      02-22-2024, 01:30 PM   #23
Wazowski
Wazowski's Avatar
84
Drives: 08 135 6MT vert
2008 E88 135  [10.00]
As you might imagine based on the miles, it’s a DD. Spends all day at work outside, but is garaged at night and weekends (and the occasional snow events&#128521.
GoRomeo968.00
      03-30-2024, 05:27 PM   #24
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
Originally Posted by Gray_Panther View Post
Thank you! My parent's E88 only had issue with glue failing on rear window but my dad sealed it back up. Been holding up fine for two years and no other issues. They open/close the top a lot, so it's nice to have these reported problems and fixes handy in our search history!
Hi there thanks for sharing. Do you know what your dad used to seal the window? One of my sides its got a little opening and would like to seal it as well. Thanks 🙏.
      03-31-2024, 08:45 AM   #25
Hellshalfacre
Nothin to see here
48
Drives: 2017 X3 sdrive28i, 2011 E88
I just did this job last weekend with 3m Window weld. Passed the hose test. There are mixed long term results with this method which I'm sure has more to do with prep and application than of the product itself.
olds350348.00
      03-31-2024, 12:31 PM   #26
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2006 330i  [6.75]
Wow that looks pretty intensive work for me 😂 Thabks for sharing. I will look into that. 👍
      03-31-2024, 12:44 PM   #27
Hellshalfacre
Nothin to see here
48
It doesn't have to be if you have just a small area that needs resealing. For me, the more I tried to crop out the old failed sealant, the more failed areas I found. I finally ended up removing all sealant to the point that the glass was loose in the roof so I could clean everything really well. I used the center (orange) glass clamp just to position the window and add a little upward force. Then a small flat hook at the driver's side top to bring that side down about 5mm or so. This got the glass in the perfect position. Then it was just seal, clamp, and trim off excess. Looks fine. I'll get a shot of the finished product. Really not terribly difficult and cost 60 bucks for everything. I had the large glass clamp from another project. If/when it fails I'll probably do one more round of the same before replacing the top. The rest of the top is in great condition and operates perfectly so I wanted to at least try this method. The tops been up and down about a dozen times since the repair and so far so good. The Florida summer will be the real test though.
GoRomeo968.00
      03-31-2024, 01:54 PM   #28
Hellshalfacre
Nothin to see here
48
Not perfect by any means, but keeps the water out and looks OK. I figure if it holds for a year I'll be happy.
GoRomeo968.00
olds350348.00
      03-31-2024, 03:31 PM   #29
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2006 330i  [6.75]
Wow that look pretty good. So the sealant I need to buy its call the 3M kit sealant?
      03-31-2024, 03:34 PM   #30
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2006 330i  [6.75]
I wonder what I can use to press down the area. Maybe leave it overnight! I notice every time I open the top, that area takes a hit and it cracks opens up the cut 🥹😏
      03-31-2024, 03:39 PM   #31
Hellshalfacre
Nothin to see here
48
Thanks. It's called 3M Window Weld. There are some other similar products, but that one had the best reviews. It's available at most parts stores, Amazon etc. The clamps are on Amazon as well if you decide to go that route.
GoRomeo968.00
      03-31-2024, 07:13 PM   #32
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2006 330i  [6.75]
Yeah I am watching a video on YouTube. Mine its got a small opening about 2” long only so I think I can tackle this project soon. ☝️☺️.
      04-15-2024, 08:47 PM   #33
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2006 330i  [6.75]
Tackled this today after work. Used the windo weld you recommended. Will leave suction clamps overnight. Well see results tomorrow. 🫰🏼😬.
The black glue Residue is supposed to come off using a blade once it dried out.
      04-15-2024, 08:53 PM   #34
Hellshalfacre
Nothin to see here
48
Nice! I taped the glass adjacent to the bead and pulled it off after about an hour, then trimmed any excess off with a utility knife once it dried. My repair is still holding up well but it's only been a couple weeks. We did have some heavy rain and no issues so far. Hope yours comes out great.
GoRomeo968.00
      04-15-2024, 08:58 PM   #35
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2006 330i  [6.75]
Nice. Thank you! 🙏
      04-16-2024, 09:26 PM   #36
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2006 330i  [6.75]
What do you think? 🤔 Not bad huh. Let the clamps for well over 24 hrs. I also opened and closed top and the rear glass stays and sticks to the roof pretty well now. Before it would make a small opening when opening. No more. Rain I am ready for you… Just kidding ☝️😂
      04-17-2024, 07:58 AM   #37
Hellshalfacre
Nothin to see here
48
Sweet! Looks great. I'd say you nailed it. I'm hoping these repairs last awhile but I guess we'll see. Nice work!
GoRomeo968.00
      04-17-2024, 10:02 AM   #38
ejm3
Drives: 2012 135 Convertible 6MT
That looks really good!
2017 Acura MDX
GoRomeo968.00
      04-17-2024, 05:15 PM   #39
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2006 330i  [6.75]
I feel so bad for OP. We hijacked this thread. I hope he found a fix for his roof not opening issues. OP??? I mean its been more than 3 yrs. 🤔
      04-19-2024, 04:41 PM   #40
Hellshalfacre
Nothin to see here
48
Woops, you're right. Sorry OP!
