BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Changing NBT Country Coding
Extreme Powerhouse
      04-26-2023, 04:56 PM   #89
weld
Drives: 320
Originally Posted by antonandres View Post
Based on my experience with NBT, You need a new FSC pack for NZ region. You can buy them at FlashXCode for about 45€
Please note that this only works for NBT, if you have NBT Evo which is ID4 (looks identical to NBT) then you have to upgrade the software to ID6 before you can convert as ID4 suffers from a region lock.
To find your version:
Map type NEXT will mean you have NBT.
Map type EVO but everything looks like NBT means you have ID4.
Hope that helps a bit
Thanks a lot, antonandres! I just found a guy on Taobao helped me remotely, he just forworded the odb port to his server(he used FRP tools: https://github.com/fatedier/frp), so I didn't know how exactly he did on the software, but he let me put the usb drive in the armrest then generated a bin file, then serveral reboot from NBT, it worked perfectly. He showed me the 00A1 had been converted to 00A0 successfully and been accept. I asked him how did it, he said just reset the FSC. And the previous FSC code I bought for NZ 2022 NEXT map still work. It only cost 20 mins to figure out my big problem, I have spend on it for many days.
      05-05-2023, 04:12 AM   #90
hawk188
Drives: BMW M135i F20
Revisituing old post ATZEBMW or Kiwkdecal please
Originally Posted by atzebmw View Post
Why do you want to flash the NBT?
Change the Salapa-Options in your VO and then only code the NBT.
All changes will be automatically set.
Hopefully either of you Atzebmw or Kiwidecal would read this. Or if anyone can help provide detail instruction on how to change VO / FA country and language from Japan to NZ please? New learner to e-sys and wanting to change Jap import to NZ navigation. I am able to read FSC from nbt of my car but not sure how or where / what value to change VO/FA to.. helpe anyone ? THANKS in advance
      05-05-2023, 01:54 PM   #91
TheNine90
Drives: bmw
Delete these from fa
807 National version japan
852 Language version Japanese
and add these to FA.
810 National version Australia
853 Language version English
For editing FA look at the link below.
https://www.bimmerfest.com/threads/c...sheets.983245/
If you have NBT then you can just code and map FSC will change to ECE. After that extract the FSC and generate code for maps you want to install
If you hhave NBTEvo you will have to do region change using feature installer. You will receive FSC files. Copy fsc to usb with maps and maps should start updating.
      05-05-2023, 05:36 PM   #92
hawk188
Thank you very much ! I think I've done enough reading and just plucking up the courage to do it. Hope I dont bricj the car - wife will not be happy LOL....
      05-05-2023, 10:33 PM   #93
TheNine90
Drives: bmw
If you are only coding then its safer. Just make sure to have backups. I can help you if you need any assistance.
      05-06-2023, 01:22 AM   #94
hawk188
Nav change from Jap to NZ
Thank you very kindly TheNine90 captain! So thankful there are awesome people like yourself and ShawnSheridan ! I think I've read enough to try soon and will let you know the outcome..
Have a great day !!
      05-06-2023, 07:49 PM   #95
hawk188
A little follow up help please
Sunday 7 May : So following the guide , I've gone as far as successfully Writing the new FA to the car. ( Changed '807' to '810' and '852' to '853' in Salapa Elements.) Entire process did not show any errors so hopefully that's a good sign.
I need some help please next on "If you have NBT then you can just code and map FSC will change to ECE. After that extract the FSC and generate code for maps you want to install"
Can you please tell me what value/where to code sir ? sorry to trouble you...
i'm ok with changing values in FDL coding if thats where I'll be changing.. just need to know what vlaue to change to >.. thanking you in advance...
      05-07-2023, 01:56 AM   #96
TheNine90
Drives: bmw
If you coded using fa then you are good to go. No need to do any fdl coding.
Now check if you have 00A0 FSC accepted. After that you need to extract DE FSC and generate map code.
