Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      02-02-2017, 06:48 PM   #89
x.shell
x.shell's Avatar
6585
Drives: ▋ ▉▉
Originally Posted by Glina View Post
I'll like to know that too.
If someone can provide me with that information, I will post it up.
      02-03-2017, 08:10 AM   #90
m4282
Drives: Tanzanite Blue M4 w/Leather
ZCP rates are 195 for front and 650 for rear- this is what I have read on this forum where a ZCP owner has measured this.
      06-22-2017, 09:29 AM   #91
jim996
127
Drives: 2016 M4
Nitron Coilovers available now
http://f80.bimmerpost.com/forums/sho....php?t=1385671
      06-22-2017, 01:50 PM   #92
x.shell
x.shell's Avatar
6585
Drives: ▋ ▉▉
Originally Posted by jim996 View Post
Thanks for the info. Adding to the list. Are these in production now or are they still in development?
      06-22-2017, 01:56 PM   #93
x.shell
x.shell's Avatar
6585
Drives: ▋ ▉▉
Updated with info on Nitron Coilovers and AST Coilovers.
      06-22-2017, 03:47 PM   #94
jim996
127
Drives: 2016 M4
They were developed on my car. I'm driving on them (brilliant by the way!) so they will be available to buy in the next week or 2 from Nitron in the UK
http://www.nitron.co.uk/catalogue_it...9&prodID=87643
http://www.nitron.co.uk/catalogue_it...9&prodID=87642
      06-29-2017, 02:27 PM   #95
jim996
127
Drives: 2016 M4
[QUOTE=jim996;21862019]They were developed on my car. I'm driving on them (brilliant by the way!) so they will be available to buy in the next week or 2 from Nitron in the UK
Available to order now in the UK
      07-06-2017, 01:38 PM   #96
M4Hulk
Drives: M4
Spax has a springs set now 25mm drop all round. Also Vogtland Sport Lowering Springs, 35mm drop all round.
      07-06-2017, 01:54 PM   #97
x.shell
x.shell's Avatar
6585
Drives: ▋ ▉▉
Links please.
      07-08-2017, 01:50 PM   #98
M4Hulk
Drives: M4
Links please.
http://www.spax.biz/home.php
Their called Spax SSX springs.
http://www.vogtland.com
      08-09-2017, 09:02 PM   #99
x.shell
x.shell's Avatar
6585
Drives: ▋ ▉▉
Added info on the KW Adaptive DDC coilovers.
      09-07-2017, 12:27 AM   #100
M4 CSL
M4 CSL's Avatar
Australia
231
Drives: ///M4
KW CS 3-Way Now available 628 Ft/lbs Fr and 1028 ft Lbs Rear
///M4 | AKRA Evo & DP's | Brembo GT BBK | MSR CAI & CP's | MPSC2 |
Suspension : | KW CS 3-way | Dinan Toe Links | GC ARWJ & End links | IND Shims | SPL Control arms & End links | aFe Bars |
      09-14-2017, 12:48 AM   #101
UG999
Drives: M3
aluminum brace Hex bolt 16mm torque spec
Anyone have the aluminum brace 16mm Hex bolt torque spec? I know it listed as 35ft.lbs but I believe it's more. Thanks!
for
I've compiled a list of Springs and Coilovers for the F8X. This post will be updated as more information becomes available. Please help by letting me know if there is a change in status or if a new kit becomes available.
SPRINGS
AC SCHNITZER - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1140744
http://f80.bimmerpost.com/forums/sho....php?t=1104262
DROP: 25-30mm/10-15mm; 0.98"-1.18"/0.39"-0.59"
aFe SPRINGS - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1233351
EIBACH PRO KIT EURO - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1129065
http://f80.bimmerpost.com/forums/sho....php?t=1103311
DROP: 20mm/5-10mm; 0.78"/0.20"-0.40"
EIBACH PRO KIT USA - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1023275
DROP: 20mm/5mm; 0.80"/0.20"
EMMANUEL DESIGN SPRINGS - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1341394
http://f80.bimmerpost.com/forums/sho...3#post21105883
DROP F80: 1.3"/0.3"
DROP F82: 1.3"/0.9"
H&R SPORT - Status: Available
F80 - http://f80.bimmerpost.com/forums/sho....php?t=1076737
F80 F82 435i - http://f80.bimmerpost.com/forums/sho....php?t=1104141
H&R SUPER SPORT - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1125229
MACHT SCHNELL SPORT COMPETITION - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1159060
http://f80.bimmerpost.com/forums/sho....php?t=1156814
DROP: 28mm/19mm; 1.10"/0.75"
Note:Macht Schnell uses the same spring set for the F80 and F82. Shims are provided for the F80 rear to balance out the height discrepancy.
