Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Revs drops on cold start
      05-02-2024, 02:25 PM   #1
tequila318325
Drives: BMW 325i E92
Hello, maybe someone may know what could cause this? The revs slightly drop on only cold starts, when the engine is warm everything is ok. E92 325i. Adding a link to the video : https://www.dropbox.com/scl/fi/gggbi...=v1rh6gj6&dl=0
      05-02-2024, 10:08 PM   #2
gavan_davis
gavan_davis's Avatar
Drives: 2008 E91 328xi
I had this problem a few months ago with my E91 328xi. Turned out to be a vacuum leak in one of the lines and the valve cover. Not entirely sure which line, as the small dealership I bought it from did a smoke test and just fixed it without many specifics. The previous owner had somebody “repair” the cracked valve cover with a bead of silicone…not how that works.
It had the same issue as in your video, cold starts would rev between 400 and about 1600, but would idle more normally the closer it got to operating temperature. Not exactly sure how much a smoke test costs since the dealer fixed everything free of charge, but that could be a good place to start.
      05-03-2024, 03:18 AM   #3
tequila318325
My car literally had a valve cover replaced 1 week ago
After it got replaced everything seemed fine for a few days and then this started to happen.
      05-03-2024, 07:48 AM   #4
gavan_davis
That’s really unfortunate if it is the cover or gasket. Can you see any oil around the bottom of the cover?
      05-03-2024, 01:15 PM   #5
tequila318325
Fortunately no, it looks bone dry.
      05-03-2024, 02:21 PM   #6
gavan_davis
That’s a good sign but I guess since it was only done a week ago it may not be leaking yet depending on how much you’ve driven, if that is the problem. I’m not 100% sure but a dirty MAF might also contribute to this? Before taking my car back to who I bought it from, I sprayed the MAF with CRC MAF cleaner (use that specific product if you choose to clean the MAF), but it didn’t help me since there was a vacuum leak. There’s a few DIY smoke tests on YouTube using a cigar and transfer pump, but I don’t personally know anyone who’s actually ever done it that way, so I can’t entirely recommend that.
      05-03-2024, 02:36 PM   #7
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
2682
Drives: 11' 335is DCT
Then it's probably one of the vac lines.
