12-10-2021, 11:06 AM | #1 |
52
Rep 29
335i RWD Suspension Upgrades
Let me first start off by apologizing if this information was buried in another thread, but I'd like to get a consensus on which Bilstein Struts I should be considering and the components that should be included in the rebuild/replacement.
Background: I have a 2015 335i M-Sport with EDC and need to replace my front struts since they're leaking. Since I have 65k miles on the car; I was also going to replace the rear struts as preventative maintenance along with the front lower control arm bushings which have minor cracks. Front: 235 /40 R18 Non-runflat Rear: 255 / 40 R18 Runflat I am in Houston which is known for poor/terrible streets, but I spend a lot of time on the highways which are pretty nice. We also have some stupidly steep driveways which I am always careful about but still scrape on. Strut Selection: I've done quite a bit of digging through the forum and I believe I want to replace the OEM EDC Struts with Bilstein B6 to primarily retain the EDC functionality while also retaining a comfortable ride. Bilstein B4 struts seem to be very difficult to find and have seen a few posts that they're back-ordered until March 2022. Due to the millage on the car, should I consider reusing the springs or would it be recommended to pair Dinan springs which would provide a 3/4" drop. I've read a lot of posts of X-Drive cars opting for ACS springs with B6 Struts, should I be considering these as well? Going with H&R would be too large or a drop and I don't think they're compatible with the B6 struts. Suspension Replacement: For the suspension refresh, I am considering replacing all of the rubber insulators, dust guards, and bump stops. I will also replace the upper and lower control arms in the front with TRW components from FCP Euro (KIT-31126855741KT3). BMW-31336855440 (Front Bump Stops) BMW-31336787114 (Front Insulator) BMW-31306791712 (Front Dust Guard) BMW-33536791538 (Rear Bump Stops) BMW-33536791709 (Rear Lower Insulator) BMW-33536764419 (Rear Upper Insulator) All parts priced out at FCP Euro and BWM South Atlanta for whats listed above including control arms is $530. Should I also be replacing the top hats (Front & Rear)? Adding in the B6 Damptronic Struts from BimmerWorld ($1770) and Dinan Performance Spring Set (Part Number D100-0910); costs for the rebuild total $2500.
2015 M-Sport 335i Melbourne Red
12-10-2021, 12:48 PM | #2 | |
Rep 787
Also, some of the bilstein front dampers use integrated bump stops, not sure which ones, but make sure with the ones you are buying. If so, then you don't use the oem bump stop along with it.
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
wayward.travel52.00 |
12-10-2021, 12:58 PM | #3 |
Rep 10,286
B6 Damptronic shocks will provide a much stiffer ride than OEM / B4 Damptronic struts.
Is comfort in daily driving scenarios important? Of course comfort means different things to different drivers ... always good to reconfirm expectations. |
12-10-2021, 02:05 PM | #4 | |
52
Rep 29
I believe you're correct about the front struts having internal bump stops; although it's been difficult to find confirmation. cfm56d7b I really like the stiffness of the OEM suspension in sport mode. Even if the B6 struts are slightly stiffer in comfort mode than the current sport mode feeling, I am happy with that. The springs will also accentuate the stiffness of the strut, any feedback from RWD owners with B6 struts would be helpful.
12-10-2021, 03:30 PM | #5 | |
Rep 1,574
I got my B4's fm FCP also. I was told by them and Bilstein that B-4's do NOT have internal Bumpstops!! Pls check with them to confirm that for your year/model they do have internal bump stops.
12-11-2021, 03:57 AM | #6 |
gds
Rep 25
Bilstein B4 /B6 Damptronic are twin tube struts and use external bump stops front and rear so you have to buy new ones or to reuse the old ones( not recommended! )
Bilstein B4 Passive are twin tube struts :they also use external bumpstops front and rear. Bilstein B6/B8 Passive are monotube struts and have internal bumpstops for the FRONT struts and external bumpstops for the rear. |
12-11-2021, 04:56 PM | #7 | |
Rep 10,286
12-12-2021, 10:05 AM | #8 | |
52
Rep 29
cfm56d7b, I've read that B6 struts are intended to be paired with OEM springs; although a modest 20 mm drop should work well with them too. Since I want to retain the EDC functionality, I'm constrained to Bilstein B4, B6, or B16's. As B4's are direct OEM replacements, they also wouldn't be designed for lowering springs. B16's would lower the car too much. Is there another spring set I should be considering outside Dinan or ACS?
12-12-2021, 12:37 PM | #9 | ||
Rep 787
03-02-2022, 12:30 PM | #10 |
52
Rep 29
I've been away for the last few months and am finally home and back looking through the forum to take a decision on refreshing my suspension. To maintain my EDC I don't believe there is anything available outside of Bilstein B4 or B6. I've read great reviews about Koni; although would really prefer to keep the EDC unless there was a very easy and cost-effective way to incorporate non-EDC struts.
From Shock Warehouse; both sets wouldn't be available until mid-April which I can live with. However, before placing the order I'd appreciate some help with spring selection. I originally wanted to get Dinan springs primarily because they were half the price of replacing the original BMW springs while also providing a subtle drop. However, at 30% increase in stiffness over M-Sport Springs, it may be too much for a daily driver. ACS, Eibach, and H&R drop the car too much for Houston driveways and speedbumps. FaRKle! posted a great thread about utilizing F80 springs which could be ideal. Does anyone know what struts the F80 uses (is it Bilstein B6, B4, or something else)?
11-04-2022, 03:43 PM | #11 |
52
Rep 29
KONI SA for RWD F30
I'm considering the following suspension swap since finding either Bilstein B4 or B6 Damptronic Shocks & Struts is impossible. I've read several reviews but am finding most are specific for XDrive; do any RWD cars have experience with the proposed setup?
KONI Special Active 8745-1356 (Front) KONI Special Active 8245-1357 (Rear) Dinan D100-0910 (Spring Set) Full refresh of suspension components (Mounts, hardware, bump stops, insulators, and guards) Control Arm (Upper & Lower) replacement TOTAL COST (Parts): $1920 I originally wanted to maintain the EDC functionality but with backorders not improving; I'm forced to bite the bullet. It seems the EDC Delete by coding is easy enough which would be the preferred route given the KW Delete Kit is another ~400 dollars.
05-02-2023, 08:07 AM | #12 | |
Rep 492
bilstein b6, dinan, suspension bmw 335i |
