The N54 Manifold Swap Thread
04-25-2022, 02:35 PM | #67 |
Old Geezer
364
Rep 1,193
Drives: 08 E92 N53B30
N52 TB versus N54 TB
04-25-2022, 03:51 PM | #68 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
Supposedly a larger 'big bore' N54 TB is coming to the market but I bet the gains are not worth the cost. I also don't trust the company supposedly making it.
https://shop.hyper-racing.net/produc...e-body-upgrade A whole 4mm larger! What they should do is a full 100MM TB for the N54 and the manifold to go with it. Not that we can fit 100MM/4'' charge piping
04-27-2022, 03:59 AM | #69 | |
9
Rep 32
Any reason you put TB upside down? |
04-27-2022, 09:31 AM | #70 |
27
Rep 29
There's a vacuum line that connects to the stock manifold on the forward side of the throttle body, right behind it. It's a hard plastic line (like the line that goes from the vacuum pump to the brake booster) so it can't bend without possibly breaking. On the N54 TB, the connection for that line faces the firewall so I had to flip it around so it points towards the front of the car.
Biginboca3767.50 |
04-27-2022, 10:00 AM | #71 | |
Old Geezer
364
Rep 1,193
04-27-2022, 01:31 PM | #72 | |
27
Rep 29
I also remember seeing pics of the TB oriented backwards on the white 128i with the N54 IM and figured that's what I may have to do on mine: https://www.1addicts.com/forums/show....php?t=1451616 But in the end, as long as everything is working properly, I'm happy with the swap! |
Torgus3781.50 |
04-28-2022, 06:01 AM | #73 |
56
Rep 92
On the N52 the connection isn't toward the firewall but on the opposite site as noted. When i installed N54 manifold and TB i had to rotate it too
EURO E92 325i N52B30 SWAP 6MT | 3SIM | MILVS | 22RPD | 3.91 DIFF
Biginboca3767.50 |
05-24-2023, 11:45 PM | #74 |
205
Rep 172
Here is a dyno comparison of the N54 intake manifold vs. the 3 stage intake manifold on the 22RPD stage 2 tune with headers. (no milvs)
Long story short, you trade 7wtq for 11whp, and a wider powerband by going with the n54im on a 22RPD tune. Add MILVs and now there is no loss.
I don't check PM, DM me on Instagram @rai_n52
22RPD Vendor - 2006 330i - N54 Intake Manifold l N54 Throttle Body l Gruppe-M Intake l MILVS l 22RPD E85 Tune l S65 Injectors l HZ Racing Headers l TCKLINE SA Coilovers l M3 Front Arms l VWETISH Diff Brace l 3,91 Differential |
05-29-2023, 02:12 PM | #75 |
56
Rep 92
last time i tried i lost much more than that on StageFP N54 tune.
Now I am on 22RPD, that graph is alluring, i may retry it. I should have all the hardware ready to go in my stash. Looks a bit too good to be true though, but who knows |
05-30-2023, 12:21 PM | #77 | |
Slow.
3782
Rep 7,152
05-30-2023, 03:42 PM | #78 |
210
Rep 169
Has anyone tried the N54 manifold without headers?
I know most folks would have upgraded headers at that point, but I don't want the noise or emissions concerns. Also don't want to mess with $800 valves that will eventually fail. |
07-07-2023, 02:30 PM | #79 |
Parts Pro
65
Rep 134
Drives: 2007 BMW 328xi 6MT
Just purchased mine for 100$ Canadian rupees
E90 328xi 6MT | Intake Scoops | K&N + Charcoal Filter Delete | DIY Dinan 3in | 3.25in + 3.5in piping | N54 Manifold | Ceramic Coated Headers | Secondary Cat Delete | Xdelete | 3.91 Diffs | 22RPD Tune
07-09-2023, 02:13 PM | #80 |
Rep 4
Looking forward to completing this swap.
I have a dedicated E90 330i race car, racing in a local series in South Africa. The performance characteristics of this swap should suit a race car application very well. I am going to try get the car on the dyno this week to get a "before" curve before I begin the hardware installation and take it to my Tuner to get optimised. I have recently purchased Bimmer Tuning Tools MSV70 Quickflash and am keen to start understanding some of the maps and tables that govern the cars performance. |
ornicar136.00 |
07-15-2023, 12:32 AM | #81 |
43
Rep 109
07-20-2023, 07:26 PM | #82 |
Parts Pro
65
Rep 134
I made some 3D printed N54 Intake Manifold guides instead of doing the DIY on it for anyone who has printer. https://cults3d.com/en/3d-model/gadg...for-n52-engine
Torgus3781.50 Onizukachan1137.50 |
08-27-2023, 07:06 PM | #83 |
Parts Pro
65
Rep 134
3D printed dowels and PCV heater washer is 3D printed as well since I couldn’t find it.
08-28-2023, 08:47 AM | #84 | |
Rep 4,204
Mods: Yes.
08-28-2023, 11:52 PM | #85 | |
43
Rep 109
For example, in 4th gear, the pull takes longer and this is what I use when I log and look at differences in tune or car settings. I looked at old Logs and with the stock 130i tune and the mixture goes to almost 0.83 in high gears above 6500rpm. The curves are smoothed, but all curves have the same settings. The virtual dyno only measures time and speed, the bounce of the road and other factors are noticeable in the curves if they are not smoothed out a bit. I plan to go back to the 3IM setup in a next couple of weeks. I want to use the 3IM setup in winter. I am using now the new version of N54 tune. A few changes were made to the new tune and it is slightly better than the previous tune I used. I do the same comparison when I swap the 3IM intake manifold back and I also have a 22RPD tune for it. Last edited by MOD.Works; 08-29-2023 at 12:18 AM.. |
08-30-2023, 07:44 AM | #86 |
998
Rep 2,287
Need to remember, these engines run a closed loop fuel system, even at full load. Fuel air mixture will always match the target map in the tune. At least until Cat protection kicks in and starts dumping more fuel.
DME measures the exhaust and wil adjust fuel mixture to match target values, in real time. Minor engine modifications will only require small trim changes. There is a limit, if the required trim percentage exceeds the allowable limit, you will receive an SEL. Stock tunes are targeted Rich above 6,500 RPM. |
ornicar136.00 |
08-30-2023, 06:01 PM | #87 | |
Parts Pro
65
Rep 134
