View Poll Results: How reliable has your 135i been? | |||
My N54 powered 135i has problems very frequently. I have to fix this car quite often | 32 | 6.57% | |
My N54 powered 135i has problems somewhat frequently, but not overwhelmingly so. | 51 | 10.47% | |
My N54 powered 135i has only had a few problems, just like any other car out there. | 78 | 16.02% | |
My N54 powered 135i very rarely has a problem. The reliability issues with these cars is overstated. | 71 | 14.58% | |
My N55 powered 135i has problems very frequently. I have to fix this car quite often. | 17 | 3.49% | |
My N55 powered 135i has problems somewhat frequently, but not overwhelmingly so. | 39 | 8.01% | |
My N55 powered 135i has only had a few problems, just like any other car out there. | 80 | 16.43% | |
My N55 powered 135i very rarely has a problem. The reliability issues with these cars is overstated. | 119 | 24.44% | |
Voters: 487. You may not vote on this poll |
09-02-2016, 02:12 PM | #45 |
Rep 5
I've had some issues but nothing major (2010 N54), since I got the car 3 months ago.
My spark plugs were all-black because my injectors (index 07) were leaking. Nothing major, but the previous owner never replaced the plugs (30k miles). Got new plugs, had a faulty low pressure fuel sensor that I changed as well. Ordered new index 12 injectors, replaced them and the engine runs smooth as a baby face. My chargepipe (OEM) blew off (car is stock, except for a Magnaflow cat-back), so I replaced it for a cp-E chargepipe. After that I had errors regarding wheel speed sensors and o2 sensors (pre-cat, bank 1), replaced them all last week just to be on the safe side. Now I'll try to find out which HPFP I have, if it's made by Bosch I'll probably get the newer one ready to be replaced. It's a fantastic car and if you have a scanner, proper tools, knowledge of the commom N54 issues and can DIY most of things it's a no-brainer. |
09-16-2016, 09:28 AM | #46 |
Rep 8
I haven't had many problems, but the ones I did were very expensive to fix. Biggest was the A/C system--had to replace the evaporator, which it seems to happen to many of these. That was just over $2k. Plus, had to have the window regulator on both the passenger and driver sides replaced--$500 each. According to the dealer, this happens when you don't put the windows down and up on a regular basis--they need to do that for lubrication purposes.
The good thing is I bought it 3 years ago (it's a 2008 135i) for only $20k with only 28k miles on it. |
09-16-2016, 12:05 PM | #47 | |
Rep 3,323
The $2K comes from having to remove the dash. a 12 hour labor job. The evap is $90 I'm told. My indy mechanics told me that if it holds pressure just get recharged once a year for $80. I feel your pain.. this car is very expensive to repair. (get ready for the wastegate rattle and new turbos at some point. And WP... the water pump will go between 60K - 80K)
Sparkling Graphite Metallic / 6MT / Terracotta Boston Leather / Sport Package / Comfort Access system / Gray Poplar wood trim / Heated front seats / iPod and USB adapter / HD radio / Premium hi-fi system / OE Tuning / VRSF Intercooler & charge pipe / BMW Performance short shift kit / BMW M Performance Handbrake Handle / BMW Stainless steel pedals / V1 hardwired / rear sun shades Pennsylvania 20 electoral votes
09-25-2016, 08:16 AM | #48 |
Rep 1
I just bought my 09' 3 days ago, the only issues have to do with my radio. If my car is sitting in the sun the display just about completely fades away. Also I have no Sirius/XM radio. Doesn't receive the preview channel or anything, just gives me a message to call Sirius.
09-25-2016, 09:54 PM | #49 |
The One
10
Rep 61
Drives: 2008 m135i coupe sport package
Okay, it's now almost a year since I last posted. I have 90,000 miles on my CPO 2008 135i. I had to replace the fuel injectors, the spark plugs again and now the ignition coils, then I upgraded the LPFP to give my HPFP and Turbo more fuel at the track. Most problems went away, but we just replaced the HPFP again because of some low pressure readings on my Cobb AP. I have the Turbo wastegate rattle that the dealer wouldn't fix under warranty, so I'll either live with it or pay $6500 to upgrade/replace my turbos.
