>COUNTRY=hongkong,after that,still no office menu show on idrive menu,do i miss something? 2.I saw a video ,that f30 changed vehicle emergency lights double flash,it's very personality,but i searched in f30 Fem_body ,it doesn't has DOPPELBLINKIMPULS_WARNBLK code which can change car emergency lights double flash,can we has it?and i searched key words BLINK in the fem_body module which code is correct to change the double flash ? thanks. |
09-13-2014, 03:14 PM | #7247 |
Rep 14
I am starting to learn coding and have a question about E-Sys token. DO I NEED IT? I have seen mixed answers and want to find out so i dont screw anything up in my car. I heard you dont need it if you are doing the basic coding like DVDinMotion and such. Is this true?
09-13-2014, 03:18 PM | #7248 | |
General
10446
Rep 40,804
You do need a Token solution to FDL Code. Considering 95% of coding is FDL Coding, including DVD-In-Motion, I would say you need a Token solution.
09-13-2014, 08:20 PM | #7249 |
Rep 14
What will happen when I try to code without token? Brick my car or will it give me an error? The reason I ask is because I dont know if my token is installed properly!
09-13-2014, 09:08 PM | #7250 |
General
10446
Rep 40,804
You will just get an error code. It won't do any harm.
09-13-2014, 09:33 PM | #7252 | |
General
10446
Rep 40,804
You will need to get with your Token solution provider for resolution.
09-13-2014, 10:12 PM | #7253 | |
General
10446
Rep 40,804
I have never found a way code the double blink flashers.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 09-14-2014 at 05:04 AM.. |
09-14-2014, 02:06 AM | #7255 | |
General
10446
Rep 40,804
Now if you somehow "break" the car coding it, and they can pin it on your coding, they may refuse to repair it under warranty.
09-14-2014, 04:33 AM | #7257 |
General
10446
Rep 40,804
Load factory FA, VO Code ECU(s) to restore factory settings.
09-14-2014, 10:29 AM | #7258 | |
Rep 1
Have you solved the BMW live and internet problem? I'm facing the same... |
09-14-2014, 02:27 PM | #7259 |
81
Rep 80
Shawn, could i get access to the software/token?
Much appreciated!
2018 BMW 440i Coupe, High-Exec, MPPSK, HUD, Dig dash, touch-nav
2014 BMW 335, High-Exec, MPPK, MPE, HUD 2011 Audi A5 2009 Alfa 159 2005 Alfa 156 |
09-14-2014, 09:53 PM | #7260 |
Rep 1
Help with installation
Hello folks
Good night for everyone my name is Bruno i have been on this fórum from long time, but just now i bought another bmw 320i and im totally lost about install the Esys program, can someone help me please i already tried to search in older posts but i did not find =/ thanks a lot |