STATUS GRUPPE - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1112333
DROP F80: 33mm/20mm; 1.30"/0.8"
DROP F82: 33mm/30.5mm; 1.30"/1.20"
SWIFT SPEC R - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1145147
DROP F80: 25mm/10mm; 1.00"/0.40"
DROP F82: 28mm/23mm; 1.10"/0.90"
HEIGHT ADJ SLEEVE KITS
BMW M-PERFORMANCE COILOVER SLEEVE KIT - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1191427
DINAN - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1133605
GROUND CONTROL COILOVER CONVERSION KIT - Status: Available
http://f80.bimmerpost.com/forums/sho...8#post19236448
KW HAS - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1044712
IMPORTANT INFO: KW HAS takes away some inner clearance in the wheel well. Research wheel width/offset and tire size to make sure you will not be rubbing.
Note: KW HAS is available for the M3, M4, and M4 convertible.
COILOVERS
IMPORTANT INFO: Coilover kits that come with top-hats or camber plates have either 3 bolt pattern or 5 bolt pattern. Please reference your M3/M4 production date to choose the correct one.
AC SCHNITZER RS ADJUSTABLE SUSPENSION - Status: Available
http://shop.ac-schnitzer.co.uk/rs-ad...f82-6068-p.asp
aFe CONTROL FEATHERLIGHT SINGLE ADJ - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1158803
AST 5100 1-Way, 5200 2-Way, 5300 3-Way - Status: Available
http://f80.bimmerpost.com/forums/sho...&highlight=ast
Review: http://f80.bimmerpost.com/forums/sho....php?t=1413065
BC RACING - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1042668
BILSTEIN PSS9 / PSS10 - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1129901
BILSTEIN CLUBSPORT - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1046894
BILSTEIN DAMPTRONIC - Status: Dev
http://f80.bimmerpost.com/forums/sho....php?t=1126739
CA TUNED COILOVERS - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1182388
Confirmed: CA Tuned kits are now available with the 5 bolt top-hat/camber plates for post 01/2015 production F8Xs.
FORTUNE AUTO - Status: Dev
http://f80.bimmerpost.com/forums/sho....php?t=1112324
JRZ RS TWO - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1132585
http://f80.bimmerpost.com/forums/sho....php?t=1045730
Confirmed: JRZ RS TWO kits are now available with the 5 bolt top-hat/camber plates for post 01/2015 production F8Xs.
For the JRZ RS TWO coilovers you can choose between Touring and Sport. The Touring version utilizes the OEM top hats. The Sport version has the option(s) to include camber plates and rear mounting plates or using the OEM top hats.
KW Variant 3 - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1062872
KW CLUBSPORT 2-WAY AND 3-WAY - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1079056
Confirmed: KW Clubsports are now available with the 5 bolt top-hat/camber plates for post 01/2015 production F8Xs.
KW GTS-SPEC CLUBSPORT 3-WAY- Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1221809
Video here - http://f80.bimmerpost.com/forums/sho....php?t=1249626
The new MSRP places the 3 way ClubSport closer in price to the 2 way adjustable ClubSport, enabling more M4 drivers to enjoy some of the magic that is available in the M4 GTS.
KW Adaptive DDC - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1411096
MOTION CONTROL SUSPENSION - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1184964
http://f80.bimmerpost.com/forums/sho...9&postcount=51
http://www.motioncontrolsuspension.c...ts/prices.html
For the MCS coilovers you can choose between MCS 2-Way and MCS 3-Way. Ground Control Camber plates can be paired with this kit. Damper and Spring Rate values are all customizable.
MOTON ADJUSTABLE COILOVERS - Status: Available
http://f80.bimmerpost.com/forums/sho...php?p=19702168
Confirmed: Moton Adjustable Coiovers will be available with the 5 bolt top-hat/camber plates for post 01/2015 production F8Xs.
Moton Adjustable Coilovers comes in the following configurations: 2-Way Sport, 3-Way Motorsport Pro, and 4-Way Motorsport Pro. The 3-way and 4-way Motorsport Pro rears will have a true spring-coil-over-shock configuration.
NITRON COILOVERS - Status: Available
OHLINS Road & Track - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1193450
OHLINS TTX - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1129675
The TTX is built to spec.
SACHS ZF COILOVERS - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1333320
STATUS GRUPPE COILOVERS - Status: Available
http://f80.bimmerpost.com/forums/sho...9&postcount=32
TC KLINE - Status: Available
http://f80.bimmerpost.com/forums/sho....php?t=1072499
Confirmed: TC KLINE SA and DA are now available with the 5 bolt top-hat/camber plates for post 01/2015 production F8Xs.