I probably will get a Surge Tank for the LPFP because at the track with a low amount of fuel, I will lose fuel pressure when the gas sloshes away from the LPFP! Both my HID Adaptive headlights went bad ($850 each), and I replaced the extra Oil cooler with a double competition ER Oil Cooler because it was overheating and going into limp mode. But now with everything working and the Cobb AP custom tune, I am getting 400 HP and 550 Torque.
2008 135i coupe w/Sport Package, aFe cold air, TC Kline DA suspension/Camber plates. AA Charge pipe/BOV, cat-less Downpipes, and AA FMIC. SuperSprint mid-pipes, Cobb V3 AP, and Corsa muffler, Wavetrac LSD, M3 contol arms and bushings + RSFB, Rear Toe-control arms, Front and rear H&R sway bars, shock tower brace, Hawk track pads, Michelin Pilot Super Sports. Enkei wheels.
09-26-2016, 08:25 AM | #50 |
Rep 2
2009. N54. Only issue I ever had with it was really squeaky brakes, which got replaced under warranty at around 10K. Granted, my car is fairly low km so that helps.
10-04-2016, 12:37 PM | #52 |
14
Rep 35
Drives: 2012 135i Convertible
I have owned my 2012 DCT N55 Convert for a year now, and I have 92k miles on it. I have had a few things to deal with but not anything crazy:
-Software update to solve lurching issue -Brake sensor re-attached- seemed to be removed by dealer at one point and not reattached - New front suspension (local roadwork, unmarked hole left on a dark roadway-ouch) -Oil filter housing replaced due to a leak -pinhole fuel line leak repaired -full tune up Things I need fixed currently: -chirping climate control fan -alignment -leaking washer fluid/new motors -side mirrors- glass stopped working, cannot reposition |
VRG_135836.50 |
11-01-2016, 08:53 AM | #53 |
Rep 65
My 2012 N55 :
Faulty Ignition Coil CPO covered OFHG leaking - covered under warranty Valvetronic motor replaced under CPO warranty. Drivers side window motor replaced under CPO(window going up then back down) Chargepipe popped off(not covered under CPO, DIYed) Last edited by Served; 07-07-2017 at 01:09 PM.. |
12-12-2016, 12:43 PM | #54 |
44
Rep 193
Not gonna add to the poll as I have only owned the car since August, but I can say for certain that these cars seem to be a mixed bag as mine had tons of good records but the list thus far is still impressive and this is just what I've had done:
2008 135i: 59,000 miles: Completely Stock -CAS, TPMS, Bluetooth Telematic and PDC Module Replacement and programming -Malfunction in rear brake sensor -Third Brake light replaced -Turbos replaced -Coils and Plugs -All Fluids -Oil filter housing, valve cover, front main and oil pan gasket -walnut blasting -PCV system -Both door lock actuators -Passenger headlight washer nozzle -All 6 Fuel injectors and both primary 02 sensors |
12-19-2016, 06:43 AM | #55 |
84
Rep 331
I bought mine 2011 135i DCT N55 a year ago, now my car has 57k mileage.
Recently did MHD flash on my car but all the problems/repairs finished prior to fully stock car except the Performance Exhaust. I will not list any routine/scheduled maintenances since they are required no matter what kind of car you are driven. Here's the things: - Passenger side Adaptive Headlight Module failure. - Evaporator leaking in AC system. - Found leaks under DCT fluid pan due to O-ring and fluid pan gasket/seal. Did the fluid change @ the same time to save labor, the dealer claims that they will reuse the old transmission fluid and put them in after repair which I will have to pay $200 if I want fresh DCT fluid. Such an environmentally friendly company - Oil Filter Housing Gasket leaking - High Pressure Fuel Pump failure and Rail pressure sensor failure The good thing is that most repairs were covered by CPO except for the Adaptive Headlight Module which cost me about $700. My car will be ready for another 50k mileage.