Pm me i can help you with extracting the fsc and getting map codes.
      05-07-2023, 05:30 AM   #97
hawk188
Thank you sire. So I have done all the above successfully.. and got the map updated to Aust/NZ NEXT 2022.. done the fsc extraction and generated code..etc.etc.. all good
BUT now the Navigation option is grayed out. The 00A0 FSC reads "Rejected" and more reading says its a Region Unlock code I need. ( different than the FSC generated code ), Hope you can help me as I felt i was so close .... Thank you once again Captain.
      05-07-2023, 07:07 AM   #98
TheNine90
Drives: bmw
For NBT using coding it should change to 00A0 FSC. For NBTEvo you require Region Unlock code.
Try flashing the NBT, maybe 00A0 FSC would be accepted.
      05-08-2023, 01:20 AM   #99
hawk188
Thank you .. I am downloading the full pszdata as i understand flashing the ECU (NBT ) will require the full database. Will give the flashing a go - my last option i guess.. thank you again for your time Captain TheNine90 !
      05-11-2023, 06:57 AM   #100
stjackBMW
Drives: BMW 320d 2013
Hi I have my 00A0 rejected
FSCSCertStatus accepted
FSCStatus rejected
AppNr./UpgrIdx 160(0xA0)/1(0x01)
SWTType SWTclassic full
What should I do? Thanks in advance.
      05-11-2023, 11:13 AM   #101
TheNine90
Drives: bmw
You can try flashing. If you code properly it will accept.
      05-15-2023, 05:40 AM   #102
hawk188
FSCStatus rejected
@stjackBMW - I haven't got around to flashing my ECU and will share with you when I do either way ( success of fail ) ......please share if you have managed to flash your ECU ..... cheers
      05-17-2023, 03:58 PM   #103
kubax86
kubax86's Avatar
1790
Drives: M2
FSCStatus rejected
Just need to load appropriate FSCs to solve this
      05-18-2023, 03:46 PM   #104
hawk188
Hi Kubax86 - so no need to flash ECU ? Thank you
      08-03-2023, 03:19 AM   #105
1989964
Drives: F11 535d
FSCStatus rejected
Hi Stack, did you get this sorted? im in the same boat and wondering if a eu map and the correct keycode will bring it back to life. thanks
      08-06-2023, 08:49 PM   #106
Charlesfeedomgundam
New Zealand
Drives: Bmw f30 330d
Hi man i am also in nz did you work it out on esys? is that possible i can learn from you please?
      08-07-2023, 01:00 AM   #107
1989964
Drives: F11 535d
Hi I will try to do mine this week and report back. I'm hopeful of success
      08-12-2023, 10:53 AM   #108
HanRau
Drives: Bmw F02 750LI
Hi Fellas,
I have the same problem. I got an NBT, car (JP import) is programmed to EU/Germany and we installed EU maps but the car will not accept the FSC.
I understood that when you copy the FSC to the USB with the map data you should place it into a folder named "FSC" in the main root but I have not tried that. Any other tips I could try?
      08-12-2023, 11:17 AM   #109
shawnsheridan
General
shawnsheridan's Avatar
Originally Posted by HanRau View Post
Hi Fellas,
You describe process for NBT2 EVO, but you say you have NBT. Which Head Unit do you have?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      08-22-2023, 02:38 AM   #110
1989964
Drives: F11 535d
hi i have changed FA, coded nbt, (f10), finally managed to flash nbt but the fsc status is STILL AppID 160(0xA0)
UpgradeIndex 1(0x01)
FSCStatus rejected
FSCCertStatus accepted
it has taken me weeks to even flash the nbt, finally got it to work with 3.27 using tal from 3.4 after failing after the bootloader as many have found, at that was AFTER setting up dhcpserver.de on the computer.....
all files in nbt are black when looking to update except 2 ENTD_00001A07_006_016_002 and
NAVD_000014B7_255_001_103
can anyone please help. thank you