SPRING RATE CONVERSION
OEM spring rates for the F80/F82 is 185 lb/ft Front, 575 lb/ft Rear
OEM COMPETITION PACK spring rates for the F80/F82 is 198 lbs/ft Front, 685 lbs/ft Rear
kg/mm to lbs/in
16 = 896
15 = 840
14 = 784
13 = 728
12 = 672
11 = 616
10 = 560
9.0 = 504
8.5 = 476
8.0 = 448
7.5 = 420
7.0 = 392
6.5 = 364
6.0 = 336
5.5 = 308
5.0 = 280
4.5 = 252
4.0 = 224
3.0 = 168
2.0 = 112
Torque Specs and Bolt Information:
Front Suspension:
Plastic Shroud Bolts - 10mm - ¼ Turn
Carbon Brace Bolts - 13mm - 12 ft.lbs.
Carbon Brace to Coolant Tank Bolt - 10mm - Snug
(A) Aluminum Brace E-Torx Bolts - 9mm - 25 ft.lbs.
(B) Aluminum Brace E-Torx Bolts - 10mm - 30 ft.lbs.
(C) Aluminum Brace Cowl Bolts - 16mm - 35 ft.lbs
Strut Hat Bolts - 13mm - 25 ft.lbs.
Strut Spindle Nut - 18mm-12pt - 25 ft.lbs.
Strut Pinch Bolts - 16mm - 60 ft.lbs.
Sway Bar End Links - 16mm/T30 - 44 ft.lbs.
Headlight Leveling Sensor - 10mm - Snug
Rear:
Lower Strut Bolt - 18mm - 74 ft.lbs.
Eccentric Bolt - 21mm/18mm - 74 ft.lbs.
Installation video by evolmotorsprt
      09-14-2017, 04:02 AM   #102
priceVob
Drives: Man
оо
Это не логично
      10-23-2017, 08:08 PM   #103
MentholGuy
MentholGuy's Avatar
Drives: 11 E90 M3
AST suspension has lowering springs for F8X M3/M4
http://astsuspension-na.com/index.ph.../bmw-m3m4-25mm
      11-06-2017, 12:11 PM   #104
Colinv6
Colinv6's Avatar
4051
Drives: 2020 M4 comp, Mexico / Opal
Noticed that H&R now do a Coilover kit for this platform.
2020 M4 competition Mexico Blue / Opal white ultimate pack, full M perf carbon kit, MP HAS, Carbon Ceramics, 763M with cup2’s.
Instagram c1_cdg
      11-06-2017, 01:38 PM   #105
x.shell
x.shell's Avatar
6585
Drives: ▋ ▉▉
Thanks for that. Added to the list.
      11-28-2017, 02:02 AM   #106
ashmostro
Drives: 2020 M4cs | 2022 M550i
AFe has come out with a HAS option with promising specs.
Excerpt below is from AFe's product page. Note the spring rates which put these between the OEM CP and Swift Spec-R’s.
https://afepower.com/afe-control-var...height-springs
aFe Control would like to introduce the Variable Height Springs (VHS) for the 2014-2016 BMW M2/M3/M4 (F80/82/83/87) chassis.
The VHS system was developed for enthusiasts who desire the ride height adjustability of a coil over while still retaining their OEM adaptive factory shock absorbers. The system features slip on coil over sleeves for the front struts that are TIG welded, and zinc plated for maximum durability.
Installation is simple, just press off the factory spring seat and replace with the aFe Control VHS. The system includes mounts for the OEM accelerometers and sway bar. M specific front springs are included and feature a progressive 224 lb/in" rate while offering 0.5 “ to 1.5 “ of lowering.
In the rear, CNC machined 6061-T6 aluminum ride height adjusters also offer 0.5 “ to 1.5 “ of lowering and maintain the factory spring location for quiet operation and strength. The 700 lb/in" rear springs were developed specifically for this application to maintain proper balance with the adaptive ride shocks.
Elevate your driving experience with the comfort, precision and excitement of the aFe Control Variable Height Springs (VHS).
Also Fits: BMW M2/M3/M4 F80/82/83-87 14-16 non adaptive ride
      11-28-2017, 03:36 AM   #107
x.shell
x.shell's Avatar
6585
Drives: ▋ ▉▉
Thanks. Added to the list.
      12-03-2017, 02:55 PM   #108
M4Hulk
Drives: M4
Spax springs not added to the list.
      12-03-2017, 03:41 PM   #109
x.shell
x.shell's Avatar
6585
Drives: ▋ ▉▉
Give me a link to an actual product or review of one on this forum. I went searching for it on the website you posted. There is only a link to springs for "M3" with no description. There is no clarification on whether it's for an M3 E30, E36, E46, E90/92, or F80/82. All their other springs include the chassis code.
      03-20-2018, 02:08 PM   #110
x.shell
x.shell's Avatar
6585
Drives: ▋ ▉▉
Added KW V4 to the list.
coilovers, sleeve kit, springs, suspension
f80post