Past: E82 135i Crimson Red | MPE | MHD Stage1+ | Dinan Camber Plate | LCI Blackline | Bavsound stage 1 | KW Coilover V2 |
Past: E93 M3 Vert Alpine White | Remus Sport Exhaust | Past: F82 Yas Marina Blue Civic M4| MPE V2 | DP | BM3 | Apex FL-5 | MP Part(s) | Current: F87 M2 Competition Long Beach Blue | Completely Stock | |
12-19-2016, 05:17 PM | #56 |
<(O0=[][]=0O)>
741
Rep 1,187
2012 N55. Bought June '15 with 46k mi - just a month out of warranty...
Now nearly 67k miles. Oil Filter Housing Gasket leak. Replacing gasket, serpentine belt, tensioner, guide & deflector pulleys, upper radiator hose, upper oil cooler hose, and O-rings. Turns out Oil Filter Housing has some stripped threads, so that's going, too.
2012 E88 M-Sport 135i DSB Metallic
ER CP, ZHP Knob, E60 SSK Lever, E92 M3 FSB, RSFB inserts, Koni Sport, Eibach Pro, UCP, MPSS, AP axle-back, MHD Stage1+ 91 <(O0=[][]=0O)> |
12-19-2016, 06:33 PM | #57 | |
Rep 8,165
The future doesn't look very promising.
12-19-2016, 06:57 PM | #58 |
<(O0=[][]=0O)>
741
Rep 1,187
Past performance is no guarantee of future returns...
Based on all the swirl marks I've discovered in the paint, I do wonder how meticulously mine was maintained by the previous owner. But boy is it a joy to drive! |
12-20-2016, 02:21 PM | #59 | |
Rep 7,224
I break them in properly and aggressively service them (1st oil change at 1200 miles, then 5K oil changes, etc). Professional detail a few times a year. I understand this costs me more but it's worth it to me. If my 1er was to get totaled today I'd probably buy a new M240i and keep it for as long as possible and treat it the same way.
tjswarbrick741.00 |
12-20-2016, 02:25 PM | #60 | |
Rep 1,944
01-05-2017, 02:45 PM | #61 |
Rep 462
202,000 km and only 6 1/2 years old... solid as a rock, still extremely reliable, and no where near the end of its life. I hope you all get to enjoy as many happy miles/kms on this car as I have.
01-05-2017, 04:34 PM | #62 |
138
Rep 253
Drives: 2013 128i LE
Anyone have a creaky/poppy dash when hitting bumps? Getting a lot of noise from the passenger side by the vent/A pillar. Could it be loose? Drives me crazy
// '13 BSM 128i Limited Edition //
01-05-2017, 06:35 PM | #63 | |
<(O0=[][]=0O)>
741
Rep 1,187
Annoying on bumpy roads in town. At speed, or decent surfaces, I don't notice it much. Bought a mechanics stethoscope to find and squelch it, but haven't let anyone else drive it while I do the investigation.
01-26-2017, 08:35 PM | #64 |
Rep 4
Adding to the list, or the noise,here.....
Just picked up a 2013 135is 7sp DCT and it has every availbale option on this car...literally. Much different vehicle than my 2001 330xi, Some quirky things, all First-world oddities: · one key works remotely (not needing to plug it into the dash) another doesnot. ·Idle surges at seemingly random moments · Voice activated system is not very stable...maybe it needs time to acclimate to my voice? · Sluggish off the line; haven't tried Launch Control modest complaints, until I get to understand and know this car. |
03-12-2017, 01:20 AM | #65 |
77
Rep 316
Drives: C63S Sedan|350Z
I have put @ 7500 miles (currently @ 65k) on my 2012 135 DCT & I have not had any problems yet .
Car has been solid so far
C63S Sedan: Long Live The V8
350Z: The Very Poorman's 981 GT4 |
03-12-2017, 06:48 AM | #66 |
Rep 1,498
Drives: 2017 MB C63 S AMG Coupe
'11 135i
Water pump went at 72k(replaced that and thermostat) Valve cover gasket at 69k Dct pan gasket at 70k (did fluid flush at same time) That's it though. Car has been rock solid (more so then either of my n54 cars) Things that need to be done are sparks (don't know when previous owner changed them) and battery (crank getting slightly longer especially in cold, battery looks to be the original)
2017 MB C63 S Coupe - DINAN | MODAL WORKS
retired: GranTurismo MC, Giulia Quadrifoglio, B8.5 RS5, Q60 RedSport, e82 135, F80, e92 M3, e90 M3, (2) e92 335, B8 S4, C209 CLK55 AMG, e46 330 |
