Bmwhat app (Carly for BMW)
07-23-2014, 11:47 AM | #68 |
530
Rep 2,083
Anyone able to get BMWhat to work using a K+DCAN cable with the UBS OTG adapter on their Android phone?
Assuming I can enable OTG USB on my phone, I'm curious how this will work. I tried asking him, but he just tells me to buy his cable. |
07-23-2014, 01:13 PM | #69 | |
44
Rep 385
Yah the app is great, but him marketing the hardware is pretty annoying |
07-23-2014, 04:11 PM | #70 | |
453
Rep 2,973
The only adapter they claim will work reliably is theirs. That could be because it's recognized and the others are not. I wanted to buy a real good one from Scantool but just sucked it up and got the BMWhat adapter. Now I need to buy the app.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
07-23-2014, 05:23 PM | #71 |
Rep 425
I bought the WIFI adaptor in the end, for those who are using WIFI and iPhone, how long does it take for the app to connect with the car? Mine takes a good 20+ minutes, should I buy another adapter?
07-24-2014, 01:23 PM | #72 |
453
Rep 2,973
20 minutes is too long.
The BMWhat bluetooth adapter connects pretty fast.
07-24-2014, 01:36 PM | #73 |
26
Rep 16
iPhone 5S here, WiFi adapter takes no more than 30 seconds to connect...
07-24-2014, 01:38 PM | #74 | |
Rep 425
07-24-2014, 02:34 PM | #75 |
26
Rep 16
This is the one I purchased:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 Connects every time! |
07-24-2014, 03:08 PM | #76 |
No 55mph
1622
Rep 8,476
If it hasn't been mentioned before-
Pricing on the Adapters/Cables authorized by BMWhat are as follows:
Personally I use the Android BT Adapter on my 09' 328iX with my Dell Venue8 Android Tablet/KitKat even though the Dell Venue DOES support USB-OTG & would work with the cable as well...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
07-24-2014, 06:03 PM | #77 |
Rep 402
Drives: 2015 550i xDrive
Diagnostic
Got these Fault codes from BMWhat
anyone know what they mean? Instrument cluster: Instrument cluster / Kombiinstrument Fehler: FRMFA failure / light system fault / LSZ alive failure Code: A3C1 Fehler: CAN signal fault light system Code: A3B4 |
07-24-2014, 09:09 PM | #78 |
Rep 743
I did this, works a treat and half the price.
07-24-2014, 11:11 PM | #79 |
Gateropode
329
Rep 2,848
Yes and no. You can read the fault reports and do some maintenance tasks (like what you can do with INPA, but it is all immensely simpler to install and use).
You cannot code with a ELM BT adapter, and it is not very clear to me at this point if you can code with an OTG USB cable. |
07-25-2014, 10:09 AM | #80 |
28
Rep 234
Coded my e90 lci last night with the ELM bluetooth adapter on my Nexus 5.
-folding mirrors with keyfob -windows up/down with keyfob -digital speedo -eject key when holding start/stop. |
07-25-2014, 12:53 PM | #81 | |
Rep 743
07-25-2014, 01:49 PM | #82 |
GoofBall
50
Rep 1,055
According to the writer the OTG will do fine on older E90's but 03/2007 forward needs the Bluetooth adapter. I have a 2008 and my OTG cable will be here in a few days, for a different project but I will test it with the app to see if it will work.
As for adding features he seems open to ideas. In the last 72 hours I have around 14 emails back and forth. If he can figure out how to send a tune through the system this app will take off like wildfire. Even if you do buy his adapters you would still be cheaper than the BT cable alone! |
07-25-2014, 03:12 PM | #83 | |
Rep 743
07-25-2014, 05:49 PM | #84 |
Gateropode
329
Rep 2,848
07-27-2014, 09:35 PM | #85 |
9
Rep 95
Drives: 07 335i E90
so gased for this.. cables are on the way
if only we could code out the bulb check |
07-28-2014, 02:34 PM | #86 | |
Rep 10
So my 2006 330i was able to be coded for almost everything, except the FRM module, which is where I would code out the amber corner lights, correct? You were able to do this on your 2006? Am I missing something, or did I miss an option in a different module? Thanks again! |
07-28-2014, 02:51 PM | #87 |
530
Rep 2,083
Please let us know if the cable + OTG adapter works on your 2008. I would like to try it on my 04/2007 since apparently the OBDII bluetooth adapter I have doesn't work.
07-28-2014, 03:23 PM | #88 |
GoofBall
50
Rep 1,055
The cable came in today as well the $9 bluettooth adapter. I can confirm the bluetooth adapter, I will test the OTG cable tonight.
Yours might be one of the oddball with the leftover parts so you may need the cable instead of the bluetooth. |
bmwhat app, coding |
